Wifi Adapter Drivers for TP-Link AC600 (rtl8811au)
I am looking to try out Manjaro having used Ubuntu for quite some time now but can’t figure out how to get wifi adapter working
I have already tried downloading rtl8812au-dkms-git from AUR as well as rtl88xxau-aircrack-dkms-git but neither seems to work
When using Ubuntu I was able to install working drivers from github using the following code but don’t know how to install on manjaro
sudo apt install git dkms
git clone https://github.com/aircrack-ng/rtl8812au.git
cd rtl8812au
sudo make dkms_install
Can somebody please explain how to make this work on Manjaro
You need the linux-headers package for your running kernel, then install the AUR package via
pamac build command
I’ve installed linux headers 419 and tried installing using pamac build but came up with this:
==> ERROR: Missing 4.19.277-1-MANJARO kernel modules tree for module rtl88xxau/r1238.eee82ac.
Did I install the wrong headers for kernel 6.1.19-1 or is something else going wrong here?
Nvm just installed linux61-headers then used pamac build to install AUR package now wifi adaptor is working perfectly. Appreciate the help @anon89812132
