My Wi-Fi connection doesnt’ work really well, I checked smartphones, other computers with different OS’ (Windows, macOS, other GNU/Linux distros) and they all work great, nothing much different from the usual speed and stability I get when connecting via Ethernet.
I did a fresh installation of Manjaro some time ago and I haven’t been able to update the software neither via pamac or terminal, when I’m at x% downloaded, the connection suddenly obfuscates, then the terminal/pamac bugs out and the download never resumes (trust me, I let the laptop online all night thinking everything would be done by morning). This extrapolates to navigating using Chromium or Firefox, most of the times I get the The request took too much time to respond, it happens to almost everything.
Curiously enough, when downloading via bittorrent the connection works well enough, it’s consistent.
inxi -F
Host: cerebrain-U925t Kernel: 5.4.22-1-MANJARO x86_64 bits: 64
Desktop: Xfce 4.14.2 Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: Satellite U925t v: PSUL1U-01H008
serial: <root required>
Mobo: TOSHIBA model: Satellite U925t v: Version A0 serial: <root required>
BIOS: TOSHIBA v: Version 1.50 date: 09/27/2013
ID-1: BAT1 charge: 17.4 Wh condition: 17.4/37.7 Wh (46%)
Topology: Dual Core model: Intel Core i5-3337U bits: 64 type: MT MCP
L2 cache: 3072 KiB
Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 799
Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Display: x11 server: X.Org 1.20.7 driver: intel unloaded: modesetting
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 19.3.4
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel
Sound Server: ALSA v: k5.4.22-1-MANJARO
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi
IF: wlp2s0 state: up mac: 60:36:dd:ba:0a:09
Local Storage: total: 119.24 GiB used: 13.22 GiB (11.1%)
ID-1: /dev/sda vendor: Toshiba model: THNSNF128GMCS size: 119.24 GiB
ID-1: / size: 116.87 GiB used: 13.22 GiB (11.3%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 188 Uptime: 1h 50m Memory: 3.74 GiB used: 2.05 GiB (54.8%)
Shell: bash inxi: 3.0.37
I honestly have no idea what might be the problem, but I’m almost sure that what happens is that the connection suddenly stops working, then denies communication with other peers.
if you people could help me troubleshoot, I would appreciate it a lot. I don’t want to go back to Windows or Debian-based distros.
