Hi, i installed Manjaro yesterday and i have problem:on WIN10 bluetooth doesnt work, wi-fi work properly, and when i installed manjaro bluetooth start working, but my wi-fi started working terribly, i sitting near router and level of my signal is ~50%
ip link
output
ip link ξ² β
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp2s0f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP mode DEFAULT group default qlen 1000
link/ether d8:c4:97:c7:1b:18 brd ff:ff:ff:ff:ff:ff
3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
link/ether f8:a2:d6:49:76:81 brd ff:ff:ff:ff:ff:ff
inxi -Fxxxrz --usb;modinfo
inxi -n|grep -Po βver: \K[^ ]+β|grep
parm output
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Aspire A315-21 v: V1.12
serial: <superuser required>
Mobo: SR model: Squirtle_SR v: V1.12 serial: <superuser required>
UEFI: Insyde v: 1.12 date: 06/19/2018
ID-1: BAT1 charge: 16.4 Wh (73.9%) condition: 22.2/37.0 Wh (59.9%)
volts: 8.1 min: 7.7 model: PANASONIC AP16M5J type: Li-ion serial: <filter>
status: charging
Info: dual core model: AMD A6-9220e RADEON R4 5 COMPUTE CORES 2C+3G
bits: 64 type: MCP smt: <unsupported> arch: Excavator rev: 0 cache:
L1: 192 KiB L2: 2 MiB
Speed (MHz): avg: 1755 high: 2243 min/max: 1200/1600 boost: enabled
cores: 1: 1267 2: 2243 bogomips: 6390
Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Realtek VGA WebCam type: USB driver: uvcvideo bus-ID: 1-1.4:4
chip-ID: 0bda:5648 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0675 res: 1366x768
hz: 60 dpi: 101 size: 344x194mm (13.54x7.64") diag: 395mm (15.5") modes:
max: 1366x768 min: 640x480
OpenGL: renderer: AMD STONEY (DRM 3.42.0 5.15.32-1-MANJARO LLVM 13.0.1)
v: 4.5 Mesa 21.3.8 direct render: Yes
Device-1: AMD vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
Device-2: AMD Family 15h Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
vendor: Acer Incorporated ALI driver: r8168 v: 8.049.02-NAPI pcie:
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: enp2s0f1 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB
driver: btusb v: 0.8 bus-ID: 1-1.3:3 chip-ID: 04ca:3015 class-ID: e001
Local Storage: total: 465.76 GiB used: 132.05 GiB (28.4%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 2J scheme: GPT
ID-1: / size: 44.7 GiB used: 12.84 GiB (28.7%) fs: ext4 dev: /dev/sda6
ID-2: /boot/efi size: 96 MiB used: 57.9 MiB (60.3%) fs: vfat
dev: /dev/sda1
ID-1: swap-1 type: partition size: 977 MiB used: 257.8 MiB (26.4%)
priority: -2 dev: /dev/sda7
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
Device-1: 1-1.3:3 info: Lite-On Qualcomm Atheros QCA9377 Bluetooth
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04ca:3015 class-ID: e001
Device-2: 1-1.4:4 info: Realtek VGA WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:5648
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 2-3:2 info: MOSART Semi. 2.4G Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 3938:1031 class-ID: 0301
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 37.0 C
Packages: pacman: 1396
1: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
2: http://mirror.fcix.net/manjaro/stable/$repo/$arch
3: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
Processes: 199 Uptime: 44m wakeups: 1 Memory: 3.71 GiB
used: 3.2 GiB (86.2%) Init: systemd v: 250 Compilers: gcc: 11.2.0
clang: 13.0.1 Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.15
parm: speed_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: duplex_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: autoneg_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: advertising_mode:force phy operation. Deprecated by ethtool (8). (uint)
parm: dynamic_aspm:int
parm: aspm:Enable ASPM. (int)
parm: s5wol:Enable Shutdown Wake On Lan. (int)
parm: s5_keep_curr_mac:Enable Shutdown Keep Current MAC Address. (int)
parm: rx_copybreak:Copy breakpoint for copy-only-tiny-frames (int)
parm: use_dac:Enable PCI DAC. Unsafe on 32 bit PCI slot. (int)
parm: timer_count:Timer Interrupt Interval. (int)
parm: eee_enable:Enable Energy Efficient Ethernet. (int)
parm: hwoptimize:Enable HW optimization function. (ulong)
parm: s0_magic_packet:Enable S0 Magic Packet. (int)
parm: dynamic_aspm_packet_threshold:Dynamic ASPM packet threshold. (int)
parm: debug:Debug verbosity level (0=none, ..., 16=all) (int)
parm: irq_mode:0: auto, 1: legacy, 2: msi (default: 0) (uint)
parm: reset_mode:0: auto, 1: warm only (default: 0) (uint)
I hope I have provided complete information.
