WiFi Device not found after upgrade
Hi … after the latest upgrade my WiFi device was lost after a reboot.
nmcli device wifi list
gives no results.
Output of inxi -zv8
  Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=893e3f7b-4c42-478d-b0b7-09828421f74c rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.13.0
  Type: Laptop System: HP product: HP EliteBook 865 16 inch G11 Notebook PC
    v: SBKPF serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 8C6E v: KBC Version 04.4A.00 serial: <superuser required>
    part-nu: 8T647AV uuid: <superuser required> UEFI: HP v: W82 Ver. 01.02.01
    date: 09/09/2024
  ID-1: BAT0 charge: 52.9 Wh (100.0%) condition: 52.9/56.0 Wh (94.3%)
    volts: 13.1 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
    serial: <filter> status: full cycles: 36
  Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device
    Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 64 GiB available: 60.61 GiB used: 5.99 GiB (9.9%)
  Device-1: Bottom-Slot 1(left) type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M425R4GA3PB0-CWMOL serial: <filter>
  Device-2: Bottom-Slot 2(right) type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 PRO 8840U w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
    microcode: 0xA705206
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1099 min/max: 400/5132 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1099 2: 1099 3: 1099
    4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
    13: 1099 14: 1099 15: 1099 16: 1099 bogomips: 105455
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
    avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 vendor: Hewlett-Packard
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-2,eDP-1 empty: DP-1, DP-3, DP-4, DP-5, DP-6, DP-7, HDMI-A-1,
    Writeback-1 bus-ID: c3:00.0 chip-ID: 1002:1900 class-ID: 0300 temp: 41.0 C
  Device-2: Chicony HP 5MP Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 04f2:b7e9
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5520x2374 s-dpi: 96 s-size: 1458x627mm (57.40x24.69")
    s-diag: 1587mm (62.48") monitors: <missing: xrandr>
  Monitor-1: DP-2 model: Lenovo T32p-30 serial: <filter> built: 2023
    res: 3840x2160 dpi: 140 gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green:
    x: 0.259 y: 0.639 blue: x: 0.141 y: 0.051 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1366x768, 1280x800, 1280x720, 1024x768,
    800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 76 2: parse_edid:
    unhandled CEA mode 95
  Monitor-2: eDP-1 model: BOE Display 0x0bfb built: 2023 res: 1920x1200
    dpi: 141 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2 2: parse_edid: unknown tag
    112
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.4-arch1.1
    phoenix LLVM 19.1.7 DRM 3.61 6.12.25-1-MANJARO) device-ID: 1002:1900
    memory: 1.95 GiB unified: no
  API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV PHOENIX) driver: mesa radv v: 25.0.4-arch1.1
    device-ID: 1002:1900 surfaces: xcb,xlib
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: c3:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Hewlett-Packard driver: snd_pci_ps v: kernel
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
    snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c3:00.5
    chip-ID: 1022:15e2 class-ID: 0480
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: c3:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
    vendor: Hewlett-Packard driver: N/A modules: rtw89_8852ce pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: a000 bus-ID: 01:00.0 chip-ID: 10ec:c852
    class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.1:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp197s0f4u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-52190c4f06ab state: down mac: <filter>
  IF-ID-2: br-c266a0de5dd7 state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0bda:c85c
  Local Storage: total: 476.94 GiB used: 187.31 GiB (39.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HP02AN00 temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 187.31 GiB (40.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 893e3f7b-4c42-478d-b0b7-09828421f74c
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: A523-6074
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 1-3:2 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:c85c class-ID: e001 serial: <filter>
  Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:00f0 class-ID: ff00 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 3-1:2 info: Chicony HP 5MP Camera type: video driver: uvcvideo
    interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 04f2:b7e9 class-ID: fe01 serial: <filter>
  Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 7-1:2 info: Lenovo USB2.1 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:1082
  Device-1: 7-1.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 94mA
  Hub-9: 7-1.2:5 info: Lenovo USB2.1 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:1084
  Device-1: 7-1.2.3:6 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 7-1.4:4 info: Realtek HID Device type: HID
    chip-ID: 0bda:1100 class-ID: 0300
  Hub-10: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1257 libs: 342 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    3: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    4: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    5: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    7: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    8: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 373
  1: cpu: 4.8% command: chrome pid: 10631 mem: 274.3 MiB (0.4%)
  2: cpu: 4.1% command: chrome pid: 5909 mem: 693.0 MiB (1.1%)
  3: cpu: 3.6% command: chrome pid: 5964 mem: 400.2 MiB (0.6%)
  4: cpu: 3.5% command: chrome pid: 10767 mem: 276.5 MiB (0.4%)
  5: cpu: 3.0% command: chrome pid: 8474 mem: 666.2 MiB (1.0%)
  Memory top: 5 of 373
  1: mem: 693.0 MiB (1.1%) command: chrome pid: 5909 cpu: 4.1%
  2: mem: 667.7 MiB (1.0%) command: plasmashell pid: 1385 cpu: 0.1%
  3: mem: 666.2 MiB (1.0%) command: chrome pid: 8474 cpu: 3.0%
  4: mem: 400.2 MiB (0.6%) command: chrome pid: 5964 cpu: 3.6%
  5: mem: 355.6 MiB (0.5%) command: systemsettings pid: 2911 cpu: 0.2%
  Processes: 373 Power: uptime: 12h 48m states: freeze,mem,disk
    suspend: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 24.22 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.38
It is there, but module is not loaded.
Seems you did not reboot the last 12 hours:
A kernel upgrade always needs a reboot.
I rebooted a couple of times last night and then went to sleep. I can reboot once more.
No sure if I need that package or something else but it lead me to this:
sudo dmesg | grep -i firmware         ✔  4s 
[    0.379905] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.978201] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: DF4E63B6-3BBC-4858-9737-C74F82F821F3 has zero instances
[    0.978225] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: 8F1F6436-9F42-42C8-BADC-0E9424F20C9A has zero instances
[    2.383817] [drm] Loading DMUB firmware via PSP: version=0x08004E00
[    2.384154] [drm] Found VCN firmware Version ENC: 1.23 DEC: 9 VEP: 0 Revision: 15
[    4.749040] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    5.192824] tee tee0: Direct firmware load for /amdtee/f29bb3d9-bd66-5441-afb88acc2b2b60d6.bin failed with error -2
[    5.192831] failed to load firmware /amdtee/f29bb3d9-bd66-5441-afb88acc2b2b60d6.bin
[    5.341429] rtw89_8852ce 0000:01:00.0: loaded firmware rtw89/rtw8852c_fw-1.bin
[    5.342956] rtw89_8852ce 0000:01:00.0: Firmware version 0.27.125.0 (526f84c0), cmd version 0, type 1
[    5.342961] rtw89_8852ce 0000:01:00.0: Firmware version 0.27.125.0 (526f84c0), cmd version 0, type 3
[    5.784725] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: Firmware: 400a4 vendor: 0x2 v0.65.0, 2 algorithms
[    5.871559] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Firmware Loaded - Type: spk-prot, Gain: 17
[    6.328462] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: Firmware: 400a4 vendor: 0x2 v0.65.0, 2 algorithms
[    6.415887] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Firmware Loaded - Type: spk-prot, Gain: 17
[41881.804218] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: DSP1: Firmware: 400a4 vendor: 0x2 v0.65.0, 2 algorithms
[41882.327753] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: DSP1: Firmware: 400a4 vendor: 0x2 v0.65.0, 2 algorithms
[41882.424472] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.1: Firmware Loaded - Type: spk-prot, Gain: 17
[41882.426347] cs35l41-hda i2c-CSC3551:00-cs35l41-hda.0: Firmware Loaded - Type: spk-prot, Gain: 17
inxi -zv8|grep uptime
  Processes: 336 Power: uptime: 6m states: freeze,mem,disk suspend: s2idle
Still no change.
Ok, you did a reboot after upgrade, right? That was not clear.
Alright…
From what I see here, is that it gets loaded… actually it should work. :thinking:
Should there not be a driver associated with the network device?
You’re using kernel version 6.12, and the device is supported by kernel versions 5.18 and newer according to the LKDDb
More
So, perhaps it is blacklisted. Please provide the output of:
ls -l /etc/modprobe.d/
ls -l / etc/modprobe.d/         1 ✘
ls: cannot access 'etc/modprobe.d/': No such file or directory
total 92
lrwxrwxrwx   1 root root     7 des  2 22:33 bin -> usr/bin
drwxr-xr-x   5 root root  4096 maí  5 13:43 boot
-rw-r--r--   1 root root 23602 nóv  4  2024 desktopfs-pkgs.txt
drwxr-xr-x  20 root root  4780 maí  6 10:18 dev
drwxr-xr-x 105 root root 12288 maí  6 10:13 etc
drwxr-xr-x   3 root root  4096 nóv 11 14:54 home
lrwxrwxrwx   1 root root     7 des  2 22:33 lib -> usr/lib
lrwxrwxrwx   1 root root     7 des  2 22:33 lib64 -> usr/lib
drwx------   2 root root 16384 nóv 11 14:53 lost+found
drwxr-xr-x   2 root root  4096 apr  8  2024 mnt
drwxr-xr-x   9 root root  4096 nóv 13 09:10 opt
dr-xr-xr-x 403 root root     0 maí  6 10:13 proc
drwxr-xr-x   9 root root  4096 feb  3 13:23 root
-rw-r--r--   1 root root  5593 nóv  4  2024 rootfs-pkgs.txt
drwxr-xr-x  34 root root   840 maí  6 10:18 run
lrwxrwxrwx   1 root root     7 des  2 22:33 sbin -> usr/bin
drwxr-xr-x   4 root root  4096 nóv  4  2024 srv
dr-xr-xr-x  13 root root     0 maí  6 10:25 sys
drwxrwxrwt  16 root root   480 maí  6 10:25 tmp
drwxr-xr-x   9 root root  4096 maí  5 13:43 usr
drwxr-xr-x  12 root root  4096 maí  5 20:19 var
Was corrected :arrow_down:
Sorry, should have spotted that. This is the outcome:
total 0
Please provide this:
sudo lspci -vvv -kkk -s 01:00.0
for more details…
01:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8852CE PCIe 802.11ax Wireless Network Controller (rev 01)
        Subsystem: Hewlett-Packard Company Device 88e5
        Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Interrupt: pin A routed to IRQ 42
        IOMMU group: 12
        Region 0: I/O ports at a000 [size=256]
        Region 2: Memory at 94c00000 (64-bit, non-prefetchable) [size=1M]
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
                Address: 0000000000000000  Data: 0000
        Capabilities: [70] Express (v2) Endpoint, IntMsgNum 0
                DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <4us, L1 <64us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75W TEE-IO-
                DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
                        RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
                        MaxPayload 256 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr+ TransPend-
                LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <2us, L1 <64us
                        ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM L1 Enabled; RCB 64 bytes, LnkDisable- CommClk+
                        ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x1
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Not Supported, TimeoutDis+ NROPrPrP- LTR+
                         10BitTagComp- 10BitTagReq- OBFF Via message/WAKE#, ExtFmt- EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
                         AtomicOpsCtl: ReqEn-
                         IDOReq- IDOCompl- LTR+ EmergencyPowerReductionReq-
                         10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
                LnkCap2: Supported Link Speeds: 2.5-5GT/s, Crosslink- Retimer- 2Retimers- DRS-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [100 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
                        ECRC- UnsupReq- ACSViol- UncorrIntErr- BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
                        PoisonTLPBlocked- DMWrReqBlocked- IDECheck- MisIDETLP- PCRC_CHECK- TLPXlatBlocked-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
                        ECRC- UnsupReq- ACSViol- UncorrIntErr+ BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr- CorrIntErr- HeaderOF-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+ CorrIntErr+ HeaderOF+
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [148 v1] Device Serial Number 00-e0-4c-ff-fe-c8-52-01
        Capabilities: [158 v1] Latency Tolerance Reporting
                Max snoop latency: 1048576ns
                Max no snoop latency: 1048576ns
        Capabilities: [160 v1] L1 PM Substates
                L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
                          PortCommonModeRestoreTime=30us PortTPowerOnTime=60us
                L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+
                           T_CommonMode=0us LTR1.2_Threshold=186368ns
                L1SubCtl2: T_PwrOn=150us
        Capabilities: [170 v1] Vendor Specific Information: ID=0002 Rev=4 Len=100 <?>
        Kernel modules: rtw89_8852ce
Okay, and what gives:
sudo modprobe -v rtw89_8852ce;
lsmod | grep rtw;
lspci -k -s 01:00.0;
rtw89_8852ce           12288  0
rtw89_8852c           946176  1 rtw89_8852ce
rtw89_pci             118784  1 rtw89_8852ce
rtw89_core           1044480  2 rtw89_pci,rtw89_8852c
mac80211             1638400  2 rtw89_core,rtw89_pci
cfg80211             1396736  3 rtw89_core,mac80211,rtw89_8852c
rfkill                 40960  8 hp_wmi,rtw89_core,bluetooth,cfg80211
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Phoenix Dummy Host Bridge
Sorry, typo…
No worries!
That is somewhat strange…
Source seems to be the same in lwfinger and linux sources… I thought there is maybe a problem with detection of the device… maybe it is the newer firmware…
Maybe try lw89 dkms module?
pamac build rtw89-dkms-git
pamac build rtw89-dkms-git         ✔
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
Error: target not found: rtw89-dkms-git
pamac update --aur --force-refresh
pamac build rtw89-dkms-git        ```
