Hi! I can’t use my wifi card. I bought a TP-LINK AC1300 Wireless Dual Band PCI Express Adapter Archer T6E and the system does not recognize it. The drivers disk that comes with it is only for Windows. I tried following several community instructions but none of them work. Help!!!
inxi -Fazy
lspci
once you noticed the device id, you can also get and post:
lspci -vs xx:xx.x
inxi -Fazy
Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
Desktop: GNOME v: 46.2 tk: GTK v: 3.24.42 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Gigabyte model: H510M S2H V2 v: x.x
serial: uuid: UEFI: American
Megatrends LLC. v: FA date: 11/26/2021
Info: model: 11th Gen Intel Core i5-11400 bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x5E
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 907 high: 2092 min/max: 800/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 2092 bogomips: 62232
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
** Device-1: Broadcom BCM4360 802.11ac Dual Band Wireless Network Adapter**
** driver: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1**
** bus-ID: 02:00.0 chip-ID: 14e4:43a0 class-ID: 0280**
** Device-2: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet**
** vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s**
** lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200**
** IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: **
** Info: services: NetworkManager, ntpd, wpa_supplicant**
Local Storage: total: 2.27 TiB used: 12.32 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S500G
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: fw-rev: SBI02102 temp: 32.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
tech: HDD rpm: 7200 serial: fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 12.32 GiB (2.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 35.0 C mobo: 30.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.56 GiB used: 3.21 GiB (42.5%)
Processes: 305 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.01 GiB services: gsd-power,
tool: systemctl
Packages: pm: pacman pkgs: 1201 libs: 300 tools: gnome-software,pamac,yay
pm: flatpak pkgs: 0 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
lspci
00:00.0 Host bridge: Intel Corporation Device 4c53 (rev 01)
00:02.0 VGA compatible controller: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] (rev 04)
00:14.0 USB controller: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Tiger Lake-H Shared SRAM (rev 11)
00:16.0 Communication controller: Intel Corporation Tiger Lake-H Management Engine Interface (rev 11)
00:17.0 SATA controller: Intel Corporation Device 43d2 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Tiger Lake-H PCI Express Root Port #5 (rev 11)
00:1c.6 PCI bridge: Intel Corporation Device 43be (rev 11)
00:1d.0 PCI bridge: Intel Corporation Device 43b2 (rev 11)
00:1f.0 ISA bridge: Intel Corporation H510 LPC/eSPI Controller (rev 11)
00:1f.3 Audio device: Intel Corporation Tiger Lake-H HD Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Tiger Lake-H SMBus Controller (rev 11)
00:1f.5 Serial bus controller: Intel Corporation Tiger Lake-H SPI Controller (rev 11)
01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. NV2 NVMe SSD SM2267XT (DRAM-less) (rev 03)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Dual Band Wireless Network Adapter (rev 03)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 16)
lspci -vs 02:00.0
Subsystem: Broadcom Inc. and subsidiaries Device 0619
Flags: fast devsel, IRQ 255
Memory at 51200000 (64-bit, non-prefetchable) [disabled] [size=32K]
Memory at 51000000 (64-bit, non-prefetchable) [disabled] [size=2M]
Capabilities:
Kernel modules: bcma
inxi -Fazy
root=UUID=2809a211-8374-49ad-9dea-48f1b29ef1c0 rw quiet splash apparmor=1
microcode: 0x5E
desc: 1x12 MiB
scheme: GPT
tool: systemctl
lspci
lspci -vs 02:00.0t
Capabilities:
Try this:
pamac install linux69-broadcom-wl
Make sure that you have the kernel headers installed as well.
pamac install linux69-headers
Reboot
Hi @abb ,
Welcome to the forum, as @jrichard326 pointed out your wifi driver is no what you supposed to be. Please,follow the commands to properly install the drivers and give us some feedback.
Regards,
WE MADE IT!
I started trying with the commands you told me, but encountered some issues during the process. Fortunately, chatGPT was there to help me, so i tried with other commands an it worked!
Thank you all, I really appreciate your support!
Successful Commands:
sudo pacman -Syu
sudo pacman -S yay
yay -S linux69-headers
yay -S linux69-broadcom-wl
--And REBOOT--
Details of my Process and Results:
sudo pacman -Sy
core 140,6 KiB 65,8 KiB/s 00:02 [######################] 100%
extra 8,3 MiB 2,12 MiB/s 00:04 [######################] 100%
multilib 144,7 KiB 67,4 KiB/s 00:02 [######################] 100%
pamac install linux69-headers --> (ERROR)
Preparing...
cp: cannot overwrite non-directory '/var/tmp/pamac/dbs/sync' with directory '/var/lib/pacman/sync'
Error: Failed to prepare transaction: target not found: linux69-headers
pacman -Qs linux-headers
local/linux69-headers 6.9.2-1
Header files and scripts for building modules for Linux69 kernel
pamac install linux69-broadcom-wl --> (ERROR)
error: package 'linux69-broadcom-wl' was not found
sudo pacman -Syu
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
Packages (40) botan2-2.19.4-1 ckbcomp-1.227-1 gdm-46.2-1 grub-btrfs-4.13-2 gtksourceview5-5.12.1-1 highway-1.2.0-1 intel-ucode-20240531-1
kvantum-1.1.2-1 kvantum-qt5-1.1.2-1 libbpf-1.4.2-1 libedit-20240517_3.1-1 libevdev-1.13.2-1 libgdm-46.2-1 libnbd-1.20.0-3
libwireplumber-0.5.3-1 linux69-6.9.3-3 linux69-headers-6.9.3-3 manjaro-release-24.0.2-1 mesa-1:24.0.9-1 mhwd-nvidia-550.90.07-2
mhwd-nvidia-470xx-470.256.02-1 mkinitcpio-39.2-2 mtools-1:4.0.44-1 noto-fonts-1:24.6.1-1 noto-fonts-extra-1:24.6.1-1
osinfo-db-20240523-1 python-pyopenssl-24.1.0-1 python-requests-2.32.3-1 qt5-base-5.15.14+kde+r140-1 qt5-svg-5.15.14+kde+r5-1
qt5-translations-5.15.14-1 qt5-x11extras-5.15.14-1 qt6-base-6.7.1-4 systemd-255.7-1 systemd-libs-255.7-1
systemd-sysvcompat-255.7-1 thunderbird-115.11.1-1 virglrenderer-1.0.1-2 wayland-1.23.0-1 wireplumber-0.5.3-1
Total Download Size: 376,66 MiB
Total Installed Size: 1235,56 MiB
Net Upgrade Size: 2,32 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages...
noto-fonts-1:24.6.1-1-any 27,7 MiB 2,37 MiB/s 00:12 [####################################################] 100%
noto-fonts-extra-1:24.6.1-1-any 64,8 MiB 3,76 MiB/s 00:17 [####################################################] 100%
mesa-1:24.0.9-1-x86_64 15,2 MiB 4,55 MiB/s 00:03 [####################################################] 100%
qt6-base-6.7.1-4-x86_64 13,7 MiB 4,02 MiB/s 00:03 [####################################################] 100%
linux69-headers-6.9.3-3-x86_64 25,1 MiB 1964 KiB/s 00:13 [####################################################] 100%
thunderbird-115.11.1-1-x86_64 55,2 MiB 2,17 MiB/s 00:25 [####################################################] 100%
intel-ucode-20240531-1-any 6,6 MiB 1124 KiB/s 00:06 [####################################################] 100%
systemd-255.7-1-x86_64 8,0 MiB 1190 KiB/s 00:07 [####################################################] 100%
qt5-base-5.15.14+kde+r140-1-x86_64 13,0 MiB 1678 KiB/s 00:08 [####################################################] 100%
qt5-translations-5.15.14-1-any 1914,3 KiB 3,95 MiB/s 00:00 [####################################################] 100%
botan2-2.19.4-1-x86_64 2,0 MiB 1936 KiB/s 00:01 [####################################################] 100%
linux69-6.9.3-3-x86_64 134,9 MiB 3,75 MiB/s 00:36 [####################################################] 100%
highway-1.2.0-1-x86_64 1099,5 KiB 362 KiB/s 00:03 [####################################################] 100%
kvantum-1.1.2-1-x86_64 1104,9 KiB 339 KiB/s 00:03 [####################################################] 100%
systemd-libs-255.7-1-x86_64 1105,4 KiB 315 KiB/s 00:04 [####################################################] 100%
gtksourceview5-5.12.1-1-x86_64 1007,0 KiB 3,93 MiB/s 00:00 [####################################################] 100%
gdm-46.2-1-x86_64 841,0 KiB 2,12 MiB/s 00:00 [####################################################] 100%
libnbd-1.20.0-3-x86_64 744,1 KiB 3,07 MiB/s 00:00 [####################################################] 100%
virglrenderer-1.0.1-2-x86_64 371,5 KiB 953 KiB/s 00:00 [####################################################] 100%
kvantum-qt5-1.1.2-1-x86_64 367,6 KiB 1558 KiB/s 00:00 [####################################################] 100%
libwireplumber-0.5.3-1-x86_64 262,1 KiB 742 KiB/s 00:00 [####################################################] 100%
libbpf-1.4.2-1-x86_64 254,1 KiB 1252 KiB/s 00:00 [####################################################] 100%
wireplumber-0.5.3-1-x86_64 225,6 KiB 968 KiB/s 00:00 [####################################################] 100%
mtools-1:4.0.44-1-x86_64 209,0 KiB 995 KiB/s 00:00 [####################################################] 100%
osinfo-db-20240523-1-any 198,1 KiB 889 KiB/s 00:00 [####################################################] 100%
qt5-svg-5.15.14+kde+r5-1-x86_64 149,3 KiB 423 KiB/s 00:00 [####################################################] 100%
wayland-1.23.0-1-x86_64 140,2 KiB 668 KiB/s 00:00 [####################################################] 100%
python-requests-2.32.3-1-any 118,5 KiB 333 KiB/s 00:00 [####################################################] 100%
libedit-20240517_3.1-1-x86_64 112,0 KiB 533 KiB/s 00:00 [####################################################] 100%
python-pyopenssl-24.1.0-1-any 107,2 KiB 481 KiB/s 00:00 [####################################################] 100%
libgdm-46.2-1-x86_64 93,3 KiB 264 KiB/s 00:00 [####################################################] 100%
mkinitcpio-39.2-2-any 64,8 KiB 289 KiB/s 00:00 [####################################################] 100%
libevdev-1.13.2-1-x86_64 57,8 KiB 164 KiB/s 00:00 [####################################################] 100%
ckbcomp-1.227-1-any 48,4 KiB 230 KiB/s 00:00 [####################################################] 100%
grub-btrfs-4.13-2-any 35,4 KiB 93,1 KiB/s 00:00 [####################################################] 100%
mhwd-nvidia-470xx-470.256.02-1-any 22,6 KiB 108 KiB/s 00:00 [####################################################] 100%
mhwd-nvidia-550.90.07-2-any 22,5 KiB 59,7 KiB/s 00:00 [####################################################] 100%
qt5-x11extras-5.15.14-1-x86_64 14,3 KiB 68,2 KiB/s 00:00 [####################################################] 100%
manjaro-release-24.0.2-1-any 11,6 KiB 30,9 KiB/s 00:00 [####################################################] 100%
systemd-sysvcompat-255.7-1-x86_64 6,1 KiB 31,1 KiB/s 00:00 [####################################################] 100%
Total (40/40) 376,7 MiB 9,28 MiB/s 00:41 [####################################################] 100%
(40/40) checking keys in keyring [####################################################] 100%
(40/40) checking package integrity [####################################################] 100%
(40/40) loading package files [####################################################] 100%
(40/40) checking for file conflicts [####################################################] 100%
(40/40) checking available disk space [####################################################] 100%
(1/4) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(2/4) Removing linux initcpios...
(3/4) Remove DKMS modules
==> dkms remove --no-depmod rtl88xxau/r1298.b44d288 -k 6.9.2-1-MANJARO
==> depmod 6.9.2-1-MANJARO
(4/4) Remove Thunderbird Distribution Settings
( 1/40) upgrading botan2 [####################################################] 100%
( 2/40) upgrading ckbcomp [####################################################] 100%
( 3/40) upgrading systemd-libs [####################################################] 100%
( 4/40) upgrading systemd [####################################################] 100%
( 5/40) upgrading libgdm [####################################################] 100%
New optional dependencies for libgdm
xorg-server: X session support [installed]
xorg-xhost: X session support [installed]
xorg-xrdb: X session support [installed]
( 6/40) upgrading wayland [####################################################] 100%
( 7/40) upgrading libedit [####################################################] 100%
( 8/40) upgrading mesa [####################################################] 100%
( 9/40) upgrading libevdev [####################################################] 100%
(10/40) upgrading libwireplumber [####################################################] 100%
(11/40) upgrading wireplumber [####################################################] 100%
(12/40) upgrading highway [####################################################] 100%
(13/40) upgrading gdm [####################################################] 100%
(14/40) upgrading grub-btrfs [####################################################] 100%
(15/40) upgrading gtksourceview5 [####################################################] 100%
(16/40) upgrading intel-ucode [####################################################] 100%
(17/40) upgrading qt6-base [####################################################] 100%
(18/40) upgrading kvantum [####################################################] 100%
(19/40) upgrading qt5-translations [####################################################] 100%
(20/40) upgrading qt5-base [####################################################] 100%
(21/40) upgrading qt5-svg [####################################################] 100%
(22/40) upgrading qt5-x11extras [####################################################] 100%
(23/40) upgrading kvantum-qt5 [####################################################] 100%
(24/40) upgrading libbpf [####################################################] 100%
(25/40) upgrading libnbd [####################################################] 100%
(26/40) upgrading mkinitcpio [####################################################] 100%
(27/40) upgrading linux69 [####################################################] 100%
(28/40) upgrading linux69-headers [####################################################] 100%
(29/40) upgrading manjaro-release [####################################################] 100%
(30/40) upgrading mhwd-nvidia-470xx [####################################################] 100%
(31/40) upgrading python-requests [####################################################] 100%
(32/40) upgrading mhwd-nvidia [####################################################] 100%
(33/40) upgrading mtools [####################################################] 100%
(34/40) upgrading noto-fonts [####################################################] 100%
(35/40) upgrading noto-fonts-extra [####################################################] 100%
(36/40) upgrading osinfo-db [####################################################] 100%
(37/40) upgrading python-pyopenssl [####################################################] 100%
(38/40) upgrading systemd-sysvcompat [####################################################] 100%
(39/40) upgrading thunderbird [####################################################] 100%
(40/40) upgrading virglrenderer [####################################################] 100%
( 1/20) Creating system user accounts...
( 2/20) Updating journal message catalog...
( 3/20) Reloading system manager configuration...
( 4/20) Reloading user manager configuration...
( 5/20) Updating udev hardware database...
( 6/20) Applying kernel sysctl settings...
( 7/20) Creating temporary files...
( 8/20) Reloading device manager configuration...
( 9/20) Arming ConditionNeedsUpdate...
(10/20) Updating module dependencies...
(11/20) Install DKMS modules
==> dkms install --no-depmod rtl88xxau/r1298.b44d288 -k 6.9.3-3-MANJARO
==> depmod 6.9.3-3-MANJARO
(12/20) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux67-rt.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz-6.7-rt-x86_64 -g /boot/initramfs-6.7-rt-x86_64.img
==> Starting build: '6.7.0-3-rt6-MANJARO'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [plymouth]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.7-rt-x86_64.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux67-rt.preset: 'fallback'
-> -k /boot/vmlinuz-6.7-rt-x86_64 -g /boot/initramfs-6.7-rt-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.7-rt-x86_64-fallback.img'
==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'default'
-> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64.img
==> Starting build: '6.9.3-3-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64.img'
==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'fallback'
-> -k /boot/vmlinuz-6.9-x86_64 -g /boot/initramfs-6.9-x86_64-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.9-x86_64-fallback.img'
(13/20) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.9-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.9-x86_64.img
Found initrd fallback image: /boot/initramfs-6.9-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.7-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.7-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-6.7-rt-x86_64-fallback.img
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
(14/20) Reloading system bus configuration...
(15/20) Updating fontconfig cache...
(16/20) Compiling GSettings XML schema files...
(17/20) Updating icon theme caches...
(18/20) Updating the info directory file...
(19/20) Copy Thunderbird Distribution Settings
(20/20) Updating the desktop file MIME type cache...
sudo pacman -S yay
:: yay-12.3.5-1 and yay-git-12.3.5.r13.g53c9d0ef-1 are in conflict. Remove yay-git? [y/N] y
Packages (2) yay-git-12.3.5.r13.g53c9d0ef-1 [removal] yay-12.3.5-1
Total Installed Size: 9,30 MiB
Net Upgrade Size: 0,82 MiB
(1/1) checking keys in keyring [####################################################] 100%
(1/1) checking package integrity [####################################################] 100%
(1/1) loading package files [####################################################] 100%
(1/1) checking for file conflicts [####################################################] 100%
(2/2) checking available disk space [####################################################] 100%
(1/1) removing yay-git [####################################################] 100%
(1/1) installing yay [####################################################] 100%
Optional dependencies for yay
sudo: privilege elevation [installed]
doas: privilege elevation
(1/1) Arming ConditionNeedsUpdate...
Sync Explicit (1): linux69-headers-6.9.3-3
warning: linux69-headers-6.9.3-3 is up to date -- reinstalling
Packages (1) linux69-headers-6.9.3-3
Total Installed Size: 122,86 MiB
Net Upgrade Size: 0,00 MiB
(1/1) checking available disk space [####################################################] 100%
(1/2) Creating Timeshift snapshot before upgrade...
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod rtl88xxau/r1298.b44d288 -k 6.9.3-3-MANJARO
(1/1) reinstalling linux69-headers [####################################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Updating module dependencies...
(3/3) Install DKMS modules
Sync Explicit (1): linux69-broadcom-wl-6.30.223.271-8
Packages (1) linux69-broadcom-wl-6.30.223.271-8
Total Download Size: 1,60 MiB
Total Installed Size: 1,61 MiB
linux69-broadcom-wl-6.30.223.271-8-x86_64 1640,0 KiB 408 KiB/s 00:04 [####################################################] 100%
(1/1) installing linux69-broadcom-wl [####################################################] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating module dependencies...
AND REBOOT
You could have done without yay - just with pacman. Seems like one of the cases where the headers are needed although they are not in theory. Me personally i always install the headers with the kernel, just in case something like this happens and there is no obvious error.
The other package is the drivers for broadcom as already pointed in the posts above, because that tplink uses broadcom chip.
Which is kind a strange for me…tplink was atheros client for years, which was bought by qualcomm…later they wanted to merge with broadcom but the deal was off (i think Trump stopped this to become the biggest radiochip monopoly…but i have already forgotten the details). So being a chip maker yourself and buying chips from the competition is kinda funny…but well we see it all the time, Apple still buys some components from Samsung, etc.
P.s. still, something is off with your pamac. Probably the database is broken or not refreshed or you have used sudo pamac which you should not do. You can open another topic for that if you refresh mirrors and the database and still cannot install anything with pamac.
