Hello,
I am a newbie in Linux. I have a MSI laptop that has a Nvidia GPU and the internal Intel GPU. I use optimus manager to switch between both. Optimus manager works well and the Nvidia GPU runs properly with my current drivers and setup.
Problem is, whenever I use the Nvidia GPU (either by setting optimus manager to use it on boot, or when switching from Intel) my home Wi-fi starts acting weird. It struggles a lot to establish connection, and upon doing so, it usually doesn’t stream any data. However, connection does work properly when I share my phone Internet data with the laptop instead of connecting with my home router.
Interestingly enough, there are exceptions to the behaviour I’ve just explained. Sometimes the Wi-fi just happens to work for an unlimited period of time without any noticeable issue. This drives me insane as I don’t understand what are the particular circumstances in which it does work.
My laptop is very small and thin; I don’t know if the fact that the Nvidia GPU is used results in interference between hardware components as things are quite close to each other. High temperature is not the issue though. The problem persists even in an idle state.
Just to add info, the problem has existed with different Linux kernels.
I don’t really know what to do. If anyone could give me at least some direction, it would very much be appreciated. I don’t know which logs to look for, or what can I possibly do with such information.
Thank you.
inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=d3f90009-50f9-4092-843d-c7edaaeabb0c rw quiet apparmor=1
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Micro-Star product: Modern 14 A10RB v: REV:1.0
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-14B3 v: REV:1.0 serial: <filter>
UEFI: American Megatrends v: E14B3IMS.50C date: 10/31/2019
ID-1: BAT1 charge: 36.3 Wh condition: 36.3/50.0 Wh (73%) volts: 16.9/15.2
model: MSI BIF0_9 type: Li-ion serial: N/A status: Full
Device-1: hidpp_battery_0 model: Logitech M585/M590 Multi-Device Mouse
status: Discharging
Topology: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: D6
L2 cache: 8192 KiB
bogomips: 36812
Speed: 800 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Micro-Star MSI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Micro-Star MSI
driver: nvidia v: 440.100 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1d13
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus ID: 1-7:4
chip ID: 5986:211b
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Device-2: Logitech [G533 Wireless Headset Dongle] type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1:7 chip ID: 046d:0a66
Sound Server: ALSA v: k5.8.11-1-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3 chip ID: 8086:02f0
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 476.94 GiB used: 133.20 GiB (27.9%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
rev: ADXA0103 scheme: GPT
ID-1: / raw size: 476.64 GiB size: 468.16 GiB (98.22%)
used: 133.20 GiB (28.5%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 280 Uptime: 3h 00m Memory: 15.48 GiB used: 2.82 GiB (18.2%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1489 pacman: 1474
lib: 436 flatpak: 11 snap: 4 Shell: Bash v: 5.0.18 running in: yakuake
inxi: 3.1.05
dmesg | less
[ 6587.225032] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 6587.225083] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 6587.225234] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 6587.225249] ieee80211 phy0: Hardware restart was requested
[ 6587.225295] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 6597.608097] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6607.618205] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6617.630649] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6627.640836] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6637.651118] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6647.661254] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6657.671574] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6664.375148] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=84.88.192.218 DST=192.168.1.42 LEN=83 TOS=0x00 PREC=0x00 TTL=56 ID=35744 DF PROTO=TCP SPT=443 DPT=40196 WINDOW=36 RES=0x00 ACK PSH URGP=0
[ 6667.681745] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6677.693601] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6687.706240] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6697.716397] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6707.726296] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6717.736550] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6727.747037] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6737.758234] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6757.779977] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6777.801425] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6797.822568] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6817.843387] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6837.865045] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6846.305752] audit: type=1130 audit(1602687524.721:184): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6856.902302] audit: type=1131 audit(1602687535.318:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6857.300516] iwlwifi 0000:00:14.3: Queue 3 is stuck 101 122
[ 6857.300668] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 6857.300761] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 6857.300766] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 6857.300770] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 6857.300775] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 6857.300778] iwlwifi 0000:00:14.3: 0x00802AF0 | trm_hw_status0
[ 6857.300781] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 6857.300784] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 6857.300787] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink1
[ 6857.300790] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink2
[ 6857.300793] iwlwifi 0000:00:14.3: 0x00006750 | data1
[ 6857.300796] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 6857.300799] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 6857.300802] iwlwifi 0000:00:14.3: 0x924186A6 | beacon time
[ 6857.300805] iwlwifi 0000:00:14.3: 0x68D58B96 | tsf low
[ 6857.300808] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 6857.300811] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 6857.300814] iwlwifi 0000:00:14.3: 0x101353E4 | time gp2
[ 6857.300817] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 6857.300820] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 6857.300823] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 6857.300826] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 6857.300829] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 6857.300832] iwlwifi 0000:00:14.3: 0x0365001C | hcmd
[ 6857.300835] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 6857.300838] iwlwifi 0000:00:14.3: 0x01000000 | isr1
[ 6857.300841] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 6857.300844] iwlwifi 0000:00:14.3: 0x00C34F4C | isr3
[ 6857.300847] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 6857.300850] iwlwifi 0000:00:14.3: 0x00BE019C | last cmd Id
[ 6857.300853] iwlwifi 0000:00:14.3: 0x00006750 | wait_event
[ 6857.300856] iwlwifi 0000:00:14.3: 0x00000080 | l2p_control
[ 6857.300859] iwlwifi 0000:00:14.3: 0x00002020 | l2p_duration
[ 6857.300862] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[ 6857.300865] iwlwifi 0000:00:14.3: 0x000000CE | l2p_addr_match
[ 6857.300868] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 6857.300870] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 6857.300873] iwlwifi 0000:00:14.3: 0x00005038 | flow_handler
[ 6857.300915] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 6857.300918] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 6857.300922] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 6857.300925] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 6857.300928] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 6857.300931] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 6857.300934] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 6857.300937] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 6857.300940] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 6857.300943] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 6857.300946] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 6857.300949] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 6857.300951] iwlwifi 0000:00:14.3: 0x101353E0 | frame pointer
[ 6857.300954] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 6857.300957] iwlwifi 0000:00:14.3: 0x00BE019C | last host cmd
[ 6857.300960] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 6857.300979] iwlwifi 0000:00:14.3: Fseq Registers:
[ 6857.301000] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 6857.301022] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 6857.301027] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 6857.301047] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 6857.301052] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 6857.301072] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 6857.301077] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 6857.301097] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 6857.301102] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 6857.301124] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 6857.301146] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 6857.301198] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 6857.301345] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 6857.301362] ieee80211 phy0: Hardware restart was requested
[ 6857.301407] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 6857.886993] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6877.908724] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6897.931216] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6917.952805] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6937.974259] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6957.996863] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6978.017332] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 6998.037862] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7012.245562] ACPI Error: No handler for Region [VRTC] (0000000030295a14) [SystemCMOS] (20200528/evregion-127)
[ 7012.245579] ACPI Error: Region SystemCMOS (ID=5) has no handler (20200528/exfldio-261)
[ 7012.245605] ACPI Error: Aborting method \_SB.PCI0.LPCB.EC._Q9A due to previous error (AE_NOT_EXIST) (20200528/psparse-529)
[ 7018.059330] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7038.081099] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7058.102321] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7078.122794] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7098.144606] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7118.166240] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7138.188473] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7158.210117] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7178.231589] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7198.252985] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7218.273404] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7238.295154] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7258.315600] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7278.338359] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7298.358625] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7318.381114] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7338.401300] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7358.422308] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7378.444677] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7398.465147] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7418.485638] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7438.508239] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7458.531829] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7478.553337] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7498.574755] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7518.596263] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7538.617879] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7558.640191] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7578.661793] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7598.682296] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7618.704776] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7638.725472] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7658.747784] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7678.768288] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7698.790710] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7718.812338] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7738.832869] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7746.792832] audit: type=1100 audit(1602688425.222:186): pid=14312 uid=1000 auid=1000 ses=5 subj==unconfined msg='op=PAM:unix_chkpwd acct="sergi" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
[ 7758.853915] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7767.152699] iwlwifi 0000:00:14.3: Queue 3 is stuck 235 250
[ 7767.152867] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 7767.152969] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7767.152974] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 7767.152977] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 7767.152981] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7767.152984] iwlwifi 0000:00:14.3: 0x0000AA10 | trm_hw_status0
[ 7767.152987] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 7767.152989] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 7767.152992] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink1
[ 7767.152994] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink2
[ 7767.152997] iwlwifi 0000:00:14.3: 0x0000B3EE | data1
[ 7767.153000] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 7767.153002] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 7767.153005] iwlwifi 0000:00:14.3: 0xAC011DAA | beacon time
[ 7767.153008] iwlwifi 0000:00:14.3: 0x9F10C496 | tsf low
[ 7767.153010] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 7767.153013] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 7767.153016] iwlwifi 0000:00:14.3: 0x3635A563 | time gp2
[ 7767.153018] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 7767.153021] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 7767.153024] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 7767.153026] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 7767.153029] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 7767.153031] iwlwifi 0000:00:14.3: 0x8010FC19 | hcmd
[ 7767.153034] iwlwifi 0000:00:14.3: 0xA4020000 | isr0
[ 7767.153036] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 7767.153039] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 7767.153042] iwlwifi 0000:00:14.3: 0x00C00018 | isr3
[ 7767.153044] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 7767.153047] iwlwifi 0000:00:14.3: 0x00A5019C | last cmd Id
[ 7767.153049] iwlwifi 0000:00:14.3: 0x0000B3EE | wait_event
[ 7767.153052] iwlwifi 0000:00:14.3: 0x000002C8 | l2p_control
[ 7767.153055] iwlwifi 0000:00:14.3: 0x00012034 | l2p_duration
[ 7767.153057] iwlwifi 0000:00:14.3: 0x000000BF | l2p_mhvalid
[ 7767.153060] iwlwifi 0000:00:14.3: 0x00000020 | l2p_addr_match
[ 7767.153062] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 7767.153065] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 7767.153068] iwlwifi 0000:00:14.3: 0x00008078 | flow_handler
[ 7767.153107] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7767.153110] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 7767.153113] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 7767.153116] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 7767.153118] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 7767.153121] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 7767.153124] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 7767.153126] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 7767.153129] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 7767.153132] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 7767.153134] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 7767.153137] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 7767.153139] iwlwifi 0000:00:14.3: 0x3635A55E | frame pointer
[ 7767.153142] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 7767.153145] iwlwifi 0000:00:14.3: 0x00A5019C | last host cmd
[ 7767.153147] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 7767.153165] iwlwifi 0000:00:14.3: Fseq Registers:
[ 7767.153184] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 7767.153189] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 7767.153210] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 7767.153214] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 7767.153235] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 7767.153239] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7767.153259] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 7767.153264] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 7767.153284] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 7767.153291] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 7767.153313] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7767.153364] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7767.153495] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 7767.153507] ieee80211 phy0: Hardware restart was requested
[ 7767.153563] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 7768.723168] audit: type=1111 audit(1602688447.156:187): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7770.930176] audit: type=1111 audit(1602688449.362:188): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=device-disconnect interface="wlo1" ifindex=2 pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7770.937775] audit: type=1111 audit(1602688449.369:189): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7770.940977] audit: type=1130 audit(1602688449.372:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7770.941972] wlo1: deauthenticating from e6:ab:89:8b:d0:88 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7772.942782] iwlwifi 0000:00:14.3: fail to flush all tx fifo queues Q 7
[ 7772.942791] iwlwifi 0000:00:14.3: Queue 7 is stuck 0 10
[ 7780.064388] audit: type=1111 audit(1602688458.496:191): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=76796d73-d8d0-4730-82e6-147bd0032e29 name="MOVISTAR_D07F" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7781.976281] wlo1: authenticate with e6:ab:89:8b:d0:88
[ 7781.978820] wlo1: send auth to e6:ab:89:8b:d0:88 (try 1/3)
[ 7782.005192] wlo1: authenticated
[ 7782.005852] wlo1: associate with e6:ab:89:8b:d0:88 (try 1/3)
[ 7782.009520] wlo1: RX AssocResp from e6:ab:89:8b:d0:88 (capab=0x511 status=0 aid=12)
[ 7782.013544] wlo1: associated
[ 7782.119030] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7782.177437] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by e6:ab:89:8b:d0:88
[ 7782.420865] audit: type=1111 audit(1602688460.852:192): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7787.142606] audit: type=1111 audit(1602688465.576:193): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7788.889202] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7792.538990] iwlwifi 0000:00:14.3: Queue 6 is stuck 1 40
[ 7792.539017] iwlwifi 0000:00:14.3: Queue 5 is stuck 1 3
[ 7792.539162] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 7792.539252] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7792.539256] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 7792.539260] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 7792.539264] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7792.539267] iwlwifi 0000:00:14.3: 0x000022F0 | trm_hw_status0
[ 7792.539270] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 7792.539273] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 7792.539275] iwlwifi 0000:00:14.3: 0x00013F06 | interruptlink1
[ 7792.539278] iwlwifi 0000:00:14.3: 0x00013F06 | interruptlink2
[ 7792.539280] iwlwifi 0000:00:14.3: 0x0000F9EE | data1
[ 7792.539283] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 7792.539286] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 7792.539288] iwlwifi 0000:00:14.3: 0x19C14081 | beacon time
[ 7792.539291] iwlwifi 0000:00:14.3: 0xA09421BB | tsf low
[ 7792.539294] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 7792.539296] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 7792.539299] iwlwifi 0000:00:14.3: 0x017D61F9 | time gp2
[ 7792.539302] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 7792.539304] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 7792.539307] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 7792.539310] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 7792.539312] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 7792.539315] iwlwifi 0000:00:14.3: 0x804DFC0F | hcmd
[ 7792.539318] iwlwifi 0000:00:14.3: 0x00020000 | isr0
[ 7792.539320] iwlwifi 0000:00:14.3: 0x00080000 | isr1
[ 7792.539323] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 7792.539325] iwlwifi 0000:00:14.3: 0x00C0000A | isr3
[ 7792.539327] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 7792.539330] iwlwifi 0000:00:14.3: 0x009E019C | last cmd Id
[ 7792.539333] iwlwifi 0000:00:14.3: 0x0000F9EE | wait_event
[ 7792.539336] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control
[ 7792.539338] iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
[ 7792.539341] iwlwifi 0000:00:14.3: 0x0000013F | l2p_mhvalid
[ 7792.539344] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 7792.539346] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 7792.539349] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 7792.539352] iwlwifi 0000:00:14.3: 0x0000F864 | flow_handler
[ 7792.539392] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7792.539395] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 7792.539398] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 7792.539401] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 7792.539404] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 7792.539406] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 7792.539409] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 7792.539412] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 7792.539414] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 7792.539417] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 7792.539419] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 7792.539422] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 7792.539425] iwlwifi 0000:00:14.3: 0x017D61F4 | frame pointer
[ 7792.539427] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 7792.539430] iwlwifi 0000:00:14.3: 0x009F010D | last host cmd
[ 7792.539432] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 7792.539451] iwlwifi 0000:00:14.3: Fseq Registers:
[ 7792.539471] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 7792.539476] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 7792.539495] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 7792.539500] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 7792.539520] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 7792.539524] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7792.539545] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 7792.539549] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 7792.539569] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 7792.539576] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 7792.539598] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7792.539650] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7792.539796] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 7792.539804] ieee80211 phy0: Hardware restart was requested
[ 7792.539847] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 7792.887103] audit: type=1131 audit(1602688471.319:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7794.376862] audit: type=1111 audit(1602688472.806:195): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7794.519817] audit: type=1130 audit(1602688472.949:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7796.087572] audit: type=1111 audit(1602688474.516:197): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=8b9c7ac8-e22d-4bf5-a866-8f57210fe2c0 name="MOVISTAR_PLUS_D07F" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7796.104180] wlo1: deauthenticating from e6:ab:89:8b:d0:88 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7796.127548] audit: type=1111 audit(1602688474.556:198): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7798.105668] iwlwifi 0000:00:14.3: fail to flush all tx fifo queues Q 6
[ 7798.105674] iwlwifi 0000:00:14.3: Queue 6 is stuck 0 3
[ 7812.890734] audit: type=1131 audit(1602688491.320:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7835.706269] wlo1: authenticate with e6:ab:89:8b:d0:88
[ 7835.708881] wlo1: send auth to e6:ab:89:8b:d0:88 (try 1/3)
[ 7835.733439] wlo1: authenticated
[ 7835.734929] wlo1: associate with e6:ab:89:8b:d0:88 (try 1/3)
[ 7835.738455] wlo1: RX AssocResp from e6:ab:89:8b:d0:88 (capab=0x511 status=0 aid=12)
[ 7835.742602] wlo1: associated
[ 7835.834583] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by e6:ab:89:8b:d0:88
[ 7835.853875] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7837.990775] audit: type=1111 audit(1602688516.420:200): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=f2483d89-3a94-41bf-bc58-137474de318e name=48554157454920503230206C697465 pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7838.023642] audit: type=1130 audit(1602688516.453:201): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7838.025775] wlo1: deauthenticating from e6:ab:89:8b:d0:88 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7839.982916] wlo1: authenticate with e4:a7:c5:45:c0:74
[ 7839.984905] wlo1: send auth to e4:a7:c5:45:c0:74 (try 1/3)
[ 7840.038056] wlo1: authenticated
[ 7840.044791] wlo1: associate with e4:a7:c5:45:c0:74 (try 1/3)
[ 7840.068019] wlo1: RX AssocResp from e4:a7:c5:45:c0:74 (capab=0x1631 status=0 aid=3)
[ 7840.071040] wlo1: associated
[ 7840.092909] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7840.099987] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by e4:a7:c5:45:c0:74
[ 7842.487784] audit: type=1111 audit(1602688520.917:202): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7844.868701] audit: type=1111 audit(1602688523.300:203): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=76796d73-d8d0-4730-82e6-147bd0032e29 name="MOVISTAR_D07F" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7844.878555] wlo1: deauthenticating from e4:a7:c5:45:c0:74 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7849.885829] audit: type=1111 audit(1602688528.317:204): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7849.916805] wlo1: authenticate with e6:ab:89:8b:d0:88
[ 7849.919406] wlo1: send auth to e6:ab:89:8b:d0:88 (try 1/3)
[ 7849.944556] wlo1: authenticated
[ 7849.947975] wlo1: associate with e6:ab:89:8b:d0:88 (try 1/3)
[ 7849.950890] wlo1: RX AssocResp from e6:ab:89:8b:d0:88 (capab=0x511 status=0 aid=13)
[ 7849.954349] wlo1: associated
[ 7849.965790] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by e6:ab:89:8b:d0:88
[ 7850.078925] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7860.164672] iwlwifi 0000:00:14.3: Queue 6 is stuck 0 15
[ 7860.164726] iwlwifi 0000:00:14.3: Queue 5 is stuck 0 4
[ 7860.164880] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 7860.164975] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7860.164981] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 7860.164985] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 7860.164991] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7860.164994] iwlwifi 0000:00:14.3: 0x00802AF4 | trm_hw_status0
[ 7860.164998] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 7860.165002] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 7860.165005] iwlwifi 0000:00:14.3: 0x004C4AD6 | interruptlink1
[ 7860.165009] iwlwifi 0000:00:14.3: 0x004C4AD6 | interruptlink2
[ 7860.165013] iwlwifi 0000:00:14.3: 0x00006750 | data1
[ 7860.165017] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 7860.165020] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 7860.165023] iwlwifi 0000:00:14.3: 0x19009D9D | beacon time
[ 7860.165026] iwlwifi 0000:00:14.3: 0xA49C049E | tsf low
[ 7860.165030] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 7860.165033] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 7860.165036] iwlwifi 0000:00:14.3: 0x0401ED2D | time gp2
[ 7860.165040] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 7860.165043] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 7860.165046] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 7860.165050] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 7860.165053] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 7860.165056] iwlwifi 0000:00:14.3: 0x0500001C | hcmd
[ 7860.165060] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 7860.165063] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 7860.165067] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 7860.165070] iwlwifi 0000:00:14.3: 0x00C30ACD | isr3
[ 7860.165073] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 7860.165077] iwlwifi 0000:00:14.3: 0x0045019C | last cmd Id
[ 7860.165081] iwlwifi 0000:00:14.3: 0x00006750 | wait_event
[ 7860.165085] iwlwifi 0000:00:14.3: 0x00000080 | l2p_control
[ 7860.165088] iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
[ 7860.165092] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[ 7860.165096] iwlwifi 0000:00:14.3: 0x00000080 | l2p_addr_match
[ 7860.165099] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 7860.165102] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 7860.165106] iwlwifi 0000:00:14.3: 0x000048F4 | flow_handler
[ 7860.165148] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7860.165152] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 7860.165155] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 7860.165159] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 7860.165162] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 7860.165164] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 7860.165171] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 7860.165177] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 7860.165180] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 7860.165183] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 7860.165185] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 7860.165189] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 7860.165192] iwlwifi 0000:00:14.3: 0x0401ED29 | frame pointer
[ 7860.165196] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 7860.165200] iwlwifi 0000:00:14.3: 0x004B011D | last host cmd
[ 7860.165203] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 7860.165224] iwlwifi 0000:00:14.3: Fseq Registers:
[ 7860.165244] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 7860.165266] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 7860.165287] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 7860.165309] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 7860.165314] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 7860.165334] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7860.165339] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 7860.165360] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 7860.165381] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 7860.165388] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 7860.165411] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7860.165463] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7860.165614] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 7860.165630] ieee80211 phy0: Hardware restart was requested
[ 7860.165678] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 7863.271519] audit: type=1111 audit(1602688541.704:205): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=8b9c7ac8-e22d-4bf5-a866-8f57210fe2c0 name="MOVISTAR_PLUS_D07F" pid=13518 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7863.278985] wlo1: deauthenticating from e6:ab:89:8b:d0:88 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7864.387010] audit: type=1701 audit(1602688542.817:206): auid=1000 uid=1000 gid=1000 ses=5 subj==unconfined pid=13518 comm="QSGRenderThread" exe="/usr/bin/plasmashell" sig=11 res=1
[ 7864.415456] audit: type=1334 audit(1602688542.847:207): prog-id=20 op=LOAD
[ 7864.415519] audit: type=1334 audit(1602688542.847:208): prog-id=21 op=LOAD
[ 7864.416461] audit: type=1130 audit(1602688542.847:209): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-15412-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7866.654885] audit: type=1131 audit(1602688545.087:210): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@1-15412-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7866.803799] audit: type=1334 audit(1602688545.234:211): prog-id=21 op=UNLOAD
[ 7866.803803] audit: type=1334 audit(1602688545.234:212): prog-id=20 op=UNLOAD
[ 7869.906403] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 7869.908473] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 7869.978108] wlo1: authenticated
[ 7869.980939] wlo1: associate with e4:ab:89:8b:d0:88 (try 1/3)
[ 7869.983853] wlo1: RX AssocResp from e4:ab:89:8b:d0:88 (capab=0x511 status=0 aid=14)
[ 7869.987091] wlo1: associated
[ 7870.036174] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by e4:ab:89:8b:d0:88
[ 7870.094339] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7873.889687] audit: type=1131 audit(1602688552.321:213): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7877.642629] audit: type=1130 audit(1602688556.074:214): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7879.165890] audit: type=1111 audit(1602688557.597:215): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=15410 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7883.530019] audit: type=1111 audit(1602688561.961:216): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=15410 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7889.886373] audit: type=1131 audit(1602688568.318:217): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7909.017644] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7915.982861] SGI_video_sync[15996]: segfault at e6 ip 00005573fb110112 sp 00007f66fb7fc740 error 6 in teams[5573f8629000+4bf9000]
[ 7915.982867] Code: e8 43 00 00 00 4c 89 f7 e8 db 01 00 00 41 8b 46 10 41 8b 4e 18 c1 e0 0c 25 00 f0 0f 00 c1 e1 14 81 e1 00 00 f0 0f 09 c1 09 d9 <c6> 01 00 81 e3 ff 0f 00 00 c6 03 00 bf 01 00 00 00 e8 f8 d4 10 02
[ 7915.982915] audit: type=1701 audit(1602688594.415:218): auid=1000 uid=1000 gid=1000 ses=5 subj==unconfined pid=15945 comm="SGI_video_sync" exe="/usr/share/teams/teams" sig=11 res=1
[ 7915.991167] audit: type=1334 audit(1602688594.425:219): prog-id=22 op=LOAD
[ 7915.991244] audit: type=1334 audit(1602688594.425:220): prog-id=23 op=LOAD
[ 7915.992147] audit: type=1130 audit(1602688594.425:221): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@2-15997-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7916.380784] SGI_video_sync[16011]: segfault at e6 ip 00005651f64a8112 sp 00007f13cfffd740 error 6 in teams[5651f39c1000+4bf9000]
[ 7916.380792] Code: e8 43 00 00 00 4c 89 f7 e8 db 01 00 00 41 8b 46 10 41 8b 4e 18 c1 e0 0c 25 00 f0 0f 00 c1 e1 14 81 e1 00 00 f0 0f 09 c1 09 d9 <c6> 01 00 81 e3 ff 0f 00 00 c6 03 00 bf 01 00 00 00 e8 f8 d4 10 02
[ 7916.380837] audit: type=1701 audit(1602688594.815:222): auid=1000 uid=1000 gid=1000 ses=5 subj==unconfined pid=15999 comm="SGI_video_sync" exe="/usr/share/teams/teams" sig=11 res=1
[ 7916.394856] audit: type=1334 audit(1602688594.828:223): prog-id=24 op=LOAD
[ 7916.394859] audit: type=1334 audit(1602688594.828:224): prog-id=25 op=LOAD
[ 7916.395696] audit: type=1130 audit(1602688594.828:225): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@3-16015-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7919.028909] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7925.870093] iwlwifi 0000:00:14.3: Queue 6 is stuck 174 207
[ 7925.870264] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 7925.870355] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7925.870360] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 7925.870363] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 7925.870368] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7925.870372] iwlwifi 0000:00:14.3: 0x00802AF4 | trm_hw_status0
[ 7925.870374] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 7925.870377] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 7925.870379] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink1
[ 7925.870382] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink2
[ 7925.870385] iwlwifi 0000:00:14.3: 0x00006750 | data1
[ 7925.870388] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 7925.870390] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 7925.870393] iwlwifi 0000:00:14.3: 0x88812567 | beacon time
[ 7925.870396] iwlwifi 0000:00:14.3: 0xA8869A6F | tsf low
[ 7925.870398] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 7925.870401] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 7925.870404] iwlwifi 0000:00:14.3: 0x03E4B255 | time gp2
[ 7925.870406] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 7925.870409] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 7925.870412] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 7925.870414] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 7925.870417] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 7925.870420] iwlwifi 0000:00:14.3: 0x06AE001C | hcmd
[ 7925.870422] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 7925.870425] iwlwifi 0000:00:14.3: 0x00400000 | isr1
[ 7925.870427] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 7925.870430] iwlwifi 0000:00:14.3: 0x00C35F0C | isr3
[ 7925.870432] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 7925.870435] iwlwifi 0000:00:14.3: 0x00E7019C | last cmd Id
[ 7925.870437] iwlwifi 0000:00:14.3: 0x00006750 | wait_event
[ 7925.870440] iwlwifi 0000:00:14.3: 0x00000080 | l2p_control
[ 7925.870443] iwlwifi 0000:00:14.3: 0x00002020 | l2p_duration
[ 7925.870445] iwlwifi 0000:00:14.3: 0x0000003F | l2p_mhvalid
[ 7925.870448] iwlwifi 0000:00:14.3: 0x00000080 | l2p_addr_match
[ 7925.870450] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 7925.870453] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 7925.870455] iwlwifi 0000:00:14.3: 0x00004848 | flow_handler
[ 7925.870495] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7925.870498] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 7925.870502] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 7925.870504] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 7925.870507] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 7925.870510] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 7925.870512] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 7925.870515] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 7925.870518] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 7925.870520] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 7925.870523] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 7925.870525] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 7925.870528] iwlwifi 0000:00:14.3: 0x03E4B251 | frame pointer
[ 7925.870530] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 7925.870533] iwlwifi 0000:00:14.3: 0x00E7019C | last host cmd
[ 7925.870536] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 7925.870554] iwlwifi 0000:00:14.3: Fseq Registers:
[ 7925.870574] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 7925.870579] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 7925.870599] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 7925.870603] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 7925.870623] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 7925.870627] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7925.870647] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 7925.870651] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 7925.870671] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 7925.870678] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 7925.870700] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7925.870752] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7925.870878] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 7925.870890] ieee80211 phy0: Hardware restart was requested
[ 7925.870935] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 7929.036489] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7936.963296] iwlwifi 0000:00:14.3: Queue 3 is stuck 0 67
[ 7936.963467] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 7936.963555] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7936.963560] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 7936.963563] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 7936.963567] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7936.963570] iwlwifi 0000:00:14.3: 0x00802AF0 | trm_hw_status0
[ 7936.963573] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 7936.963576] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 7936.963578] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink1
[ 7936.963581] iwlwifi 0000:00:14.3: 0x004B31CC | interruptlink2
[ 7936.963583] iwlwifi 0000:00:14.3: 0x00006750 | data1
[ 7936.963586] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 7936.963589] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 7936.963591] iwlwifi 0000:00:14.3: 0x1980A08A | beacon time
[ 7936.963594] iwlwifi 0000:00:14.3: 0xA92FDF4C | tsf low
[ 7936.963597] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 7936.963599] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 7936.963602] iwlwifi 0000:00:14.3: 0x00A3719B | time gp2
[ 7936.963605] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 7936.963607] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 7936.963610] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 7936.963613] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 7936.963615] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 7936.963618] iwlwifi 0000:00:14.3: 0x0300001C | hcmd
[ 7936.963621] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 7936.963623] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 7936.963626] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 7936.963628] iwlwifi 0000:00:14.3: 0x00C37FCC | isr3
[ 7936.963631] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 7936.963633] iwlwifi 0000:00:14.3: 0x004D019C | last cmd Id
[ 7936.963636] iwlwifi 0000:00:14.3: 0x00006750 | wait_event
[ 7936.963639] iwlwifi 0000:00:14.3: 0x00000148 | l2p_control
[ 7936.963641] iwlwifi 0000:00:14.3: 0x00002020 | l2p_duration
[ 7936.963644] iwlwifi 0000:00:14.3: 0x00000003 | l2p_mhvalid
[ 7936.963646] iwlwifi 0000:00:14.3: 0x00000090 | l2p_addr_match
[ 7936.963649] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 7936.963651] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 7936.963654] iwlwifi 0000:00:14.3: 0x00006810 | flow_handler
[ 7936.963695] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7936.963698] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 7936.963701] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 7936.963704] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 7936.963706] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 7936.963709] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 7936.963712] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 7936.963714] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 7936.963717] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 7936.963719] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 7936.963722] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 7936.963725] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 7936.963727] iwlwifi 0000:00:14.3: 0x00A37197 | frame pointer
[ 7936.963730] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 7936.963733] iwlwifi 0000:00:14.3: 0x004D019C | last host cmd
[ 7936.963735] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 7936.963754] iwlwifi 0000:00:14.3: Fseq Registers:
[ 7936.963774] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 7936.963779] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 7936.963799] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 7936.963803] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 7936.963823] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 7936.963828] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7936.963848] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 7936.963853] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 7936.963873] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 7936.963880] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 7936.963902] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7936.963954] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7936.964081] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 7936.964092] ieee80211 phy0: Hardware restart was requested
[ 7936.964136] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 7939.046730] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7943.095106] kauditd_printk_skb: 6 callbacks suppressed
[ 7943.095112] audit: type=1111 audit(1602688621.528:232): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=15410 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7949.058100] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 7949.578619] audit: type=1111 audit(1602688628.012:233): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=76796d73-d8d0-4730-82e6-147bd0032e29 name="MOVISTAR_D07F" pid=15410 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7949.601120] audit: type=1130 audit(1602688628.035:234): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7949.602237] wlo1: deauthenticating from e4:ab:89:8b:d0:88 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7949.615348] audit: type=1111 audit(1602688628.048:235): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=15410 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7954.617091] wlo1: authenticate with e6:ab:89:8b:d0:88
[ 7954.620060] wlo1: send auth to e6:ab:89:8b:d0:88 (try 1/3)
[ 7954.645033] wlo1: authenticated
[ 7954.646211] wlo1: associate with e6:ab:89:8b:d0:88 (try 1/3)
[ 7954.649071] wlo1: RX AssocResp from e6:ab:89:8b:d0:88 (capab=0x511 status=0 aid=15)
[ 7954.651574] wlo1: associated
[ 7954.720796] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by e6:ab:89:8b:d0:88
[ 7954.778802] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7965.762900] iwlwifi 0000:00:14.3: Queue 6 is stuck 1 18
[ 7965.763071] iwlwifi 0000:00:14.3: Microcode SW error detected. Restarting 0x0.
[ 7965.763159] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7965.763163] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 6
[ 7965.763167] iwlwifi 0000:00:14.3: Loaded firmware version: 55.d9698065.0 QuZ-a0-jf-b0-55.ucode
[ 7965.763171] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN
[ 7965.763174] iwlwifi 0000:00:14.3: 0x00802AF4 | trm_hw_status0
[ 7965.763177] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1
[ 7965.763180] iwlwifi 0000:00:14.3: 0x004C3DFE | branchlink2
[ 7965.763182] iwlwifi 0000:00:14.3: 0x0001F054 | interruptlink1
[ 7965.763185] iwlwifi 0000:00:14.3: 0x0001F054 | interruptlink2
[ 7965.763188] iwlwifi 0000:00:14.3: 0x00006750 | data1
[ 7965.763190] iwlwifi 0000:00:14.3: 0xFF000000 | data2
[ 7965.763193] iwlwifi 0000:00:14.3: 0x00000000 | data3
[ 7965.763196] iwlwifi 0000:00:14.3: 0x1AC0406F | beacon time
[ 7965.763198] iwlwifi 0000:00:14.3: 0xAAE751CE | tsf low
[ 7965.763201] iwlwifi 0000:00:14.3: 0x000001F6 | tsf hi
[ 7965.763204] iwlwifi 0000:00:14.3: 0x00000000 | time gp1
[ 7965.763206] iwlwifi 0000:00:14.3: 0x01B18F0D | time gp2
[ 7965.763209] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type
[ 7965.763212] iwlwifi 0000:00:14.3: 0x00000037 | uCode version major
[ 7965.763214] iwlwifi 0000:00:14.3: 0xD9698065 | uCode version minor
[ 7965.763217] iwlwifi 0000:00:14.3: 0x00000351 | hw version
[ 7965.763220] iwlwifi 0000:00:14.3: 0x00489004 | board version
[ 7965.763222] iwlwifi 0000:00:14.3: 0x0501001C | hcmd
[ 7965.763225] iwlwifi 0000:00:14.3: 0x80020000 | isr0
[ 7965.763228] iwlwifi 0000:00:14.3: 0x00000000 | isr1
[ 7965.763230] iwlwifi 0000:00:14.3: 0x08F00002 | isr2
[ 7965.763233] iwlwifi 0000:00:14.3: 0x00C347CD | isr3
[ 7965.763235] iwlwifi 0000:00:14.3: 0x00000000 | isr4
[ 7965.763238] iwlwifi 0000:00:14.3: 0x00A8019C | last cmd Id
[ 7965.763240] iwlwifi 0000:00:14.3: 0x00006750 | wait_event
[ 7965.763243] iwlwifi 0000:00:14.3: 0x000000D4 | l2p_control
[ 7965.763245] iwlwifi 0000:00:14.3: 0x00000020 | l2p_duration
[ 7965.763248] iwlwifi 0000:00:14.3: 0x00000007 | l2p_mhvalid
[ 7965.763250] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match
[ 7965.763253] iwlwifi 0000:00:14.3: 0x00000009 | lmpm_pmg_sel
[ 7965.763256] iwlwifi 0000:00:14.3: 0x00000000 | timestamp
[ 7965.763258] iwlwifi 0000:00:14.3: 0x000058D0 | flow_handler
[ 7965.763298] iwlwifi 0000:00:14.3: Start IWL Error Log Dump:
[ 7965.763301] iwlwifi 0000:00:14.3: Status: 0x00000040, count: 7
[ 7965.763304] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST
[ 7965.763307] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1
[ 7965.763310] iwlwifi 0000:00:14.3: 0x80461F16 | umac branchlink2
[ 7965.763312] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink1
[ 7965.763315] iwlwifi 0000:00:14.3: 0x8047CB2C | umac interruptlink2
[ 7965.763318] iwlwifi 0000:00:14.3: 0x01000000 | umac data1
[ 7965.763320] iwlwifi 0000:00:14.3: 0x8047CB2C | umac data2
[ 7965.763323] iwlwifi 0000:00:14.3: 0x00000000 | umac data3
[ 7965.763325] iwlwifi 0000:00:14.3: 0x00000037 | umac major
[ 7965.763328] iwlwifi 0000:00:14.3: 0xD9698065 | umac minor
[ 7965.763330] iwlwifi 0000:00:14.3: 0x01B18F08 | frame pointer
[ 7965.763333] iwlwifi 0000:00:14.3: 0xC0886270 | stack pointer
[ 7965.763336] iwlwifi 0000:00:14.3: 0x00AC010C | last host cmd
[ 7965.763338] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg
[ 7965.763357] iwlwifi 0000:00:14.3: Fseq Registers:
[ 7965.763378] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE
[ 7965.763382] iwlwifi 0000:00:14.3: 0x80260000 | FSEQ_TOP_INIT_VERSION
[ 7965.763403] iwlwifi 0000:00:14.3: 0x00020006 | FSEQ_CNVIO_INIT_VERSION
[ 7965.763407] iwlwifi 0000:00:14.3: 0x0000A384 | FSEQ_OTP_VERSION
[ 7965.763427] iwlwifi 0000:00:14.3: 0xE8F10C95 | FSEQ_TOP_CONTENT_VERSION
[ 7965.763432] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN
[ 7965.763452] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID
[ 7965.763456] iwlwifi 0000:00:14.3: 0x01300202 | FSEQ_CNVR_ID
[ 7965.763477] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP
[ 7965.763483] iwlwifi 0000:00:14.3: 0x01300202 | CNVR_AUX_MISC_CHIP
[ 7965.763506] iwlwifi 0000:00:14.3: 0x0000485B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM
[ 7965.763558] iwlwifi 0000:00:14.3: 0xA5A5A5A2 | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR
[ 7965.763699] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 5 fired.
[ 7965.763709] ieee80211 phy0: Hardware restart was requested
[ 7965.763752] iwlwifi 0000:00:14.3: Hardware error detected. Restarting.
[ 7968.889131] audit: type=1131 audit(1602688647.322:236): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7972.341888] audit: type=1106 audit(1602688650.776:237): pid=13397 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="sergi" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 7972.341953] audit: type=1104 audit(1602688650.776:238): pid=13397 uid=0 auid=1000 ses=5 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="sergi" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 7972.373569] audit: type=1130 audit(1602688650.809:239): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7972.376324] wlo1: deauthenticating from e6:ab:89:8b:d0:88 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 7974.379409] iwlwifi 0000:00:14.3: fail to flush all tx fifo queues Q 6
[ 7974.379416] iwlwifi 0000:00:14.3: Queue 6 is stuck 0 4
[ 7974.405013] audit: type=1701 audit(1602688652.839:240): auid=1000 uid=1000 gid=1000 ses=3 subj==unconfined pid=16239 comm="kglobalaccel5" exe="/usr/bin/kglobalaccel5" sig=6 res=1
[ 7974.415004] audit: type=1334 audit(1602688652.849:241): prog-id=26 op=LOAD
[ 7974.415037] audit: type=1334 audit(1602688652.849:242): prog-id=27 op=LOAD
[ 7974.415685] audit: type=1130 audit(1602688652.849:243): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-16245-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7974.680403] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 7974.702798] audit: type=1131 audit(1602688653.139:244): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@4-16245-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7974.716193] nvidia-modeset: Unloading
[ 7974.963039] audit: type=1334 audit(1602688653.399:245): prog-id=27 op=UNLOAD
[ 7974.963048] audit: type=1334 audit(1602688653.399:246): prog-id=26 op=UNLOAD
[ 7975.439573] nvidia 0000:01:00.0: Enabling HDA controller
[ 7975.474577] nvidia-nvlink: Unregistered the Nvlink Core, major device number 234
[ 7976.871314] audit: type=1100 audit(1602688655.306:247): pid=16306 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7976.871318] audit: type=1101 audit(1602688655.306:248): pid=16306 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7976.871506] audit: type=1103 audit(1602688655.306:249): pid=16306 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7981.844612] kauditd_printk_skb: 9 callbacks suppressed
[ 7981.844613] audit: type=1100 audit(1602688660.279:259): pid=16331 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="sergi" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7981.845796] audit: type=1101 audit(1602688660.282:260): pid=16331 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_permit,pam_time acct="sergi" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7981.846178] audit: type=1103 audit(1602688660.282:261): pid=16331 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="sergi" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[ 7981.846257] audit: type=1006 audit(1602688660.282:262): pid=16331 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=7 res=1
[ 7981.924791] audit: type=1105 audit(1602688660.359:263): pid=16331 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_kwallet5 acct="sergi" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 7981.957434] audit: type=1106 audit(1602688660.392:264): pid=16306 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 7981.957520] audit: type=1104 audit(1602688660.392:265): pid=16306 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
[ 7984.888482] audit: type=1131 audit(1602688663.322:266): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7985.168906] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 7985.171142] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 7985.295828] wlo1: send auth to e4:ab:89:8b:d0:88 (try 2/3)
[ 7985.399134] wlo1: send auth to e4:ab:89:8b:d0:88 (try 3/3)
[ 7985.502708] wlo1: authentication with e4:ab:89:8b:d0:88 timed out
[ 7987.467400] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 7987.469692] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 7987.639123] wlo1: send auth to e4:ab:89:8b:d0:88 (try 2/3)
[ 7987.745877] wlo1: send auth to e4:ab:89:8b:d0:88 (try 3/3)
[ 7987.849113] wlo1: authentication with e4:ab:89:8b:d0:88 timed out
[ 7989.213033] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 7989.216132] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 7989.385740] wlo1: send auth to e4:ab:89:8b:d0:88 (try 2/3)
[ 7989.489103] wlo1: send auth to e4:ab:89:8b:d0:88 (try 3/3)
[ 7989.592532] wlo1: authentication with e4:ab:89:8b:d0:88 timed out
[ 7991.244801] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 7991.247846] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 7991.415842] wlo1: send auth to e4:ab:89:8b:d0:88 (try 2/3)
[ 7991.519062] wlo1: send auth to e4:ab:89:8b:d0:88 (try 3/3)
[ 7991.622471] wlo1: authentication with e4:ab:89:8b:d0:88 timed out
[ 7992.009355] audit: type=1131 audit(1602688670.446:267): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7992.017133] audit: type=1131 audit(1602688670.453:268): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@968 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8001.721935] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 8001.727806] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 8001.855659] wlo1: send auth to e4:ab:89:8b:d0:88 (try 2/3)
[ 8001.958887] wlo1: send auth to e4:ab:89:8b:d0:88 (try 3/3)
[ 8002.062219] wlo1: authentication with e4:ab:89:8b:d0:88 timed out
[ 8014.630048] wlo1: authenticate with e4:ab:89:8b:d0:88
[ 8014.633846] wlo1: send auth to e4:ab:89:8b:d0:88 (try 1/3)
[ 8014.761921] wlo1: send auth to e4:ab:89:8b:d0:88 (try 2/3)
[ 8014.865268] wlo1: send auth to e4:ab:89:8b:d0:88 (try 3/3)
[ 8014.968701] wlo1: authentication with e4:ab:89:8b:d0:88 timed out
[ 8016.881614] audit: type=1111 audit(1602688695.313:269): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=76796d73-d8d0-4730-82e6-147bd0032e29 name="MOVISTAR_D07F" pid=16445 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 8016.909933] audit: type=1130 audit(1602688695.343:270): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8018.901249] wlo1: authenticate with e6:ab:89:8b:d0:88
[ 8018.904974] wlo1: send auth to e6:ab:89:8b:d0:88 (try 1/3)
[ 8018.931322] wlo1: authenticated
[ 8018.935260] wlo1: associate with e6:ab:89:8b:d0:88 (try 1/3)
[ 8018.938863] wlo1: RX AssocResp from e6:ab:89:8b:d0:88 (capab=0x511 status=0 aid=15)
[ 8018.942731] wlo1: associated
[ 8019.028358] wlo1: Limiting TX power to 23 (23 - 0) dBm as advertised by e6:ab:89:8b:d0:88
[ 8019.060234] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 8019.314886] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=2478 DF PROTO=TCP SPT=443 DPT=53436 WINDOW=110 RES=0x00 ACK PSH URGP=0
[ 8019.314984] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=9694 DF PROTO=TCP SPT=443 DPT=53432 WINDOW=114 RES=0x00 ACK PSH URGP=0
[ 8019.315756] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=9695 DF PROTO=TCP SPT=443 DPT=53432 WINDOW=114 RES=0x00 ACK PSH URGP=0
[ 8019.376301] audit: type=1111 audit(1602688697.810:271): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=16445 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 8021.263433] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=9696 DF PROTO=TCP SPT=443 DPT=53432 WINDOW=114 RES=0x00 ACK PSH URGP=0
[ 8023.563302] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=2479 DF PROTO=TCP SPT=443 DPT=53436 WINDOW=110 RES=0x00 ACK PSH URGP=0
[ 8024.199572] audit: type=1111 audit(1602688702.633:272): pid=818 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=16445 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 8025.615262] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=9697 DF PROTO=TCP SPT=443 DPT=53432 WINDOW=114 RES=0x00 ACK PSH URGP=0
[ 8029.153393] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8029.888250] audit: type=1131 audit(1602688708.320:273): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8052.491020] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=54.226.103.235 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=239 ID=9699 DF PROTO=TCP SPT=443 DPT=53432 WINDOW=114 RES=0x00 ACK PSH URGP=0
[ 8074.957561] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=91 TOS=0x00 PREC=0x20 TTL=53 ID=54308 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK PSH URGP=0
[ 8075.109224] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x20 TTL=53 ID=54311 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK FIN URGP=0
[ 8075.425357] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=115 TOS=0x00 PREC=0x20 TTL=53 ID=54312 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK PSH FIN URGP=0
[ 8076.001012] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=115 TOS=0x00 PREC=0x20 TTL=53 ID=54313 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK PSH FIN URGP=0
[ 8077.153120] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=115 TOS=0x00 PREC=0x20 TTL=53 ID=54314 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK PSH FIN URGP=0
[ 8079.202520] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8084.156979] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=115 TOS=0x00 PREC=0x20 TTL=53 ID=54316 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK PSH FIN URGP=0
[ 8093.372946] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=185.59.220.2 DST=192.168.1.42 LEN=115 TOS=0x00 PREC=0x20 TTL=53 ID=54317 DF PROTO=TCP SPT=443 DPT=53428 WINDOW=126 RES=0x00 ACK PSH FIN URGP=0
[ 8119.244567] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8128.199868] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=13.32.90.218 DST=192.168.1.42 LEN=91 TOS=0x00 PREC=0x00 TTL=244 ID=58271 PROTO=TCP SPT=443 DPT=59144 WINDOW=118 RES=0x00 ACK PSH URGP=0
[ 8128.230599] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=13.32.90.119 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x00 TTL=244 ID=14203 PROTO=TCP SPT=443 DPT=35332 WINDOW=118 RES=0x00 ACK FIN URGP=0
[ 8128.232118] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.217.21.10 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x20 TTL=118 ID=4464 PROTO=TCP SPT=443 DPT=49960 WINDOW=261 RES=0x00 ACK FIN URGP=0
[ 8128.232137] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.217.21.10 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x20 TTL=118 ID=64156 PROTO=TCP SPT=443 DPT=49958 WINDOW=261 RES=0x00 ACK FIN URGP=0
[ 8128.232549] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=13.32.90.190 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x00 TTL=244 ID=59091 PROTO=TCP SPT=443 DPT=49252 WINDOW=118 RES=0x00 ACK FIN URGP=0
[ 8128.236956] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.217.21.10 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x20 TTL=118 ID=39236 PROTO=TCP SPT=443 DPT=49956 WINDOW=261 RES=0x00 ACK FIN URGP=0
[ 8128.245338] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=13.32.90.218 DST=192.168.1.42 LEN=52 TOS=0x00 PREC=0x00 TTL=244 ID=58297 PROTO=TCP SPT=443 DPT=59144 WINDOW=118 RES=0x00 ACK FIN URGP=0
[ 8135.942606] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.217.21.10 DST=192.168.1.42 LEN=108 TOS=0x00 PREC=0x20 TTL=118 ID=9073 PROTO=TCP SPT=443 DPT=49960 WINDOW=261 RES=0x00 ACK PSH FIN URGP=0
[ 8137.863092] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=13.33.234.123 DST=192.168.1.42 LEN=91 TOS=0x00 PREC=0x00 TTL=244 ID=38874 PROTO=TCP SPT=443 DPT=57394 WINDOW=149 RES=0x00 ACK PSH URGP=0
[ 8155.455604] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=130.211.26.229 DST=192.168.1.42 LEN=108 TOS=0x00 PREC=0x00 TTL=121 ID=35722 PROTO=TCP SPT=443 DPT=38858 WINDOW=318 RES=0x00 ACK PSH FIN URGP=0
[ 8176.923406] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.217.19.42 DST=192.168.1.42 LEN=108 TOS=0x00 PREC=0x20 TTL=55 ID=45785 PROTO=TCP SPT=443 DPT=56580 WINDOW=261 RES=0x00 ACK PSH FIN URGP=0
[ 8179.319365] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8189.320089] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8199.336479] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8206.680097] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=84.88.26.169 DST=192.168.1.42 LEN=40 TOS=0x00 PREC=0x00 TTL=248 ID=30641 DF PROTO=TCP SPT=443 DPT=54502 WINDOW=0 RES=0x00 ACK RST URGP=0
[ 8249.384590] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8259.392583] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8279.413409] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8288.867554] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.64.100.2 DST=192.168.1.42 LEN=79 TOS=0x00 PREC=0x20 TTL=54 ID=40818 DF PROTO=TCP SPT=443 DPT=44642 WINDOW=67 RES=0x00 ACK PSH URGP=0
[ 8289.648497] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.67.38.224 DST=192.168.1.42 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=13136 DF PROTO=TCP SPT=443 DPT=34762 WINDOW=93 RES=0x00 ACK FIN URGP=0
[ 8289.720786] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.67.38.224 DST=192.168.1.42 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=13137 DF PROTO=TCP SPT=443 DPT=34762 WINDOW=93 RES=0x00 ACK FIN URGP=0
[ 8289.910784] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=172.67.38.224 DST=192.168.1.42 LEN=103 TOS=0x00 PREC=0x00 TTL=57 ID=13138 DF PROTO=TCP SPT=443 DPT=34762 WINDOW=93 RES=0x00 ACK PSH FIN URGP=0
[ 8290.344999] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.18.158.66 DST=192.168.1.42 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=18393 DF PROTO=TCP SPT=443 DPT=55240 WINDOW=159 RES=0x00 ACK FIN URGP=0
[ 8296.764528] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.16.65.85 DST=192.168.1.42 LEN=40 TOS=0x00 PREC=0x00 TTL=57 ID=30221 DF PROTO=TCP SPT=443 DPT=56296 WINDOW=200 RES=0x00 ACK FIN URGP=0
[ 8299.433731] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8319.465201] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8349.498918] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8409.570908] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8419.576237] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8449.612642] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8459.623065] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8499.664556] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8500.517067] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.132.176 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=3334 DF PROTO=TCP SPT=443 DPT=36598 WINDOW=63 RES=0x00 ACK PSH URGP=0
[ 8500.569650] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.134.217 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=24106 DF PROTO=TCP SPT=443 DPT=50104 WINDOW=56 RES=0x00 ACK PSH URGP=0
[ 8500.976081] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.140 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=44724 DF PROTO=TCP SPT=443 DPT=33150 WINDOW=56 RES=0x00 ACK PSH URGP=0
[ 8501.224135] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.132.176 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=3338 DF PROTO=TCP SPT=443 DPT=36598 WINDOW=63 RES=0x00 ACK PSH FIN URGP=0
[ 8501.240550] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.2 DST=192.168.1.42 LEN=103 TOS=0x00 PREC=0x00 TTL=57 ID=40529 DF PROTO=TCP SPT=443 DPT=50246 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8501.244288] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.140 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=44727 DF PROTO=TCP SPT=443 DPT=33150 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8501.300482] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.134.217 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=24110 DF PROTO=TCP SPT=443 DPT=50104 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8501.688504] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.2 DST=192.168.1.42 LEN=103 TOS=0x00 PREC=0x00 TTL=57 ID=40530 DF PROTO=TCP SPT=443 DPT=50246 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8501.712203] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.140 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=44728 DF PROTO=TCP SPT=443 DPT=33150 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8502.118076] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.132.176 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=3339 DF PROTO=TCP SPT=443 DPT=36598 WINDOW=63 RES=0x00 ACK PSH FIN URGP=0
[ 8502.192503] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.134.217 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=24111 DF PROTO=TCP SPT=443 DPT=50104 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8502.584692] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.2 DST=192.168.1.42 LEN=103 TOS=0x00 PREC=0x00 TTL=57 ID=40531 DF PROTO=TCP SPT=443 DPT=50246 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8502.604128] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.140 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=44729 DF PROTO=TCP SPT=443 DPT=33150 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8519.690620] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8528.778544] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.132.176 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=3343 DF PROTO=TCP SPT=443 DPT=36598 WINDOW=63 RES=0x00 ACK PSH FIN URGP=0
[ 8557.093260] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.140 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x20 TTL=51 ID=44734 DF PROTO=TCP SPT=443 DPT=33150 WINDOW=56 RES=0x00 ACK PSH FIN URGP=0
[ 8559.722053] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8566.065426] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=151.101.133.140 DST=192.168.1.42 LEN=110 TOS=0x00 PREC=0x00 TTL=57 ID=30932 DF PROTO=TCP SPT=443 DPT=33156 WINDOW=58 RES=0x00 ACK PSH FIN URGP=0
[ 8569.737599] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8629.798600] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8669.838837] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8689.858322] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8709.880019] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8739.912289] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8749.926818] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8789.969687] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8797.033483] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.244.42.195 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=50 ID=59015 DF PROTO=TCP SPT=443 DPT=57440 WINDOW=126 RES=0x00 ACK PSH URGP=0
[ 8797.033514] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.244.42.195 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=50 ID=59016 DF PROTO=TCP SPT=443 DPT=57440 WINDOW=126 RES=0x00 ACK PSH URGP=0
[ 8797.137465] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.244.42.195 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=50 ID=59017 DF PROTO=TCP SPT=443 DPT=57440 WINDOW=126 RES=0x00 ACK PSH URGP=0
[ 8797.226266] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.244.42.5 DST=192.168.1.42 LEN=98 TOS=0x00 PREC=0x20 TTL=50 ID=20411 DF PROTO=TCP SPT=443 DPT=36264 WINDOW=122 RES=0x00 ACK PSH URGP=0
[ 8797.615869] [UFW BLOCK] IN=wlo1 OUT= MAC=c0:b8:83:f2:23:71:e4:ab:89:8b:d0:7f:08:00 SRC=104.244.42.5 DST=192.168.1.42 LEN=144 TOS=0x00 PREC=0x20 TTL=50 ID=20414 DF PROTO=TCP SPT=443 DPT=36264 WINDOW=122 RES=0x00 ACK PSH URGP=0
[ 8820.001582] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8840.022369] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8860.043425] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8880.062651] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8910.099623] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8920.110051] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8942.829828] audit: type=1100 audit(1602689621.283:274): pid=18782 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 8942.832176] audit: type=1101 audit(1602689621.287:275): pid=18782 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 8942.832604] audit: type=1110 audit(1602689621.287:276): pid=18782 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 8942.834227] audit: type=1105 audit(1602689621.287:277): pid=18782 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 8950.140863] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8980.173744] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 8993.164160] audit: type=1106 audit(1602689671.621:278): pid=18782 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 8993.164451] audit: type=1104 audit(1602689671.621:279): pid=18782 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 9010.206023] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9040.237713] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9140.344263] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9160.367608] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9200.411838] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9230.443785] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9250.466502] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9260.479089] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9330.553867] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9350.576268] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9360.585950] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9370.593423] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9390.618394] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9410.641105] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9440.671547] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9460.693109] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9480.715496] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9490.730295] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9500.735608] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9530.769404] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9540.777662] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9570.808995] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9580.820074] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9590.828872] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9620.861859] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9650.894977] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9660.906143] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9680.928585] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9700.948725] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9751.003270] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9761.015654] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9781.043569] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9861.125958] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9871.140579] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9901.166635] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9941.212936] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9951.225814] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9961.237249] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[ 9981.256486] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10041.323566] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10061.344878] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10081.366719] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10121.408532] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10131.422567] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10161.457252] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10231.531755] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10241.541315] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10251.551499] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10301.600305] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10351.660902] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10391.704276] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10421.732575] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10461.777264] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10491.809319] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10501.821956] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10508.682720] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[10508.783459] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 440.100 Fri May 29 08:45:51 UTC 2020
[10509.555555] nvidia 0000:01:00.0: Enabling HDA controller
[10511.658887] nvidia 0000:01:00.0: Enabling HDA controller
[10511.830527] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10531.852455] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10551.872229] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10621.949457] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10633.942089] ACPI Error: No handler for Region [VRTC] (0000000030295a14) [SystemCMOS] (20200528/evregion-127)
[10633.942102] ACPI Error: Region SystemCMOS (ID=5) has no handler (20200528/exfldio-261)
[10633.942121] ACPI Error: Aborting method \_SB.PCI0.LPCB.EC._Q9A due to previous error (AE_NOT_EXIST) (20200528/psparse-529)
[10692.025122] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10702.035560] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10722.053907] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10732.067356] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10742.075005] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10752.085287] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10792.129899] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10802.138437] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10810.082895] nvidia 0000:01:00.0: Enabling HDA controller
[10811.472887] nvidia 0000:01:00.0: Enabling HDA controller
[10812.150380] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10812.576190] nvidia 0000:01:00.0: Enabling HDA controller
[10813.879433] nvidia 0000:01:00.0: Enabling HDA controller
[10852.192361] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10872.213845] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10912.257000] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[10972.318366] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11032.386093] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11042.397157] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11052.407474] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11062.417113] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11082.439232] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11092.106498] audit: type=1100 audit(1602691770.595:280): pid=20310 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11092.109546] audit: type=1101 audit(1602691770.598:281): pid=20310 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11092.110080] audit: type=1110 audit(1602691770.598:282): pid=20310 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11092.111795] audit: type=1105 audit(1602691770.598:283): pid=20310 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11092.135055] audit: type=1106 audit(1602691770.621:284): pid=20310 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11092.135099] audit: type=1104 audit(1602691770.621:285): pid=20310 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11092.456141] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11102.459957] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11132.488344] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11161.832770] audit: type=1101 audit(1602691840.322:286): pid=20343 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11161.833192] audit: type=1110 audit(1602691840.322:287): pid=20343 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11161.834060] audit: type=1105 audit(1602691840.322:288): pid=20343 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11182.540624] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11232.597057] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11242.607596] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11282.419556] audit: type=1106 audit(1602691960.907:289): pid=20343 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11282.419846] audit: type=1104 audit(1602691960.907:290): pid=20343 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11312.679914] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11352.724299] [UFW BLOCK] IN=wlo1 OUT= MAC=01:00:5e:00:00:01:e4:ab:89:8b:d0:7f:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=0 DF PROTO=2
[11376.582219] audit: type=1101 audit(1602692055.072:291): pid=20700 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11376.583062] audit: type=1110 audit(1602692055.075:292): pid=20700 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11376.585409] audit: type=1105 audit(1602692055.075:293): pid=20700 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11407.064149] audit: type=1106 audit(1602692085.556:294): pid=20700 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11407.064328] audit: type=1104 audit(1602692085.556:295): pid=20700 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11412.246617] audit: type=1101 audit(1602692090.739:296): pid=20921 uid=1000 auid=1000 ses=7 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="sergi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11412.246976] audit: type=1110 audit(1602692090.739:297): pid=20921 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[11412.248114] audit: type=1105 audit(1602692090.739:298): pid=20921 uid=0 auid=1000 ses=7 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
