I have installed Manjaro - “manjaro-xfce-21.0.7-210614-linux510” recently in my HP - 250 G3 laptop.
I haven’t installed any additional drivers. It’s just clean Manjaro system with default options and newest kernel.
I can’t enable Wifi. The Wifi checkbox is unclickable.
I have tried to plug USB Wifi adapter, but the results were poor. The Wifi connection still did not exist.
Is there any chance to get internal network card to work properly? If it’s impossible, could you help me to establish connection using usb Wifi dongle?
USB network adapter: TP-LINK TL-WN722N v.1 (Atheros AR9271)
Internal network adapter: Ralink RT3290
Here are the outputs of a few commands (USB adapter plugged in, without ethernet connection):
inxi -F
> System:
> Host: user-hp250g3notebookpc Kernel: 5.10.42-1-MANJARO x86_64 bits: 64
> Desktop: Xfce 4.16.0 Distro: Manjaro Linux
> Machine:
> Type: Laptop System: Hewlett-Packard product: HP 250 G3 Notebook PC
> v: 096C100000405F00050660181 serial: <superuser required>
> Mobo: Hewlett-Packard model: 2213 v: 57.26 serial: <superuser required>
> UEFI: Insyde v: F.18 date: 05/21/2014
> Battery:
> ID-1: BAT1 charge: 24.4 Wh (93.5%) condition: 26.1/31.0 Wh (84.1%)
> CPU:
> Info: Dual Core model: Intel Celeron N2830 bits: 64 type: MCP cache:
> L2: 1024 KiB
> Speed: 500 MHz min/max: 500/2416 MHz Core speeds (MHz): 1: 500 2: 500
> Graphics:
> Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
> driver: i915 v: kernel
> Device-2: Cheng Uei Precision Industry (Foxlink) HP Webcam type: USB
> driver: uvcvideo
> Display: x11 server: X .Org 1.20.11 driver: loaded: intel
> unloaded: modesetting resolution: 1366x768~60Hz
> OpenGL: renderer: Mesa DRI Intel HD Graphics (BYT) v: 4.2 Mesa 21.1.2
> Audio:
> Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio
> driver: snd_hda_intel
> Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
> Sound Server-2: PulseAudio v: 14.2 running: yes
> Network:
> Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
> IF: wlp2s0f0 state: down mac: 8b:4c:8a:4a:c4:4d
> Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
> IF: enp4s0 state: down mac: 7a:c4:87:c9:5a:83
> Device-3: Qualcomm Atheros AR9271 802.11n type: USB driver: ath9k_htc
> IF: wlp0s20u2 state: down mac: c4:f9:a0:b5:8a:a1
> Bluetooth:
> Device-1: Ralink RT3290 Bluetooth driver: N/A
> Report: This feature requires one of these tools: hciconfig/bt-adapter
> Drives:
> Local Storage: total: 465.76 GiB used: 6.69 GiB (1.4%)
> ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
> Partition:
> ID-1: / size: 449 GiB used: 6.69 GiB (1.5%) fs: ext4 dev: /dev/sda2
> ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
> dev: /dev/sda1
> Swap:
> ID-1: swap-1 type: partition size: 8.21 GiB used: 0 KiB (0.0%)
> dev: /dev/sda3
> Sensors:
> System Temperatures: cpu: 41.0 C mobo: 36.0 C
> Fan Speeds (RPM): N/A
> Info:
> Processes: 155 Uptime: 4m Memory: 3.73 GiB used: 827.8 MiB (21.7%)
> Shell: Bash inxi: 3.3.05
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
After I press F12 something changes. It might be some issue with F12/airplane mode button, but it doesn’t help anything.>
Soft blocked: yes
Hard blocked: yes
Soft blocked: no
Hard blocked: no
sudo dmesg | grep iwlwifi
Nothing found…
