Hi there, i just installed Manjaro.
I wanted to use WiFi, but as i found out, my WiFi-card is not recognized.
nmcli device status yields:
DEVICE TYPE STATE CONNECTION
enp34s0 ethernet connected Kabelgebundene Verbindung 1
lo loopback unmanaged --
But as you can see in the specs, the card is showing up, but not as giving a wlan-connection.
That is weird, because Bluetooth works fine.
I tried updating the driver with: www . intel . de/content/www/de/de/support/articles/000005511/wireless.html
As it was suggested in this thread with a similar topic: archived . forum . manjaro . org/t/intel-8260-wifi-no-network-connections-after-recent-update/128360/6
(Just remove the spaces between the dots)
But it did not work.
How should I proceed?
Here are the specs:
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=30a41124-dcbc-4907-af8a-98b026724fbf rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.60
date: 12/30/2019
RAM: total: 15.63 GiB used: 1.6 GiB (10.2%)
RAM Report:
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701013
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2379 high: 3597 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3532 2: 2058
3: 2056 4: 2199 5: 2200 6: 2199 7: 3597 8: 2053 9: 2058 10: 2200 11: 2200
12: 2199 bogomips: 86439
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Gigabyte
driver: nouveau v: kernel bus-ID: 26:00.0 chip-ID: 10de:1f06 class-ID: 0300
Device-2: Realtek EKACOM-K20E type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-1:2 chip-ID: 0bda:5696 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Device-1: NVIDIA TU106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 26:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Realtek EKACOM-K20E type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 21:00.0
chip-ID: 8086:2526 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-8:3 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.4 TiB used: 8.73 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Leven model: JAJS600M128C
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 5A0 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%) used: 8.73 GiB (7.5%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 30a41124-dcbc-4907-af8a-98b026724fbf
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 0217-FF60
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs
label: Wiederherstellung uuid: F6DE6266DE621EDD
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 2E62-BA88
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 476.31 GiB fs: ntfs label: N/A
uuid: 8092652E926529BC
ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-6: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: HDD
uuid: B028A3A628A36A54
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-7:2 info: SteelSeries ApS SteelSeries Rival 3 type: Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 400mA chip-ID: 1038:184c class-ID: 0300
Device-2: 1-8:3 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Device-3: 1-10:4 info: SteelSeries ApS SteelSeries QCK Prism Cloth
type: HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 350mA chip-ID: 1038:150d class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Realtek EKACOM-K20E type: Video,Audio
power: 500mA chip-ID: 0bda:5696 class-ID: 0102 serial: <filter>
Device-2: 5-4:3 info: SteelSeries ApS SteelSeries Apex 5
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 5 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1038:161c class-ID: 0300
Hub-6: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nouveau temp: 23.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 946
Processes: 276 Uptime: 6m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1073 lib: 314 flatpak: 0 Shell: Bash
v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
