I installed Manjaro KDE about a week ago. The experience has been amazing but from few days I am facing this issue with my wifi connection. At first it showed limited wifi connection even though in my other devices wifi was fine. I removed my wifi and again tried to connect but from then the problem is on, KDE Wallet always shows popup and wifi doesn’t connect after entering the password everytime the wifi Authenticate pops up.
Just In: I just noticed, when I connect to my earbud by bluetooth the wifi slows down to the point where web page doesn’t reload. I turned off the wifi then again tried to connect it asks for password again (Authenticate) but if I disconnect my bluetooth earbud the wifi is working.
Please provide me with solution if you are familiar or know what’s going on.
Olli
15 June 2024 10:03
2
please post the output of the mandatory
first. use the option “preformatted text” (the </> ) and paste it inside.
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=1dcf5a69-04bc-45eb-a13b-81182603f09d rw quiet
cryptdevice=UUID=328a6c03-522c-4375-805b-a04538d73726:luks-328a6c03-522c-4375-805b-a04538d73726
root=/dev/mapper/luks-328a6c03-522c-4375-805b-a04538d73726 splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Dell product: Inspiron 15 3511 v: N/A
Mobo: Dell model: 0042CN v: A00 serial: <superuser required> part-nu: 0AB0
uuid: <superuser required> UEFI: Dell v: 1.28.0 date: 03/08/2024
ID-1: BAT0 charge: 9.9 Wh (31.9%) condition: 31.0/40.0 Wh (77.5%) volts: 11.9
min: 11.2 model: SMP DELL MGCM514 type: Li-poly serial: <filter>
status: charging
System RAM: total: 8 GiB available: 7.51 GiB used: 3.21 GiB (42.7%)
Array-1: capacity: 16 GiB slots: 2 modules: 1 EC: None
Device-1: DIMM A type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 3200 MT/s actual: 2667 MT/s volts: curr: 1 width (bits): data: 64
total: 64 manufacturer: 802C0000802C part-no: 4ATF1G64HZ-3G2E2
serial: <filter>
Device-2: DIMM B type: no module installed
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 400 min/max: 400/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 38720
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip user_shstk vaes vme vmx vnmi vpclmulqdq vpid x2apic
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 0bda:5522
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: LG Display 0x06ff built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 7.33 GiB unified: yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
bus-ID: 0000:01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 0bda:c829
Device-1: luks-328a6c03-522c-4375-805b-a04538d73726 maj-min: 254:0
type: LUKS dm: dm-0 size: 238.17 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 238.17 GiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 31.63 GiB (13.3%)
model: PC SN530 NVMe WDC 256GB size: 238.47 GiB block-size: physical: 512 B
fw-rev: 21113012 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.37 GiB (97.99%)
used: 31.63 GiB (13.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-328a6c03-522c-4375-805b-a04538d73726 label: N/A
uuid: 1dcf5a69-04bc-45eb-a13b-81182603f09d
used: 460 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5DCE-6C3C
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: Realtek Integrated_Webcam_HD type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0bda:5522 class-ID: fe01 serial: <filter>
Device-2: 1-10:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:c829 class-ID: e001 serial: <filter>
System Temperatures: cpu: 52.0 C mobo: 49.0 C
Fan Speeds (rpm): cpu: 900
Processes: 244 Power: uptime: 2h 51m states: freeze,mem,disk suspend: s2idle
wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 2.99 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1215 pm: pacman pkgs: 1208 libs: 348 tools: pamac,yay pm: flatpak
pkgs: 7 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
Olli
15 June 2024 11:30
4
there is a firmware update for realtek in the aur
pamac search realtek
should show it up if aur is enabled.
pamac install realtek-firmware
will install it
it’s always good to update the firmware of the hardware to the latest
Conflict occurred
pamac search realtek ✔
realtek-firmware 20191022-1 AUR
Realtek-specific firmware for WiFI, Bluetooth and Ethernet cards
~ pamac install realtek-firmware ✔
Warning: realtek-firmware is only available from AUR
Preparing...
Checking realtek-firmware dependencies...
Resolving dependencies...
Checking inter-conflicts...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing linux-firmware breaks dependency 'linux-firmware' required by linux69
Edit build files : [e]
Apply transaction ? [e/y/N] y
Transaction cancelled.
What should I do ?
Sounds like a misconfig in your DNS Resolver Settings. Had the same issues as well, especially, when you are in a Network within 14 eyes alliances wher ISP’s only allow certain DNS Servers as Intelligence monitors all internet traffic. Are you using VPN?
Check your Resolver Settings and maybe also try this as a workaround with your own specified DNS Settings from here: Manjaro Forum Link - NETWORKING
Concerning your bluetooth problem: This is normaly due to the fact of frequency overlapp and the frequencies used by your modem. Especially, when it points from the same direction. - Solution: Try other drivers for your Network Adadpter and/or try 5G or change your modem position.
For me it worked when I changed my modem the best.
No I don’t use vpn.
The first problem was solved. I just had to disable KDE wallet and in Wi-Fi & Networking => Wi-Fi Security, I entered my wifi password and selected ‘Store password for all users (not encrypted)’ and after reboot the problem was solved, It didn’t ask for password anymore and limited connection was also not shown. I don’t know if that’s how it was solved but I didn’t face the problem again.
As for second problem with Bluetooth and Wi-Fi, like you said it was due to interference of frequency both being same (2.4GHz). Your suggestion for solution on changing the Network Adapter worked for me. I changed my driver from rtw_8821ce
to rtl8821ce
and wifi is working while I am listening song on my earbuds rn
Thank you for helping solve this for me @Frater_418 and @Olli
system
Closed
17 June 2024 04:01
12
