I tried all the solutions that i know to solve the problem. Tried to set a channel to the wifi, turned off wifi power save and all. I noticed that sometimes my wifi speed up with turned on bluetooth. But whenever i play music with my bluetooth device wifi becomes too slow.
I will share the details below:-
nmcli device wifi list
IN-USE BSSID SSID MODE CHAN RATE SIGNAL BARS >
* EC:79:F2:05:5E:DF XPON Infra 7 270 Mbit/s 87 ▂▄▆█
inxi -Fazy
Kernel: 5.16.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.16-x86_64
root=UUID=fc2e3534-fcf8-40a3-af0e-283bdf105cc9 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.33 info: plank vt: 7
Type: Laptop System: ASUSTeK product: X542UQR v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: X542UQR v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X542UQR.309 date: 05/21/2019
ID-1: BAT0 charge: 20.5 Wh (93.6%) condition: 21.9/38.0 Wh (57.7%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 879
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 724 high: 800 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 700 2: 745 3: 800 4: 751
5: 700 6: 700 7: 700 8: 700 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nouveau
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:134d class-ID: 0302
Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.9") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: BOE Display built: 2015 res: 1920x1080 dpi: 142
gamma: 1.2 size: 344x193mm (13.5x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.16.14-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: d000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0036 class-ID: 0280
IF-ID-1: pan1 state: down mac: <filter>
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-8:7
chip-ID: 04ca:3018 class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 2 state: down
bt-service: disabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 1.82 TiB used: 140.58 GiB (7.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-1: / raw-size: 192.57 GiB size: 192.57 GiB (100.00%)
used: 23.39 GiB (12.1%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /boot/efi raw-size: 320.7 MiB size: 320 MiB (99.80%)
used: 568 KiB (0.2%) fs: vfat dev: /dev/sdb3 maj-min: 8:19
ID-3: /home raw-size: 738.63 GiB size: 738.63 GiB (100.00%)
used: 117.19 GiB (15.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-4: /var/log raw-size: 192.57 GiB size: 192.57 GiB (100.00%)
System Temperatures: cpu: 43.0 C pch: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 340 Uptime: 3h 45m wakeups: 3 Memory: 7.65 GiB
used: 3.02 GiB (39.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1342 lib: 384 flatpak: 0
Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.13
Checked the power management and it is turned off.
iwconfig
lo no wireless extensions.
enp2s0 no wireless extensions.
wlp3s0 IEEE 802.11 ESSID:"XPON"
Mode:Managed Frequency:2.442 GHz Access Point: EC:79:F2:05:5E:DF
Bit Rate=150 Mb/s Tx-Power=16 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-35 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:75 Missed beacon:0
pan1 no wireless extensions.
But whenever i play something in my bluetooth device there is some change in the above output.
iwconfig
Bit Rate=135 Mb/s Tx-Power=16 dBm
Link Quality=59/70 Signal level=-51 dBm
Tx excessive retries:1 Invalid misc:289 Missed beacon:0
I set a channel for wifi and it didnt help,
iwlist wlp3s0 frequency
wlp3s0 13 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Current Frequency:2.442 GHz (Channel 7)
I think the problem is with Network manager or my driver configuration. Sadly i dont know how to fix it.
I have two files in the /etc/modeprobe folder. 8821cu.conf, for my usb adapter, and a iwlwifi.conf file.
my iwlwifi.conf file is configured as:-
options iwlwifi bt_coex_active=0 swcrypto=1 11n_disable=1
Hope these outputs will help you to guide me.
