Hi there!
Every time I boot up my laptop, I notice that after going through the login screen both the wifi and ethernet cable are disabled by hardware in less than 1 minute.
Inxi output:
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ef484781-2ef2-4aae-a8ac-ada204be80d1 rw quiet splash apparmor=1
security=apparmor resume=UUID=f92cadcc-25a9-4054-97c5-8ccf24417d7e
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 20041 v: Lenovo G460
serial: <superuser required>
Mobo: LENOVO model: N/A serial: <superuser required> part-nu: Calpella_CRB
uuid: <superuser required> BIOS: LENOVO v: 29CN40WW(V2.17) date: 04/13/2011
ID-1: BAT1 charge: 0 Wh condition: N/A/47.5 Wh volts: 8.7 min: 11.1
model: SANYO PABAS024 type: Li-ion serial: <filter> status: not charging
Info: model: Intel Core i5 M 460 bits: 64 type: MT MCP arch: Westmere
gen: core 1 level: v2 built: 2010-11 process: Intel 32nm family: 6
model-id: 0x25 (37) stepping: 5 microcode: 0x7
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1199 min/max: 1199/2534 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1199 2: 1199 3: 1199
4: 1199 bogomips: 20226
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5.75 process: Intel 45nm built: 2010 ports:
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0046 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 note: <missing: xdpyinfo/xrandr>
Monitor-1: LVDS-1 model: LG Display 0x02e9 built: 2010 res: 1366x768
dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.5 compat-v: 2.1 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics (ILK)
device-ID: 8086:0046 memory: 1.46 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo de: xfce4-display-settings x11: xprop
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
class-ID: 0403
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 05:00.0 chip-ID: 14e4:4727 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 06:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IF-ID-1: wlp5s0b1 state: down mac: <filter>
Local Storage: total: 465.76 GiB used: 27.06 GiB (5.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPCX-21VHAT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 456.96 GiB size: 448.72 GiB (98.20%) used: 27.06 GiB (6.0%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 41.4 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 6 GiB available: 5.59 GiB used: 1.94 GiB (34.7%)
Processes: 199 Power: uptime: 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.22 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1134 libs: 354 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: N/A Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.37
Dmesg errors and warnings:
[ 0.164417] x86/cpu: VMX (outside TXT) disabled by BIOS
[ 0.257781] APIC calibration not consistent with PM-Timer: 406ms instead of 100ms
[ 0.258247] core: CPUID marked event: 'bus cycles' unavailable
[ 0.267939] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.425756] pnp 00:00: disabling [io 0x164e-0x164f] because it overlaps 0000:00:1c.4 BAR 13 [io 0x1000-0x1fff]
[ 19.630545] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20240827/utaddress-204)
[ 19.630580] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20240827/utaddress-204)
[ 19.630589] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20240827/utaddress-204)
[ 19.630597] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20240827/utaddress-204)
[ 19.630605] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 19.801489] at24 7-0050: supply vcc not found, using dummy regulator
[ 19.803234] at24 7-0052: supply vcc not found, using dummy regulator
[ 20.275048] r8169 0000:06:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 21.236281] Support for cores revisions 0x17 and 0x18 disabled by module param allhwsupport=0. Try b43.allhwsupport=1
[ 21.236289] b43 bcma0:1: probe with driver b43 failed with error -524
[ 26.804898] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 26.804916] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 26.887553] kauditd_printk_skb: 154 callbacks suppressed
[ 26.918262] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 26.918274] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 29.203690] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 29.203708] brcmsmac bcma0:1: brcms_ops_config: change power-save mode: false (implement)
[ 29.680017] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: associated
[ 29.680025] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: true (implement)
[ 30.853567] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211: AC_VO txop exceeded phylen 159/256 dur 1778/1504
[ 30.858130] brcmsmac bcma0:1: wl0: brcms_c_d11hdrs_mac80211: AC_VO txop exceeded phylen 137/256 dur 1602/1504
[ 31.319039] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[ 42.360966] brcmsmac bcma0:1: wl0: brcms_c_watchdog: dead chip
[ 43.481009] brcmsmac bcma0:1: ops->tx called while down
[ 44.057764] brcmsmac bcma0:1: brcmsmac: brcms_ops_bss_info_changed: disassociated
[ 44.057780] brcmsmac bcma0:1: brcms_ops_bss_info_changed: arp filtering: 1 addresses (implement)
[ 44.057785] brcmsmac bcma0:1: brcms_ops_bss_info_changed: qos enabled: false (implement)
[ 44.057791] brcmsmac bcma0:1: wl0: brcms_c_wme_setparams : no-clock
[ 44.057796] brcmsmac bcma0:1: wl0: brcms_c_wme_setparams : no-clock
[ 44.057799] brcmsmac bcma0:1: wl0: brcms_c_wme_setparams : no-clock
[ 44.057802] brcmsmac bcma0:1: wl0: brcms_c_wme_setparams : no-clock
[ 44.190994] brcmsmac bcma0:1: ops->tx called while down
[ 44.191038] brcmsmac bcma0:1: ops->tx called while down
[ 44.257625] brcmsmac bcma0:1: ops->tx called while down
[ 44.257638] brcmsmac bcma0:1: ops->tx called while down
[ 44.324289] brcmsmac bcma0:1: ops->tx called while down
[ 44.324301] brcmsmac bcma0:1: ops->tx called while down
[ 44.390998] brcmsmac bcma0:1: ops->tx called while down
[ 44.391010] brcmsmac bcma0:1: ops->tx called while down
[ 44.457665] brcmsmac bcma0:1: ops->tx called while down
[ 44.457677] brcmsmac bcma0:1: ops->tx called while down
[ 44.524343] brcmsmac bcma0:1: ops->tx called while down
[ 44.524367] brcmsmac bcma0:1: ops->tx called while down
[ 44.590962] brcmsmac bcma0:1: ops->tx called while down
[ 44.590994] brcmsmac bcma0:1: ops->tx called while down
[ 44.660974] brcmsmac bcma0:1: ops->tx called while down
[ 44.660991] brcmsmac bcma0:1: ops->tx called while down
[ 44.727625] brcmsmac bcma0:1: ops->tx called while down
[ 44.727639] brcmsmac bcma0:1: ops->tx called while down
[ 44.794363] brcmsmac bcma0:1: ops->tx called while down
[ 44.794396] brcmsmac bcma0:1: ops->tx called while down
[ 44.860998] brcmsmac bcma0:1: ops->tx called while down
[ 44.861013] brcmsmac bcma0:1: ops->tx called while down
[ 44.912537] brcmsmac bcma0:1: ops->tx called while down
[ 45.507725] brcmsmac bcma0:1: ops->tx called while down
[ 46.494362] brcmsmac bcma0:1: ops->tx called while down
[ 48.067639] brcmsmac bcma0:1: ops->tx called while down
[ 48.067654] brcmsmac bcma0:1: ops->tx called while down
[ 48.134287] brcmsmac bcma0:1: ops->tx called while down
[ 48.134300] brcmsmac bcma0:1: ops->tx called while down
[ 48.201004] brcmsmac bcma0:1: ops->tx called while down
[ 48.201029] brcmsmac bcma0:1: ops->tx called while down
[ 48.267639] brcmsmac bcma0:1: ops->tx called while down
[ 48.267661] brcmsmac bcma0:1: ops->tx called while down
[ 48.334289] brcmsmac bcma0:1: ops->tx called while down
[ 48.334302] brcmsmac bcma0:1: ops->tx called while down
[ 48.400967] brcmsmac bcma0:1: ops->tx called while down
[ 48.400980] brcmsmac bcma0:1: ops->tx called while down
[ 48.467629] brcmsmac bcma0:1: ops->tx called while down
[ 48.467641] brcmsmac bcma0:1: ops->tx called while down
[ 48.534289] brcmsmac bcma0:1: ops->tx called while down
[ 48.534302] brcmsmac bcma0:1: ops->tx called while down
[ 48.600960] brcmsmac bcma0:1: ops->tx called while down
[ 48.600972] brcmsmac bcma0:1: ops->tx called while down
[ 48.667653] brcmsmac bcma0:1: ops->tx called while down
[ 48.667670] brcmsmac bcma0:1: ops->tx called while down
[ 48.734297] brcmsmac bcma0:1: ops->tx called while down
[ 48.734341] brcmsmac bcma0:1: ops->tx called while down
[ 53.820923] brcmsmac bcma0:1: ops->tx called while down
[ 53.820936] brcmsmac bcma0:1: ops->tx called while down
[ 53.887581] brcmsmac bcma0:1: ops->tx called while down
[ 53.887590] brcmsmac bcma0:1: ops->tx called while down
[ 53.954305] brcmsmac bcma0:1: ops->tx called while down
[ 53.954320] brcmsmac bcma0:1: ops->tx called while down
[ 54.020956] brcmsmac bcma0:1: ops->tx called while down
[ 54.020977] brcmsmac bcma0:1: ops->tx called while down
[ 54.087733] brcmsmac bcma0:1: ops->tx called while down
[ 54.087754] brcmsmac bcma0:1: ops->tx called while down
[ 54.154248] brcmsmac bcma0:1: ops->tx called while down
[ 54.154261] brcmsmac bcma0:1: ops->tx called while down
[ 54.224330] brcmsmac bcma0:1: ops->tx called while down
[ 54.224346] brcmsmac bcma0:1: ops->tx called while down
[ 54.290982] brcmsmac bcma0:1: ops->tx called while down
[ 54.290999] brcmsmac bcma0:1: ops->tx called while down
[ 54.357676] brcmsmac bcma0:1: ops->tx called while down
[ 54.357693] brcmsmac bcma0:1: ops->tx called while down
[ 54.427725] brcmsmac bcma0:1: ops->tx called while down
[ 54.427743] brcmsmac bcma0:1: ops->tx called while down
[ 54.494357] brcmsmac bcma0:1: ops->tx called while down
[ 54.494393] brcmsmac bcma0:1: ops->tx called while down
[ 59.024241] brcmsmac bcma0:1: brcms_ops_start: brcms_up() returned -132
How can I fix that?
