Wi/Fi adaptor lights
Plugged in my Alfa Wi-Fi adaptor after installing 8812au and the light on the adaptor comes on when the system boots.
I have another WiFi adaptor by tp-link and in the Windows 11 that I dual boot with the light on the adaptor works.
In Manjaro although the adaptor works well the indicator light does not work.
This isn’t a problem but just out of curiosity I wonder why there is no light in Manjaro
If the module option exists you could use that … but we need the information.
Show us an inxi -Nazy
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: TP-Link Archer T4U ver.3 driver: rtw_8822bu type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-11:6 chip-ID: 2357:0115
class-ID: 0000 serial:
The indicator might only activate when there is network activity, with Linux. Only a guess, at this point. Cheers.
No light at any time - running software , browsing youtube , etc…
Guess it is just a quirk with the TP-Link device.
My other system has a light with a similar Alfa USB WiFi card.
More likely there’s some specific Windows hook in software to trigger it that wasn’t deemed important enough to replicate for Linux; or at least, not in all distributions. Often, software is built for Debian/Ubuntu with others being merely an afterthought.
Please show us
modinfo rtw_8822bu
Booted today and the TP-Link WiFi light came on - guess some update yesterday fixed it.
Question solved!!!
Sooner or later, the Good God Darwin always sorts things out. Cheers.
