I finally got around to setting up trim support, I needed to perform a firmware upgrade first. So all seems to be working until I tried to start the fstrim.timer. It fails because /etc/initrd-release exists, an empty file. huh? Why does fstrim.timer not run if this file exists?
$ systemctl status fstrim.timer
○ fstrim.timer - Discard unused blocks once a week
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; vendor preset: disabled)
Active: inactive (dead)
Trigger: n/a
Triggers: ● fstrim.service
Condition: start condition failed at Sat 2021-07-17 14:48:30 CDT; 2s ago
└─ ConditionPathExists=!/etc/initrd-release was not met
Docs: man:fstrim
Edit: The file is not owned by any package on my system. But that does not mean it was not installed by a package. It is also possible that I created this file at sometime in the past. But in the back of my mind, I am thinking this was recently added… or was that /etc/os-release?
The file does exist, but I am not sure why it exists. And it strikes me as very odd that fstrim.timer would be coded to not run, if the file does exist. I believe systemd uses/used the file as a flag, for what to run or load during the boot process.
