This seems like a solvable problem since nothing else in plasma is breaking. I get the following errors in my logs.
plasmashell QWaylandDataOffer: timeout reading from pipe
plasmashell QWaylandDataOffer: error reading data for mimeType application/x-kde-cutselection
plasmashell QQmlComponent: Component is not ready
plasmashell file:///usr/lib/qt/qml/org/kde/kirigami.2/PageRow.qml:801: Error: Error while loading page: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:25 module "org.kde.newstuff" plugin "newstuffqmlplugin" not found
Actually, I just reinstalled knewstuff and I got widget settings back!
I get a load of warnings after restarting though. Any thoughts on what else caused these? Are they even important?
plasmashell org.kde.klipper: Invalid or non-local url for preview: QUrl("")
plasmashell qml: >>>>>>>>>>>>> childrenRect: 443 - 518
plasmashell qml: >>>>>>>>>>>>> w-h: 443 - 681
plasmashell trying to show an empty dialog
plasmashell qt.core.qabstractitemmodel.checkindex: Index QModelIndex(-1,-1,0x0,QObject(0x0)) is not valid (expected valid)
plasmashell file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/FullRepresentation.qml:35:1: QML FullRepresentation: Binding loop detected for property "implicitHeight"
plasmashell file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.linechart/contents/ui/LineChart.qml:98:13: Unable to assign [undefined] to int
plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/ToolTipInstance.qml:69:5: Unable to assign QStringList to QString
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:27:1: QML Panel: Binding loop detected for property "state"
plasmashell QQmlEngine::setContextForObject(): Object already has a QQmlContext
plasmashell file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/OverlaySheet.qml:220:38: QML FocusScope: Binding loop detected for property "contentItemMaximumWidth"
plasmashell QCoreApplication::postEvent: Unexpected null receiver
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:166:9: QML StackView: replace: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/config.qml:26 module "org.kde.kquickcontrols" is not installed
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:190: TypeError: Cannot read property 'cfg_objectNameChanged' of null
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationContainmentAppearance.qml:90: TypeError: Cannot read property 'formLayout' of null
plasmashell file:///usr/lib/qt/qml/org/kde/kirigami.2/AbstractApplicationItem.qml:94: TypeError: Cannot read property 'position' of null
plasmashell file:///usr/lib/qt/qml/org/kde/kirigami.2/AbstractApplicationItem.qml:93: TypeError: Cannot read property 'background' of null
plasmashell file:///usr/lib/qt/qml/org/kde/newstuff/qml/Page.qml:155: TypeError: Cannot read property 'useLabel' of null
plasmashell file:///usr/lib/qt/qml/org/kde/newstuff/qml/Dialog.qml:130: TypeError: Cannot read property 'uploadEnabled' of null
plasmashell qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
plasmashell file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ButtonStyle.qml:30:12: QML RowLayout: Binding loop detected for property "minimumHeight"
plasmashell qml: in external window
plasmashell Error: cannot change the containment to AppletsLayout
plasmashell Both point size and pixel size set. Using pixel size.
plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/Tooltip.qml:66:9: QML GridLayout (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
plasmashell Process "/usr/share/plasma/plasmoids/gr.ictpro.jsalatas.plasma.pstate/contents/code/set_prefs.sh -read-all" already running. Pid: 1567
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:50:5: QML Loader: Binding loop detected for property "height"
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/AppletConfiguration.qml:212: TypeError: Value is null and could not be converted to an object
plasmashell kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: cannot open shared object file: No such file or directory)"
plasmashell kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: cannot open shared object file: No such file or directory)"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/applications.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/applications.so'"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kf5/kio/desktop.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kf5/kio/desktop.so'"
plasmashell Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_about_distro.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_kernel.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevildpmsaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_info.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_kill.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilprofilesconfig.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cookies.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_printer_manager.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_netpref.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libkcm_qtquicksettings.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_facebook.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_cddb.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_opengl.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_trash.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_wacomtablet.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_vkontakte.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_smug.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_ssl.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/comicbookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/comicbookthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwallet5.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/rawthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/rawthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_kmlexport.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3bexternalencoder.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/windowsexethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/windowsexethumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_keyboard.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_desktoppaths.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_obexftp.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_obexftp.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/plasma-geolocation-ip.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_fontinst.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_charrunner.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_bluetooth.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_bluetooth.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintouchscreen.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/textthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/textthumbnail.so'"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/exrthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/exrthumbnail.so'"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/gsthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/gsthumbnail.so'"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/cursorthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/cursorthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kdeconnect.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/blenderthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/blenderthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_spellcheck.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_imgur.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/djvuthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/djvuthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/okularpart.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_bittorrentfactory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfileaudiopreview.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_hotkeys.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilbrightnesscontrolaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_smb.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_printimages.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilglobalconfig.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_mirrorsearchfactory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_language_packages.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_pci.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/miloutextplugin.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ebookthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ebookthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_networkmanagement.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_timedate.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilsuspendsessionaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilkeyboardbrightnesscontrolaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/plasma-geolocation-gps.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinoptions.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kamera.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_rajce.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/fontthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/fontthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_checksumsearchfactory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_devinfo.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kded_touchpad.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_proxy.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kgamma.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/svgthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/svgthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_breeze_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/appimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/appimagethumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_findthisdevice_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_filetypes.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphinnavigation.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilrunscriptaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_joystick.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_systemd.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_pausemusic_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwinscreenedges.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kget_browser_integration.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_yandexfotki.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphingeneral.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevildimdisplayaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_dropbox.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilhandlebuttoneventsaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwin_scripts.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/audiothumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/audiothumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_sendnotifications_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_activities.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/opendocumentthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/opendocumentthumbnail.so'"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/windowsimagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/windowsimagethumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_mmsfactory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_usb.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3boggvorbisencoder.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_clock.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/ffmpegthumbs.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/ffmpegthumbs.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_share_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcmspellchecking.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_googleservices.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/jpegthumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/jpegthumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_flickr.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_mhwd.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_users.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_jalbum.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/imagethumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/imagethumbnail.so'"
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kio_fonts.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kio_fonts.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_imageshack.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_plasmasearch.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3bsoxencoder.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_wikimedia.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/baloofilepropertiesplugin.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kdeconnect_runcommand_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_webshortcuts.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_krunner_dictionary.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_mouse.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_solid_actions.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libplasmanetworkmanagement_openconnectui.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_sendimages.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_remotestorage.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/attica_kde.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kipiplugin_piwigo.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_metalinkfactory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kwintabbox.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/libkcm_device_automounter.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kwincompositing.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: no metadata found in "/usr/lib/qt/plugins/kritathumbnail.so" "Failed to extract plugin meta data from '/usr/lib/qt/plugins/kritathumbnail.so'"
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_dolphinviewmodes.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kfontviewpart.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_k3blameencoder.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_keyboard.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_kget_multisegkiofactory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/msm_locale.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kstyle_oxygen_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_powerdevilactivitiesconfig.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_memory.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/powerdevilwirelesspowersavingaction_config.so" does not have a valid 'MetaData' object
plasmashell kf.coreaddons: plugin metadata in "/usr/lib/qt/plugins/kcm_view1394.so" does not have a valid 'MetaData' object
plasmashell kf.plasma.quick: Applet preload policy set to 1
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
plasmashell libpng warning: iCCP: known incorrect sRGB profile
plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.systemmonitor/contents/ui/main.qml:56:5: QML MouseArea: Cannot anchor to an item that isn't a parent or sibling.
plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:531:9: QML Label: Binding loop detected for property "height"
plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:486:13: QML Label: Binding loop detected for property "height"
plasmashell file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:30:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
plasmashell file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:553:5: QML Label: Binding loop detected for property "height"
plasmashell file:///usr/share/ksysguard/sensorfaces/org.kde.ksysguard.piechart/contents/ui/CompactRepresentation.qml:35:1: QML CompactRepresentation: Binding loop detected for property "implicitHeight"
plasmashell file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:213: Error: Invalid write to global property "prefix"
Appears lots of my packages were not updated completely or are missing plugins. Anything else I should reinstall to resolve these?
