Hi - Here is the output of inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=793d1021-0f25-4131-90f7-02a0ef0aecee rw quiet
cryptdevice=UUID=4ede1347-0ca7-4348-acf7-c76998eb2e72:luks-4ede1347-0ca7-4348-acf7-c76998eb2e72
root=/dev/mapper/luks-4ede1347-0ca7-4348-acf7-c76998eb2e72 apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: HP product: HP EliteBook Folio 1040 G3 v: N/A
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 80FA v: KBC Version 01.72 serial: <filter> UEFI: HP
v: N83 Ver. 01.21 date: 01/30/2018
ID-1: BAT0 charge: 27.1 Wh condition: 42.1/42.1 Wh (100%) volts: 11.7/11.4
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
Topology: Dual Core model: Intel Core i7-6600U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: D6
L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 22408
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 801
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-9:4
chip ID: 04f2:b530
Display: x11 server: X. Org 1.20.9 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: eDP1 res: 2560x1440 hz: 60 dpi: 210 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d70
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Ethernet I219-LM vendor: Hewlett-Packard driver: e1000e
v: 3.2.6-k port: efa0 bus ID: 00:1f.6 chip ID: 8086:156f
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0
bus ID: 01:00.0 chip ID: 8086:24f3
Local Storage: total: 238.47 GiB used: 21.99 GiB (9.2%)
ID-1: /dev/sda vendor: Micron model: MTFDDAV256MBF-1AN15ABHA
size: 238.47 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: M6T3 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 21.99 GiB (9.4%) fs: ext4 dev: /dev/dm-0
System Temperatures: cpu: 41.0 C mobo: 0.0 C
Processes: 208 Uptime: 51m Memory: 15.52 GiB used: 1.82 GiB (11.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1211 lib: 321
flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
It is only happening on this machine. I am only using wifi, ethernet is not being used. For power management i’m using TLP and I have disabled all of the wifi power saving options, likewise under Power Management I have Wireless unchecked.
I did try to reinstall NetworkManager, have not restarted yet. I think it did install all dependencies but i’m not sure. I just used “pamac reinstall networkmanager”.
