Why is manjaro frozen?
I have another question
It has happened to me many times!
what’s the solution ?
Can a graphics card be a maker?
Can not say based on your info.
Perhaps take a look at the logs to see if you can find relevant errors:
sudo journalctl -p 3 -xb
:+1: Welcome to Manjaro! :+1:
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
:innocent:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU you have, …
