cnvrg
9 January 2022 11:13
1
Hello there all,
I’m using Manjaro with
Linux w01 5.15.12-1-MANJARO #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021 x86_64 GNU/Linux
$ lspci
01:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
This happens only when working on battery.
When this notebook uses the wifi, like updating pacman, its suddenly turn off the screen and shutdown.
Anyone knows how to get more information ?
Pls see journal below (Pastebin)
$ inxi -fazy
Info: model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1680 high: 2626 min/max: 1400/2375 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1353 2: 1397
3: 1752 4: 1400 5: 1552 6: 2626 bogomips: 28455
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
Welcome!
This could be done by TLP . To disable wifi powersave in TLP permanently on battery you don’t have to fiddle with iwconfig or rc.local (won’t work reliable anyway).
Open the file /etc/tlp.conf as root and change on to off in TLP’s configuration instead:
WIFI_PWR_ON_BAT=off
Reboot for changes to take effect.
cscs
9 January 2022 12:51
3
I swear I documented a situation where an odd Atheros card was causing random freezes (fixable by module options) … I just cant find it…
cnvrg:
inxi -fazy
That is only a small part, and importantly, missing the sections like ‘Network’…
(maybe because of the lowercase f instead of F … I was not sure if typo)
Upstream 4 years old…
failed to fetch board data QCA6174 (narkive.com)
ene 09 07:58:01 w01 kernel: ath10k_pci 0000:01:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 11ad:0847
ene 09 07:58:01 w01 kernel: ath10k_pci 0000:01:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
ene 09 07:58:01 w01 kernel: ath10k_pci 0000:01:00.0: firmware ver WLAN.RM.4.4.1-00157-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 90eebefb
ene 09 07:58:01 w01 kernel: ath10k_pci 0000:01:00.0: failed to fetch board data for bus=pci,vendor=168c,device=003e,subsystem-vendor=11ad,subsystem-device=0847 from ath10k/QCA6174/hw3.0/board-2.bin
ene 09 07:58:01 w01 kernel: ath10k_pci 0000:01:00.0: board_file api 1 bmi_id N/A crc32 70c38a29
also
Problem loading CT ath10k firmware for QCA9984 device (PCI ID 168c:0046) · Issue #172 · greearb/ath10k-ct (github.com)
tl;dr vendors using cheap IoT with $hitty support firmware in Linux. Nihil novi.
https://www.google.com/search?q=failed+to+fetch+board+data+for+from+ath10k
This is not related self with power saving setup. This is directly kernel and firmware crap things.
TLP should be set in /etc/tlp.conf
RUNTIME_PM_DRIVER_BLACKLIST="mei_me nvidia pcieport"
anyway.
cnvrg
9 January 2022 18:01
6
I add manually. the whole file its commented.
I’m trying this config
cnvrg
9 January 2022 18:02
7
Thanks, also add to my tlp.conf
im waiting to see if crash or not
cnvrg
14 January 2022 21:31
8
thanks you all, with this configuration and an update of the firmware
( firmware-6.bin_WLAN.RM.4.4.1-00288-QCARMSWPZ-1 )
seems to be working.
Again thanks
EDIT:
The system keeps crashing (3 times today), I will start again to loop up for errors
cnvrg
25 January 2022 12:56
9
Hello there, after a upgrade of linux-firmware the wifi stop working.
So i’m using a USB with a realtek chipset.
The system keep crashing, i’m thinking on battery issues maybe or some kernel failure.
Is there any change to test the battery or maybe see if the system run out of battery from journal or dmesg?
Please create new topic issue.
