I’ve seen quite a few of these threads across both the Manjaro forums and the Arch forums, and followed many of the suggested tweaks, but I’m still having problems in my own system.
New Manjaro user. Started out on Linux Mint and had this same problem, but was more severe on Mint. I switched to Manjaro because I was not really liking Mint all that much anyway. Manjaro seemed to improve the situation marginally but I’m still having problems where my wi-fi is behaving kind of like it’s bottlenecked?
On ookla, I’ve been able to peak about 110 Mbps Down and 100-200 Mbps Up out of the box. When I had Windows installed on this same system, it was able to reach much higher speeds (around 200-250 Mbps Down.). My husband’s computer is right next to mine and still gets those speeds, peaking at 250 Mbps down. Same network, but he’s using Windows 10. All programs that I use including Steam and package manager seem to follow this speed, so it’s either slower or equal, but never faster.
If it weren’t so significantly slower than expected, I wouldn’t even worry about it, because an average of 60-100 Mbps down is still fine, but I’m frustrated about not getting the full speeds that I should be.
What I’ve done so far:
- Disabled IPv6 in NetworkManager. I should note that I’m using the 5g band for my particular network, but there is a 2.4g band available that seemed consistently slower in the past when I used it even on Windows.
- Updated lwlwifi.conf with some new configurations (I’ve included this below) and tweaked these back and forth to understand somewhat how it behaves. I’ve gotten it to the best spot I could.
- Attempted to update firmware through the Intel website, but it doesn’t seem to have taken, or if it did, it doesn’t show. I did that from Intel’s /support/articles/000005511/wireless.html.
Let’s see if I can do this right. Here’s my diags.
inxi --full --admin --filter --width
Kernel: 6.6.16-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=f568e386-a299-4e61-b9f0-15eb0109638a rw quiet splash
resume=UUID=94cd970e-a7eb-49a3-8025-36261525b459 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Dash F15 FX516PE_FX516PE
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: FX516PE v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: FX516PE.330
date: 05/15/2023
ID-1: BAT0 charge: 67.0 Wh (99.3%) condition: 67.5/76.0 Wh (88.9%)
volts: 15.8 min: 15.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 20
Info: model: 11th Gen Intel Core i7-11370H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xB4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 2621 high: 3733 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1968 2: 1956 3: 3203
4: 3235 5: 3082 6: 586 7: 3733 8: 3205 bogomips: 52856
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
RSB filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 bus-ID: 0000:01:00.0
chip-ID: 10de:25a0 class-ID: 0300
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-1-0 size-res: N/A modes: N/A
Monitor-2: eDP-1 pos: primary res: 1920x1080 hz: 144 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.96 GiB unified: yes
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3050 Ti Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:25a0 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: Intel Xe Graphics (TGL GT2) driver: mesa intel v: 23.3.5-manjaro1.1
device-ID: 8086:9a49 surfaces: xcb,xlib
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:2291 class-ID: 0403
API: ALSA v: k6.6.16-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel port: 3000
bus-ID: 0000:2e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno2 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 280.66 GiB (19.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR002 temp: 25.9 C
scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: MZVLQ512HBLU-00B00
lanes: 4 tech: SSD serial: <filter> fw-rev: FXM7201Q temp: 28.9 C
scheme: GPT
ID-1: / raw-size: 459.79 GiB size: 451.5 GiB (98.20%) used: 43.81 GiB (9.7%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:4
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
Kernel: swappiness: 25 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
System Temperatures: cpu: 37.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 3.68 GiB (24.0%)
Processes: 261 Power: uptime: 40m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 6.11 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1332 pm: pacman pkgs: 1324 libs: 397 tools: pamac,yay pm: flatpak
pkgs: 8 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Here’s how I’ve configured the file. I did a lot of tweaking to try and improve the connection. Some configuration lines had a visible effect but in the opposite direction. This is the best I can get with the Ookla results I posted before:
iwlwifi.conf
options iwlwifi power_save=0
options iwlwifi power_level=5
options iwlwifi 11n_disable=8
options iwlwifi swcrypto=0
options iwlwifi bt_coex_active=0
options iwlwifi uapsd_disable=0
options iwlmvm power_scheme=1
systool -vm iwlwifi
Module = "iwlwifi"
Attributes:
coresize = "569344"
initsize = "0"
initstate = "live"
refcnt = "1"
srcversion = "CBA99B6995DCE3FD42D4D42"
taint = ""
uevent = <store method only>
Parameters:
11n_disable = "8"
amsdu_size = "0"
bt_coex_active = "N"
debug = "0"
disable_11ac = "N"
disable_11ax = "N"
disable_11be = "N"
enable_ini = "16"
fw_restart = "Y"
led_mode = "0"
nvm_file = "(null)"
power_level = "5"
power_save = "N"
remove_when_gone = "N"
swcrypto = "0"
uapsd_disable = "0"
Hopefully someone has some new ideas? Otherwise I’m stumped. Thanks in advance.
