hello
lately when the cursor appears it is frozen and not animated.
why?
hi
a little more information would be helpful.
the output of these two commands would be useful.
inxi --verbosity=8 --filter
gsettings list-recursively org.gnome.desktop.interface | grep cursor
post the respective content as code via the button: </>
Mod edit:- Note that sudo is not required to run inxi.
Your post has been edited to reflect this. Cheers.
As has been said;
Please provide system information as described (below) and please⦠read and absorb the link (also below) entitled āHow to Postā.
You have been a user of this forum long enough to understand the basic requirements of asking for Support. ![]()
Update Announcements
System Information
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes itās better to ask your system directly; ![]()
inxi --filter --verbosity=8
or the short form:
inxi -zv8
- inxi man pages (Arch Manual)
Be prepared to provide output from other commands whenever asked. Itās equally important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem.
Highly Recommended
Required Reading
Technical Resources
i thought it is a common problem because it happens on two manjaro computers that iāveā¦
org.gnome.desktop.interface cursor-blink true
org.gnome.desktop.interface cursor-blink-time 1200
org.gnome.desktop.interface cursor-blink-timeout 10
org.gnome.desktop.interface cursor-size 24
org.gnome.desktop.interface cursor-theme 'Bibata-Modern-Classic'
inxi -zv8:
Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=99541b23-7385-4771-8f2d-59a8ec47ec47 rw quiet splash apparmor=1
Desktop: GNOME v: 48.1 tk: GTK v: 3.24.49 wm: gnome-shell
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: PRO B760M-A DDR4 II (MS-7D99) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.A0 date: 03/21/2024
System RAM: total: 32 GiB available: 31.12 GiB used: 4.21 GiB (13.5%)
Device-1: Controller0-DIMMA1 type: no module installed
Device-2: Controller0-DIMMA2 type: DDR4 detail: synchronous size: 16 GiB
speed: 3600 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Kingston part-no: KF3600C18D4/16GX
serial: <filter>
Device-3: Controller1-DIMMB1 type: no module installed
Device-4: Controller1-DIMMB2 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x38
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB
desc: 1x20 MiB
Speed (MHz): avg: 800 min/max: 800/4900:3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800 16: 800
bogomips: 118000
de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand
rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel AlderLake-S GT1 vendor: Micro-Star MSI driver: i915
v: kernel alternate: xe arch: Xe process: Intel 10nm built: 2020-21 ports:
active: none empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0380
Device-2: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: Gigabyte
driver: nvidia v: 570.144 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none off: HDMI-A-5 empty: DP-3,DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:2187 class-ID: 0300
compositor: gnome-shell driver: X: loaded: N/A failed: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-5 model: Dell S2722QC serial: <filter> built: 2022
res: 3840x2160 dpi: 163 gamma: 1.2 chroma: red: x: 0.659 y: 0.329 green:
x: 0.306 y: 0.647 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
modes: 3840x2160, 2560x1440, 2048x1280, 1920x1080, 1600x1200, 1600x900,
1280x1024, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 93 3: parse_edid: unhandled CEA mode 94 4: parse_edid:
unhandled CEA mode 95
API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau drv: nvidia
platforms: device: 0 drv: nvidia device: 1 drv: nouveau device: 2 drv: iris
device: 3 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland:
drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.144
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
x11: xdpyinfo,xprop
Device-1: Intel Raptor Lake High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7a50 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: Gigabyte
bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Microsoft Nano Transceiver v1.0 for Bluetooth
driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-6:2 chip-ID: 045e:0745 class-ID: 0300
Local Storage: total: 2.73 TiB used: 28.1 GiB (1.0%)
model: WD Blue SN580 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 281010WD temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 28.1 GiB (3.1%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 99541b23-7385-4771-8f2d-59a8ec47ec47
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D3B0-7D54
ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: N/A
uuid: 79c1870e-ae21-44e1-9cbc-50df1c5042c2
Device-1: 1-6:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: keyboard,mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
Device-2: 1-9:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7d99 class-ID: 0300
serial: <filter>
Hub-2: 1-10:4 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-3: 1-11:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Hub-5: 2-10:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 23.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1365 libs: 376 tools: gnome-software,pamac
pm: flatpak pkgs: 0
1: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
4: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
5: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
8: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 467
1: cpu: 22.8% command: firefox pid: 2574 mem: 763.2 MiB (2.3%)
2: cpu: 14.1% command: gnome-shell pid: 1911 mem: 576.7 MiB (1.8%)
3: cpu: 13.1% command: firefox pid: 3729 mem: 284.9 MiB (0.8%)
4: cpu: 3.2% command: firefox pid: 2711 mem: 300.3 MiB (0.9%)
5: cpu: 3.0% command: firefox pid: 2898 mem: 343.1 MiB (1.0%)
Memory top: 5 of 467
1: mem: 763.2 MiB (2.3%) command: firefox pid: 2574 cpu: 22.8%
2: mem: 595.4 MiB (1.8%) command: thunderbird pid: 3224 cpu: 1.8%
3: mem: 576.7 MiB (1.8%) command: gnome-shell pid: 1911 cpu: 14.1%
4: mem: 498.3 MiB (1.5%) command: ./firefox.real pid: 3388 cpu: 1.9%
5: mem: 413.2 MiB (1.2%) command: exe pid: 3167 cpu: 1.4%
Processes: 467 Power: uptime: 46m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 fails: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.42 GiB services: gsd-power,
tool: systemctl
Compilers: N/A Shell: Bash v: 5.2.37 running-in: gnome-terminal
inxi: 3.3.38
Mod edit: Note that inxi --verbosity=8 --filter and inxi -zv8 are the same command and produce the same output. This was clearly described (above) as it has been on many other occasions. The superfluous pasted output has been removed.
no, unfortunately this is not a common problem, it works on my machine ![]()
even if i switch to your cursor-theme it still works, the only difference is that i use the 6.14 kernel, but i almost donāt think thatās the reason.
you can try to change the cursor theme?
so i have no idea at the moment, but maybe someone else.
never mind.
it is not such a big dealā¦
my focus was more about letting you know about itā¦
tnx anyway
In the interests of improving the standards of support in Linux, I would like to politely request that you improve the standards of your interactions here.
- You mention an issue with your systems.
- Firstly with the mention of someone using a 6.14 kernel (one possible difference) you should consider rebooting to a different kernel to test the theory.
- Change the cursor theme to verify that it is not a specific issue with one theme on your machine (i.e. is your problem ONE theme, or MANY themes?).
Your response ānever mindā is unfortunately dismissive, disrespectful, and disappointing considering that you also decided to complain in another thread about the quality of Linux Support.
Linux Support starts here, with you.
Off topic;
I suppose, traditionally, I am a mono-themist; though sometimes I do subscribe to the many themes theology.
It just depends on my state of mind, or my desire for just a breath of change. ![]()
So you are a panthemist? ![]()
Iāll get my coatā¦
I was rather impressed with your inventiveness, though surely as polytheists worship many Gods (Greek) then a polythematist would worship many themes.
As you, yourself do worship your theme, then I assume youāre more of a Monothematist⦠or perhaps an aesthetic liturgist might be more appropriate. ![]()
These matters must be taken extremely seriously, as accuracy is of vital importance in such a valuable technical thread.
