Trying to use fresh manjaro install on Acer Aspire laptop, but Wi-Fi card isn’t showing up, only ethernet adapter. Wi-Fi worked when it was using windows, so I’m not sure what’s happened.
Hi @LavaLamp ,
Welcome to the forum. Please run the following command on the terminal and post the output in formatted mode (with three backstick before and after the`text ( ```), in order to help you.
ìnxi -Fazy
Regards,
