??vim is a important part of a linux os. there is htop but not vim. doesn’t make any sense
vim is a matter of preference - vi is available
…Says who ?
vi
is installed by default … though it is not necessary either.
You can, as with every other package in the repos, easily install vim though if you like.
You can install it whenever you want.
sudo pacman -S vim
Note:
I work against remote servers.
On some servers, it is not installed.
By default I always find nano pre-installed.
I’ve gotten used to Vim, because I think it’s safer when editing. But it is a personal appreciation.
Well I’m used to nano and that’s it. However other team members seem to like vi: Update Packages-Root (!74) · Merge requests · Profiles & Settings / iso-profiles · GitLab
I think micro would be even better for novices.
micro
uses standard key bindings.
vi
is terrible and does not fit the arrow keys on keyboard.
vim
does not support copying to clipboard. (when using :set mouse=a
gvim
is like vim
that supports copying to clipboard well. It works as I excepted.
I am using vim
(gvim
) and micro
nano
version 6 is coming soon.
??not everyone uses vim.
