Might not work for you, but my Intel Wifi card is also missing on various kernels.
Workaround I found by mistake: Boot into UEFI/BIOS and turn off your ethernet
Would be interested if this works for you and returns your wifi on a Realtek RTL card. That would implicate a much different set of kernels and headers.
See the Configuration section of [HowTo] Install Manjaro on the ASUS TUF FX505DY / FX705DY with Ryzen / Radeon combo. It’s a known/common problem with that WiFi adapter. If you have the means (money and your computer/notebook allows), I’d suggest swapping it out. I have the notebook that post was written for, and I followed the author’s advice and replaced the WiFi adapter and saw about a 30% improvement in throughput.
