I am kinda curious, does anyone use mssql-server? if use, can you tell me are you use SQLCMD or not, if not what tools you using for query mssql-server? I know azura studio, but my potato laptop can’t handle that, does anyone have alternative beside SQLCMD and Azure Studio? I know there are mssql-cli, but I can’t found that package in AUR and in the mssql-cli github only provide for ubuntu, rhel, debian and CentOS
Isn’t that a Windows tool?
I think the mssql-tools package exists in the AUR for mssql-server. Perhaps you’ll find something you need in that.
pamac build mssql-tools
There’s also the deprecation notice that’s somewhat detracting.
DBbeaver or any of the following might potentially be useful:
Otherwise ![]()
Cheers.
If you can use visual studio code - it should be possible to use azure datastudio as well - they are built upon the same platform.
I use mssql - and even run a couple of local instances, one on a manjaro box the other on Microsoft Server. If I need to interact with the service I have most used SQL Management Studio. But since my main platform is Manjaro - Azure Datastudio works - not as featurerich as SQL Management Studio but for simple tasks - like bulk changes to a recordset - it works great.
We rarely interact with the service using CLI directly but should it be necessary I would use powershell.
For interacting with the production database we have scripted the interaction using powershell.
we use a powershell script to keep a sandbox environment current
- creates a backup
- copy that backup to a sandbox instance
- change ownership on the backup file
- creates a tail backup
- restoring the backup into the sandbox instance
When the database schema needs update we use EntifyFramework to do the lifting based on a codefirst approach.
Powershell can be build from a custom AUR script … and has an excellent forum - which also discuss interaction with sql server Search results for 'sql' - PowerShell Forums
SQLCMD is official tool in any platform, you can use sqlcmd in linux too, but sqlcmd is very uncomfortable, so I want change to other CLI, the reason I don’t use GUI just my laptop can’t handle the workload
Thank you for reply, I am really appreciate that
It is not that hard to use sqlcmd - it require you to know the database schema by heart - or at least have a reference sheet at hand.
Short example from my local development service
sqlcmd -S <sqlname> -H <hostname> -C -U <username>
Password:
1> use crmdata
2> go
Changed database context to 'CRMDATA'.
1> select top(5) [SalesItemId], [sku], [Description] from salesitems
2> go
SalesItemId sku Description
0033a2af-cb63-ec11-9f08-000d3ab4fc9a G360 11800 FARVE G360
00373921-2e63-ec11-9f08-000d3ab4fc9a 04,1900 STOR SMART CLEANERS
00383921-2e63-ec11-9f08-000d3ab4fc9a 05,2311 Moulding Tape 15 mm x 10 m
0049449a-d663-ec11-9f08-000d3ab4fc9a 02,1200 Solid Spray Filler
007f3127-2e63-ec11-9f08-000d3ab4fc9a 90,0206 Micro Torch use
Another example getting all columns in a named table
1> select COLUMN_NAME from information_schema.columns where table_name = 'SalesItems'
2> go
COLUMN_NAME
SalesItemId
ProductVariantId
Sku
Description
Description2
ProductGroup
PictureLink
ShortName
CreateTimestamp
UpdateTimestamp
ArchiveTimestamp
SyncTimestamp
Description1
VendorItemNo
SalesRepCountryCode
Location
BoxSize
OnDemand
If you are more comfortable with a GUI - dbeaver community edition is working very well.
Just be sure to use the latest jdk-openjdk
sudo pacman -Syu dbeaver jdk-openjdk
