Wifi card doesn't connect
I have an Apple MacBook Pro and wifi card isn’t working. I’ve done sudo -Syyu and it says nothing to do.
In Manjaro Settings Manager, under hardware configuration it says I have a “BCM42602 802.11 ac Wireless LAN SoC (Broadcom)”. I will also say I cant’ do anything with that, but maybe I don’t know how to right click in Manjaro.
Symptom: can’t connect to multiple wifi access points. It says that the password is incorrect. The password is correct.
As a new or infrequent forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
inxi --filter --verbosity=8
inxi -zv8
Thanks, here’s the results
  Kernel: 6.12.64-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=841ea4ac-b34c-48b3-af62-eeb39e025524 rw rootflags=subvol=@
    quiet splash resume=UUID=e650dca3-413d-4b7a-a4b0-df255f3648c5
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Laptop System: Apple product: MacBookPro13,3 v: 1.0
    serial: <superuser required> Chassis: type: 9 v: Mac-A5C67F76ED83108C
  Mobo: Apple model: Mac-A5C67F76ED83108C v: MacBookPro13,3
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: Apple v: 529.120.1.0.0 date: 03/14/2024
  ID-1: BAT0 charge: 9.1 Wh (17.1%) condition: 53.4/76.6 Wh (69.7%)
    temp: 38.1 C volts: 12.11 min: 11.49 model: SMP bq20z451 type: Li-ion
    serial: N/A charging: status: charging cycles: 697
  Device-1: apple_mfi_fastcharge_1-2 model: N/A serial: N/A charge: N/A
    status: N/A
  System RAM: total: 16 GiB available: 15.52 GiB used: 2.71 GiB (17.5%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: 0x802C part-no: 0x4D5435324C31473332443450472D30393320
    serial: <filter>
  Device-2: DIMM0 type: LPDDR3 detail: synchronous size: 8 GiB
    serial: <filter>
  Info: model: Intel Core i7-6920HQ bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3493 min/max: 800/3800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3493 2: 3493 3: 3493 4: 3493 5: 3493 6: 3493
    7: 3493 8: 3493 bogomips: 46419
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: Intel HD Graphics 530 vendor: Apple driver: i915 v: kernel
    arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: none
    empty: DP-5, DP-6, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:191b
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Baffin [Radeon RX 460/560D /
    Pro 450/455/460/555/555X/560/560X] vendor: Apple driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 8 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 01:00.0 chip-ID: 1002:67ef
    class-ID: 0300 temp: 57.0 C
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
    alternate: fbdev,vesa dri: radeonsi,iris gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Apple Color LCD built: 2015 res: mode: 2880x1800
    hz: 60 scale: 145% (1.45) to: 1986x1241 dpi: 221 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.322 green: x: 0.263 y: 0.690 blue: x: 0.149 y: 0.051 white:
    x: 0.310 y: 0.329 size: 331x207mm (13.03x8.15") diag: 390mm (15.4")
    ratio: 16:10 modes: 2880x1800, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
    drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
    surfaceless: drv: iris wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX Graphics (radeonsi
    polaris11 ACO DRM 3.61 6.12.64-1-MANJARO) device-ID: 1002:67ef
    memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 2 device: 0 type: discrete-gpu name: AMD
    Radeon RX Graphics (RADV POLARIS11) driver: mesa radv v: 25.3.3-arch1.1
    device-ID: 1002:67ef surfaces: N/A device: 1 type: integrated-gpu
    name: Intel HD Graphics 530 (SKL GT2) driver: mesa intel v: 25.3.3-arch1.1
    device-ID: 8086:191b surfaces: N/A
  Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a170
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon
    RX 550 640SP / 560/560X] driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
  API: ALSA v: k6.12.64-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
    driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 03:00.0 chip-ID: 14e4:43ba class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:8153
    class-ID: 0000 serial: <filter>
  IF: enp0s20f0u5 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 931.84 GiB used: 12 GiB (1.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD SM1024L
    size: 931.84 GiB block-size: physical: 4096 B logical: 4096 B
    speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: CXS6AA0Q
    temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 914.48 GiB size: 914.48 GiB (100.00%) used: 12 GiB (1.3%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 841ea4ac-b34c-48b3-af62-eeb39e025524
  ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
    used: 640 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 7408-0167
  ID-3: /home raw-size: 914.48 GiB size: 914.48 GiB (100.00%)
    used: 12 GiB (1.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  ID-4: /var/cache raw-size: 914.48 GiB size: 914.48 GiB (100.00%)
  ID-5: /var/log raw-size: 914.48 GiB size: 914.48 GiB (100.00%)
  ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: e650dca3-413d-4b7a-a4b0-df255f3648c5
  Device-1: 1-3:2 info: Apple Apple Mobile Device [Recovery Mode]
    type: <vendor specific> driver: N/A interfaces: 2 rev: 2.0
    chip-ID: 05ac:1281 class-ID: fe01 serial: <filter>
  Device-2: 1-5:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: amdgpu temp: 58.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1256 libs: 336 tools: pamac pm: flatpak pkgs: 0
    1: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    8: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    12: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    16: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 306
  1: cpu: 11.6% command: firefox pid: 1661 mem: 769.6 MiB (4.8%)
  2: cpu: 6.9% command: kwin_wayland pid: 851 mem: 322.2 MiB (2.0%)
  3: cpu: 3.4% command: firefox pid: 2008 mem: 359.2 MiB (2.2%)
  4: cpu: 1.4% command: firefox pid: 13061 mem: 307.6 MiB (1.9%)
  5: cpu: 1.2% command: firefox pid: 1841 mem: 269.4 MiB (1.6%)
  Memory top: 5 of 306
  1: mem: 769.6 MiB (4.8%) command: firefox pid: 1661 cpu: 11.6%
  2: mem: 536.8 MiB (3.3%) command: plasmashell pid: 1072 cpu: 0.9%
  3: mem: 359.2 MiB (2.2%) command: firefox pid: 2008 cpu: 3.4%
  4: mem: 322.2 MiB (2.0%) command: kwin_wayland pid: 851 cpu: 6.9%
  5: mem: 317.7 MiB (1.9%) command: firefox pid: 11235 cpu: 1.2%
  Processes: 306 Power: uptime: 56m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40```
Thanks for replying with the system information, however it is not easy to read due to it being incorrectly formatted. Please edit your post by clicking the :pen: icon at the bottom of it.
Pre-prepared instructions below for formatting terminal output as code are below:
Note that any code or command output (such as inxi output) should be placed within a scrollable pre-formatted text enclosure according to forum guidelines.
See here for instructions: :point_down:
[MiniHowTo] Present code or command output
  • for example, typing: `code here` will display the text as code here.
What is a Quark?
edited. thanks for the note.
The output you posted shows that at least it is detected and a driver binds to it. Can you clarify if there are any access points that you can connect to? And this is a regression, and things have worked in the past? Furthermore, if possible, you should try creating an open wifi network with your phone and check if you can connect to that. Another thing you can try is starting sudo journalctl -f, then try to connect to a network while you leave the command running, there might be an error message or such related to why the connection fails.
Sorry I didn’t start with that. I installed Manjaro on this laptop for the first time today after using it for years on a headless server. I tried multiple access points (my wifi, my phone) and multiple people entering the password, and reading it back. I’m sure that’s not the problem.
Your suggestion to check the journal gave me something to go on (dates removed)
wlp3s0: WPS-CANCEL
MBO: Disable MBO/OCE due to misbehaving AP not having enabled PMF
wlp3s0: Trying to associate with SSID anSSID
Hi @pdb ,
I wonder whether you could read this post, in order to solve the problem.
‘WIFI problem after latest update - #7 by megavolt’
You could also search any other posts in the forum:
‘Search results for 'BCM43602' - Manjaro Linux Forum’
Hope it help, regards
Searching Laptop/Apple - ArchWiki for your specific device
I was quite surprised to to see the apple firmware being as new as it is.
I have a Intel (no amd) macbook pro 2017 which is no longer in support from Apple.
Please see here for advise related to Broadcom wireless - ArchWiki as this will be valid for Manjaro as well.
