Hi there,
I face the same problem as testingcont (2 years ago: /t/wifi-available-but-not-working/42720).
I mean my chipset is the same. Except that:
- my PC is an HP ProBook 6460b ;
- solution suggested in comment 21 (/t/wifi-available-but-not-working/42720/21) - that had solved testingcont’s issue - didn’t work in my case.
(so at the moment, I still have file /etc/modprobe.d/iwlwifi.conf present, with the same suggested contents)
Here are a few indications from journalctl around driver iwlwifi:
23:26:28 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: can't disable ASPM; OS doesn't have ASPM control
23:26:28 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: loaded firmware version 18.168.6.1 6000g2a-6.ucode op_mode iwldvm
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEBUG enabled
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: Detected Intel(R) Centrino(R) Advanced-N 6205 AGN, REV=0xB0
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: reporting RF_KILL (radio disabled)
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: RF_KILL bit toggled to disable radio.
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0 wlo1: renamed from wlan0
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: RF_KILL bit toggled to enable radio.
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: reporting RF_KILL (radio enabled)
23:26:29 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
23:26:30 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: Radio type=0x1-0x2-0x0
23:26:30 HP-ProBook-6460b NetworkManager[332]: <info> [1675895190.3566] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.3/0000:24:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
23:26:34 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: RF_KILL bit toggled to disable radio.
23:26:34 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: reporting RF_KILL (radio disabled)
23:26:34 HP-ProBook-6460b kernel: iwlwifi 0000:24:00.0: Not sending command - RF KILL
Just as for testingcont, there was no problem using the WiFi on this PC with a previous Linux Mint 20 installation. So I don’t get what’s going wrong with Manjaro…
I have a physical WiFi toggle which is lighted (switched ON) by default at boot. However, KDE’s software WiFi toggle is greyed out.
rfkill command shows WLAN is hard blocked.
$ rfkill
ID TYPE DEVICE SOFT **HARD**
1 **wlan** phy0 débloqué **bloqué**
7 bluetooth hci0 débloqué débloqué
What may be causing this?
Any help would be greatly appreciated (as you can imagine ^^). Thanks!
