hello, I’m a newbie, I dual booted manjaro with windows, but I tried to use the wifi and it didn’t show up.I’ve tried a lot of solutions that I’ve found, so help me understand the problem.
$ rfkill list
0: asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: asus-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Please put ``` before and after your output, or highlight your output and click on the </> button on the forum. The way you currently have it is hard to read.
Try updating to Kernel 5.14 to see if that fixes anything. Also install linux514-headers if it doesn’t auto install. Kernel 5.13 is EOL.
I meant shutdown from the Windows Start button. Kernel 5.13 is EOL, Please try with a LTS Kernel, either 5.4LTS or 5.10LTS and be sure to install the corresponding kernel headers, then reboot and remove 5.13 and reboot again.
Are you certain that the rtl8821ce driver built and installed successfully?
What does output of (in terminal) look like:
