Why system not recognize GPU device names?
Hello all. I have an issue with missing GPU device names in MHWD on my MSI Karana GF76 12UGSO laptop (6.3.5-2 kernel). If i open GUI driver installer i see on two GPUs “Unkown device name (nVidia Corporation)” and “Unkown device name (Intel Corporation)”. And almost the same in mhwd -l -d:
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:24a0)
  Display controller nVidia Corporation
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   INFO:        Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:    8
   FREEDRIVER:  false
   DEPENDS:     video-modesetting
   CONFLICTS:   video*nvidia*
   CLASSIDS:    0300 0302 0300
   VENDORIDS:   10de 8086
   ATTACHED:    PCI
   VERSION:     2020.01.13
   INFO:        X.org modesetting video driver.
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    7
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2023.03.23
   INFO:        Closed source NVIDIA drivers for linux.
   PRIORITY:    5
   FREEDRIVER:  false
   DEPENDS:     -
   CLASSIDS:    0300 0302
   VENDORIDS:   10de
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    4
   FREEDRIVER:  false
   DEPENDS:     -
   CLASSIDS:    0300 0302
   VENDORIDS:   10de
   ATTACHED:    PCI
   VERSION:     2018.05.04
   INFO:        Standard open source drivers.
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300 0380 0302
   VENDORIDS:   1002 8086 10de
   ATTACHED:    PCI
   VERSION:     2020.01.13
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   INFO:        X.org vesa video driver.
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
> PCI Device: /devices/pci0000:00/0000:00:1c.5/0000:04:00.0 (0200:10ec:8168)
  Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2016.04.20
   INFO:        RealTek RTL-8168 Gigabit Ethernet driver
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0200
   VENDORIDS:   1186 10ec
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2016.04.20
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0200
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:46a6)
  Display controller Intel Corporation
  > INSTALLED:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2020.01.13
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
  > AVAILABLE:
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    8
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2023.03.23
   PRIORITY:    7
   FREEDRIVER:  false
   ATTACHED:    PCI
   VERSION:     2018.05.04
   PRIORITY:    2
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   ATTACHED:    PCI
   VERSION:     2020.01.13
   PRIORITY:    1
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
   ATTACHED:    PCI
   VERSION:     2017.03.12
   PRIORITY:    0
   FREEDRIVER:  true
   DEPENDS:     -
   CONFLICTS:   -
   CLASSIDS:    0300
   VENDORIDS:   *
Warning: no configs for USB devices found!
Does it create problems? How i can fix that?
Welcome to the forum! :wave:
Since MHWD detected you have a hybrid Intel + NVIDIA laptop, it chose the proper driver configuration:
As long as the proper driver configuration is used, I would not worry about it not displaying the name.
Please post the output of the following so we know what graphics hardware you have:
inxi -Gazy
  Device-1: Intel Alder Lake-P Integrated Graphics vendor: Micro-Star MSI
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:46a6
    class-ID: 0300
  Device-2: NVIDIA GA104 [Geforce RTX 3070 Ti Laptop GPU]
    vendor: Micro-Star MSI driver: nvidia v: 530.41.03
    alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: lanes: 16 ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:24a0 class-ID: 0300
  Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 5986:211b
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x978f built: 2020
    res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
    diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX 3070 Ti
    Laptop GPU/PCIe/SSE2 direct-render: Yes
Looks good. It appears we have the same CPU, but I have an RTX 3060.
