inxi -F:
Host: hpnotebook Kernel: 5.10.52-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Type: Laptop System: Hewlett-Packard product: HP Notebook
v: Type1ProductConfigId serial: <superuser required>
Mobo: Hewlett-Packard model: 80C2 v: 96.02 serial: <superuser required>
UEFI: Insyde v: F.02 date: 03/24/2015
ID-1: BAT1 charge: 30.9 Wh (100.0%) condition: 30.9/41.4 Wh (74.7%)
Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP cache:
L2: 3 MiB
Speed: 2379 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 2379 2: 2464
3: 2388 4: 2396
Device-1: Intel HD Graphics 5500 driver: i915 v: kernel
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
driver: radeon v: kernel
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,intel,radeon
unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.1.5
Device-1: Intel Broadwell-U Audio driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 14.2 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <>
Device-2: Broadcom BCM43142 802.11b/g/n driver: wl
IF: wlp4s0 state: dormant mac:<>
IF-ID-1: pan1 state: down mac: <>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
bt-service: enabled,running rfk-block: hardware: no software: yes
address: <>
Local Storage: total: 931.51 GiB used: 24.33 GiB (2.6%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
ID-1: / size: 103.71 GiB used: 24.23 GiB (23.4%) fs: ext4 dev: /dev/sda8
ID-2: /boot/efi size: 256 MiB used: 104 MiB (40.6%) fs: vfat
dev: /dev/sda2
ID-1: swap-1 type: partition size: 2 GiB used: 1 MiB (0.0%) dev: /dev/sda7
System Temperatures: cpu: 50.5 C mobo: N/A gpu: radeon temp: 50.0 C
Processes: 206 Uptime: 2h 6m Memory: 3.75 GiB used: 2.61 GiB (69.4%)
Shell: Bash inxi: 3.3.06
When I try to connect to the wifi on my router through my laptop it repeateadly asks for password and doesnt connect. Sometimes it connects to the wifi and I am able to access the internet but randomly disconnects and asks for password. Ethernet works. This is probably not a driver issue as my laptop connects seamlessly to other wifi devices like mobile hotspot without any issue.
I have tried removing the network in ‘advanced network configuration’ application in xfce. Same problem persists.
Thanks
