I don’t think you need this for this question, but I’ll added here. The Title says it all. Youtube-dl does not work. Any reason why. IDK how to tackle this problem. Thank you for your answer.
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=fb3b8569-3b15-4c53-ab66-d3dd1f3cb627 rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor
resume=UUID=f2e22fa6-fc97-4195-b99c-425615b3ea4b udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 20U9005MUS v: ThinkPad X1 Carbon Gen 8
Mobo: LENOVO model: 20U9005MUS v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N2WET30W (1.20 )
date: 08/26/2021
ID-1: BAT0 charge: 50.1 Wh (100.0%) condition: 50.1/51.0 Wh (98.2%)
volts: 17.2 min: 15.4 model: SMP 5B10W13931 type: Li-poly serial: <filter>
status: Full cycles: 18
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 740 high: 800 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 755 2: 791 3: 701 4: 734
5: 700 6: 700 7: 742 8: 800 bogomips: 36812
Type: spectre_v2
mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:5 chip-ID: 13d3:56bb class-ID: 0e02
Display: wayland server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: 0
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: no
Sound Server-5: PipeWire v: 0.3.43 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IF-ID-2: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 1-10:8 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 204.34 GiB (21.4%)
model: PC SN730 SDBQNTY-1T00-1001 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11170101 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
used: 204.31 GiB (21.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 24.8 MiB (4.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
ID-4: /var/log raw-size: 936.96 GiB size: 936.96 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.41 GiB used: 1.2 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 60.0 C pch: 62.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 4235
Processes: 372 Uptime: 1d 23h 18m wakeups: 114 Memory: 15.29 GiB
used: 7.45 GiB (48.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1631 pacman: 1591 lib: 444 flatpak: 31
snap: 9 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
