I’m using karnel 5.12.9-1 and can’t activate the wifi, I’ve been looking for a way to solve it but nothing is working please help me
Host: ferdian-aspire4752 Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Type: Laptop System: Acer product: Aspire 4752 v: V2.17
serial: <superuser required>
Mobo: Acer model: Aspire 4752 v: V2.17 serial: <superuser required> UEFI: Phoenix
v: 2.17 date: 02/14/2012
Info: Dual Core model: Intel Core i3-2330M bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L2: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17567
Speed: 798 MHz min/max: 800/2200 MHz Core speeds (MHz): 1: 798 2: 943 3: 816
4: 816
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0116
Device-2: Sunplus Innovation 1.3M HD WebCam type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 1bcf:288a
loaded: modesetting alternate: fbdev,vesa resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.2.3
compat-v: 3.0 direct render: Yes
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Device-1: Qualcomm Atheros AR9287 Wireless Network Adapter
vendor: Foxconn T77H167.00 driver: ath9k v: kernel bus-ID: 02:00.0
chip-ID: 168c:002e
IF: wlp2s0 state: down mac: 52:ff:13:66:3d:ce
Device-2: Broadcom NetLink BCM57785 Gigabit Ethernet PCIe
vendor: Acer Incorporated ALI driver: tg3 v: kernel port: N/A bus-ID: 03:00.0
chip-ID: 14e4:16b5
IF: enp3s0f0 state: down mac: 20:6a:8a:55:c7:f4
IF-ID-1: enp0s26u1u2 state: unknown speed: N/A duplex: N/A mac: 92:d4:e1:ab:a8:2c
Device-1: OPPO Android type: USB driver: rndis_host v: kernel bus-ID: 1-1.2:9
chip-ID: 22d9:276a
Local Storage: total: 577.55 GiB used: 137.99 GiB (23.9%)
ID-1: /dev/sda vendor: V-Gen model: 08AS19FS120IT size: 111.79 GiB speed: 6.0 Gb/s
serial: SCRW19082705G0401
ID-2: /dev/sdb vendor: Seagate model: ST9500325AS size: 465.76 GiB speed: 3.0 Gb/s
serial: S2W3FGMK
ID-1: / size: 109.47 GiB used: 51.05 GiB (46.6%) fs: ext4 dev: /dev/sda1
ID-2: /boot/efi size: 188 MiB used: 5 MiB (2.7%) fs: vfat dev: /dev/sdb4
System Temperatures: cpu: 70.0 C mobo: 53.0 C
Processes: 206 Uptime: 2h 40m Memory: 5.62 GiB used: 2.51 GiB (44.6%)
Init: systemd v: 249 Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1414
pacman: 1404 snap: 10 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
