hello everyone, i just turn on my laptop today and it doenst connects to wifi or lan, im trying to fix it rebooting the computer but doesnt work.
i believe to u need my computer’s information for fix it
inxi -Fza:
System: Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=0cbaeffd-b9b5-42c9-b3e9-c95a3308ca1f rw quiet splash
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: Hewlett-Packard product: HP ProBook 4440s v: A1009D11 serial: Chassis: type: 10
serial:
Mobo: Hewlett-Packard model: 17F3 v: KBC Version 58.21 serial: BIOS: Hewlett-Packard v: 68IRR Ver. F.60
date: 01/15/2015
Battery: ID-1: BAT0 charge: 24.1 Wh (100.0%) condition: 24.1/24.1 Wh (100.0%) volts: 12.3 min: 10.8
model: Hewlett-Packard Primary type: Li-ion serial: status: Full
CPU: Info: Quad Core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge family: 6 model-id: 2A (42)
stepping: 7 microcode: 2F cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 35120
Speed: 881 MHz min/max: 800/3100 MHz Core speeds (MHz): 1: 881 2: 856 3: 861 4: 848 5: 866 6: 865 7: 887 8: 813
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116 class-ID: 0300
Device-2: Sunplus Innovation HP HD Webcam [Fixed] type: USB driver: uvcvideo bus-ID: 1-1.3:5 chip-ID: 1bcf:2c03
class-ID: 0e02
Display: x11 server: X . org 1.20.11 compositor: gnome-shell driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 21.0.2 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
Network: Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel port: 3040 bus-ID: 03:00.0 chip-ID: 8086:088e
class-ID: 0280
IF: wlo1 state: up mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac:
Bluetooth: Device-1: Intel Centrino Bluetooth Wireless Transceiver type: USB driver: btusb v: 0.8 bus-ID: 2-1.6:3
chip-ID: 8087:07da class-ID: e001
Drives: Local Storage: total: 447.13 GiB used: 35.49 GiB (7.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU650 size: 447.13 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s rotation: SSD serial: rev: 4A0 scheme: MBR
Partition: ID-1: / raw-size: 447.13 GiB size: 439.04 GiB (98.19%) used: 35.49 GiB (8.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 45.0 C mobo: 0.0 C
Info: Processes: 244 Uptime: 11m wakeups: 1 Memory: 7.66 GiB used: 1.14 GiB (14.8%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: 1476 pacman: 1466 lib: 381 flatpak: 0 snap: 10 Shell: Zsh v: 5.8
running-in: gnome-terminal inxi: 3.3.04
help plz
