Hi! I’m new to linux and just installed Manjaro 20.2 and I can’t figure why the wifi isn’t working, but the ethernet works fine
Host: victor-PC Kernel: 5.9.11-3-MANJARO x86_64 bits: 64
Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 2350A26 v: ThinkPad T430
serial: <superuser/root required>
Mobo: LENOVO model: 2350A26 serial: <superuser/root required>
UEFI [Legacy]: LENOVO v: G1ETC2WW (2.82 ) date: 08/07/2019
ID-1: BAT0 charge: 5.4 Wh condition: 5.5/94.0 Wh (6%)
Info: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 1264 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197
2: 1338 3: 1197 4: 1197
Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Device-2: Chicony thinkpad t430s camera type: USB driver: uvcvideo
Display: x11 server: X. Org 1.20.10 driver: intel unloaded: modesetting
resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
v: 4.2 Mesa 20.2.3
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel 82579LM Gigabit Network driver: e1000e
IF: enp0s25 state: up speed: 100 Mbps duplex: full
mac: 00:21:cc:ce:ec:59
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
IF: wlp3s0 state: down mac: f2:c3:ab:6c:01:d7
Local Storage: total: 494.88 GiB used: 38.90 GiB (7.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB
ID-2: /dev/sdb type: USB vendor: Transcend
model: JetFlash Transcend 32GB size: 29.12 GiB
ID-1: / size: 457.45 GiB used: 15.92 GiB (3.5%) fs: ext4
dev: /dev/sda1
ID-1: swap-1 type: file size: 512.0 MiB used: 1.2 MiB (0.2%)
file: /swapfile
System Temperatures: cpu: 51.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3773
Processes: 207 Uptime: 1h 32m Memory: 11.41 GiB used: 1.97 GiB (17.2%)
Shell: Bash inxi: 3.1.08
probably an exotic wireless adapter
j8a
13 December 2020 19:18
4
Hi @testingcont ,
Can you execute the terminal command inxi -FN and put the output in the post?
In order to help you we must know something about the wifi adapter.
Hope it help, regards.
j8a
13 December 2020 21:28
7
Hi, @testingcont ,
Your wifi is down, although is present.
You can check whether is blocked or not with the following terminal command:
sudo rfkill list all.
I also suggest you to look at this couple of post, in order to try to solve your problem.
‘Wireless Connection randomly disconnects, restart is required - #12 by TriMoon ’
‘Wifi shows its connected for 5Ghz radio but will not resolve an address, but connecting with 2.4Ghz Radio always works - #2 by megavolt ’
Hey! Doesn’t seem to be blocked, but the wifi works on both windows and Linux Mint
Try:
sudo systemctl restart NetworkManager
nmcli networking on
Same thing, only now it shows “limited connectivity”
Could you also post the vendor and ID (chip ID)? Without it, it would really hard to find any possible solution if that one is really exotic…
inxi -Nazy
testingcont:
ThinkPad T430
A Thinkpad has a wifi toggle Fn F8 .
Also check in the firmware if wifi-card is enabled.
There is specific power modules for Thinkpad is in the repo - so you should check your power settings both within KDE but also tlp . Install tlpui
to get a GUI overview over the settings.
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 6080 bus ID: 00:19.0 chip ID: 8086:1502
v: kernel port: efa0 bus ID: 03:00.0 chip ID: 8086:0085
ok @testingcont , at least the wifi is not exotic and should work:
I guess there is more investigation needed then…
Could you run:
journalctl -f
and then try to connect? Any useful information in the log?
Quite a lot.
– Logs begin at Sun 2020-12-13 20:01:43 EET. –
Dec 14 15:07:01 victor-PC dolphin[5497]: kf.kio.core: “Can’t load /etc/samba/smb.conf - run testparm to debug it\n”
Dec 14 15:07:03 victor-PC kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22864, resource id: 90177547, major code: 18 (ChangeProperty), minor code: 0
Dec 14 15:07:03 victor-PC kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22879, resource id: 75497489, major code: 18 (ChangeProperty), minor code: 0
Dec 14 15:07:03 victor-PC systemd[1050]: app-org.kde.dolphin-fb7d1723ba524e4fba59e42cbc7ee9e2.scope: Succeeded.
Dec 14 15:07:03 victor-PC kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 22894, resource id: 35651876, major code: 18 (ChangeProperty), minor code: 0
Dec 14 15:07:05 victor-PC plasmashell[1182]: trying to show an empty dialog
Dec 14 15:07:07 victor-PC systemd[1050]: Started Konsole - Terminal.
Dec 14 15:07:07 victor-PC kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24488, resource id: 12582925, major code: 18 (ChangeProperty), minor code: 0
Dec 14 15:07:08 victor-PC kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24896, resource id: 16796128, major code: 3 (GetWindowAttributes), minor code: 0
Dec 14 15:07:08 victor-PC kwin_x11[1136]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 24897, resource id: 16796128, major code: 14 (GetGeometry), minor code: 0
Dec 14 15:07:15 victor-PC kwin_x11[1136]: file:///usr/lib/qt/qml/org/kde/plasma/components/Highlight.qml:34:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. U
se this syntax instead: function onFoo() { … }
I also tried to follow this guide:this
and when I tried
/etc/modprobe.d/iwlwifi.conf
the file doesn’t exist.
testingcont:
You need to create that text file.
Can you help in more details how do I do that?
Just a blank text file? What would that accomplish?
Of course with content xD
Your can try some other options like:
options iwlwifi 11n_disable=1 swcrypto=1
https://wiki.archlinux.org/index.php/Network_configuration/Wireless#iwlwifi
More information with:
modinfo iwlwifi
testingcont:
Sorry, I’m really trying to learn. What content should it have?
ok… open nano and create a new file:
sudo nano /etc/modprobe.d/iwlwifi.conf
then copy and paste this:
into that file and with CTRL+S you save the file. Close with CTRL+X.
Reboot…
It works . Thank you so much. Was the missing file the problem? I tried a bunch of other things
