I just clean installed manjaro and dont know much about it. I am facing some issues after waking it from sleep. As soon as i wake it, the display starts to behave abnormally, although i can use all functions (such as shutting it down ) and mouse(mouse is visible). But i am not able to use after that. If you need any system info, i can provide you (please also tell me the way to retrieve the concerned info as i am fairly new to manjaro). i will also attach an image to show the abnormal display.
Just post inxi -Fza
on console.
Thanks for your time and concern but apparently updating Linux kernel version fixed the problem.
Sorry I was wrong, updating the kernel didn’t solved the problem…i have changed my plasma on Wayland to plasma(x11),which solved the problem.
