Hi all,
Linux newb here. I have an issue regarding my Wi-Fi internet dongle. I’m running Manjaro KDE/Plasma, which I believe uses the NetworkManager service for wifi connectivity.
The issue is as follows. After my PC has been inactive for a certain amount of time (it seems to be 30+ minutes), when the PC wakes it no longer recognizes the USB dongle. The issue is resolved by manually unplugging the dongle and plugging it back in. Having read other posts on similar issues, I ran the command lsusb
both before and after this procedure.
The output of lsusb
after waking is
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 046d:c24a Logitech, Inc. G600 Gaming Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 25a7:fa70 Areson Technology Corp 2.4G Wireless Receiver
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
The output of lsusb
after manually disconnecting and reconnecting the USB dongle is
Bus 001 Device 009: ID 1737:0079 802.11g Adapter [Linksys WUSB54GC v3] WUSB600N v2 Dual-Band Wireless-N Network Adapter [Ralink RT3572]
Again, I’m a newb with linux, but this seems to indicate to me pretty clearly that for whatever reason the device is simply not being recognized by the kernel upon waking, with the USB dongle being device 009. The behavior persists regardless of which peripherals are plugged into the USB ports on the machine, and regardless of their physical configuration.
The same behavior is intermittently observed when I restart the PC, and is resolvable in the same manner. I have had this issue since installation of the OS, so I don’t think it’s a result of anything I have done.
The output of the command inxi --admin --verbosity=7 --filter --no-host --width
while the Wi-Fi is active is as follows.
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c9608465-0a7e-4d9d-8a68-63cccc981f7c rw quiet apparmor=1
resume=/dev/disk/by-uuid/c9608465-0a7e-4d9d-8a68-63cccc981f7c
resume_offset=995328
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: H61M-USB3-B3 v: x.x
serial: <superuser required> BIOS: Award v: F9 date: 10/12/2011
RAM: total: 7.68 GiB used: 6.69 GiB (87.0%)
RAM Report:
Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2022 high: 3450 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1696 2: 3450 3: 1820
4: 1913 5: 1596 6: 1684 7: 1942 8: 2079 bogomips: 54299
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce
md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
xtpr
Type: l1tf
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel ports: active: HDMI-A-1,VGA-1
empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0102
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right
model: LG (GoldStar) W2361 serial: <filter> built: 2010 res: 1920x1080
hz: 60 dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42")
diag: 587mm (23.1") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: VGA-1 pos: primary,left model: Acer V226HQL serial: <filter>
built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9 modes:
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
v: 3.3 Mesa 21.3.8 compat-v: 3.0 direct render: Yes
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Qualcomm Atheros AR8151 v1.0 Gigabit Ethernet vendor: Gigabyte
driver: atl1c v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: ef00
bus-ID: 05:00.0 chip-ID: 1969:1073 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: 802.11g Adapter [Linksys WUSB54GC v3] WUSB600N v2 Dual-Band
Wireless-N Network [Ralink RT3572]
type: USB driver: rt2800usb bus-ID: 1-1.3:9 chip-ID: 1737:0079
class-ID: 0000
IF: wlp0s26u1u3 state: up mac: <filter>
Local Storage: total: 1.24 TiB used: 100.06 GiB (7.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHII120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB10C
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: SSD serial: <filter> rev: R022 scheme: MBR
ID-1: / raw-size: 111.74 GiB size: 109.43 GiB (97.93%)
used: 49.91 GiB (45.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: c9608465-0a7e-4d9d-8a68-63cccc981f7c
ID-2: /run/media/josh/10F8DAE4F8DAC75E raw-size: 223.06 GiB
size: 223.06 GiB (100.00%) used: 50.15 GiB (22.5%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: N/A uuid: 10F8DAE4F8DAC75E
ID-1: swap-1 type: file size: 8 GiB used: 353.1 MiB (4.3%) priority: -2
file: /swapfile
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System Reserved
uuid: BABAD4DEBAD497E9
ID-2: /dev/sdc2 maj-min: 8:34 size: 517 MiB fs: ntfs label: N/A
uuid: A6A02B3EA02B1479
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.3:9 info: 802.11g Adapter [Linksys WUSB54GC v3] WUSB600N v2
Dual-Band Wireless-N Network [Ralink RT3572]
type: Network driver: rt2800usb interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 450mA chip-ID: 1737:0079 class-ID: 0000
Device-2: 1-1.4:4 info: Areson Corp 2.4G Wireless Receiver
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 25a7:fa70 class-ID: 0301
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 3-1:2 info: Logitech G600 Gaming Mouse type: Mouse,Keyboard
power: 500mA chip-ID: 046d:c24a class-ID: 0300 serial: <filter>
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 269 Uptime: 18h 32m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1523
pacman: 1515 lib: 373 flatpak: 0 snap: 8 Shell: Zsh v: 5.8.1
running-in: konsole inxi: 3.3.15
Any advice on diagnostic commands I might run, as well as any ideas for fixes, would be much appreciated.
