So I was playing some games with my Bluetooth headset and suddenly the Bluetooth connection ended. When I was checking the Bluetooth settings I noticed that Bluetooth was entirely not working, and Wifi also was not working. I tried ethernet but that also does not work anymore.
Here’s some inxi output
inxi -Fazy
Kernel: 5.19.17-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=8fcce604-0669-4d22-b5bd-536dfb418a74 rw quiet
resume=UUID=e660a3a9-11de-47f0-88a5-6b76d91879bb udev.log_priority=3
Desktop: i3 v: 4.22 info: polybar vt: 1 dm: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
Mobo: HP model: 84AA v: 82.52 serial: <superuser required> UEFI: Insyde
v: F.36 date: 02/03/2021
Info: model: Intel Celeron N4000 bits: 64 type: MCP arch: Goldmont Plus
level: v2 built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122)
stepping: 1 microcode: 0x3E
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 796 min/max: 800/2600 scaling: driver: intel_cpufreq
governor: powersave cores: 1: 796 2: 796 bogomips: 4378
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: Hewlett-Packard
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:6 chip-ID: 0408:5362
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-982bb driver:
X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2017 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 600 (GLK
2) direct-render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
API: ALSA v: k5.19.17-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.70 status: off with: 1: pipewire-pulse
status: off 2: pipewire-media-session status: off 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtl8821ce v: N/A modules: rtw88_8821ce,8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.0
chip-ID: 10ec:c821 class-ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: br-96a17d5f9015 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:5 chip-ID: 0bda:b00a
Local Storage: total: 465.76 GiB used: 172.31 GiB (37.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 4C scheme: GPT
ID-1: / raw-size: 104 GiB size: 101.81 GiB (97.89%) used: 44.58 GiB (43.8%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 511 MiB size: 510 MiB (99.80%)
used: 160 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 353.26 GiB size: 347.15 GiB (98.27%)
used: 127.73 GiB (36.8%) fs: ext4 dev: /dev/sda9 maj-min: 8:9
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 118 Uptime: 8m wakeups: 1 Memory: available: 7.58 GiB
used: 856.4 MiB (11.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1777
pm: pacman pkgs: 1768 libs: 455 tools: pamac pm: flatpak pkgs: 9 Shell: Zsh
v: 5.9 running-in: kitty inxi: 3.3.27
