I made the temp account and tested it, and kate works fine, however, I guess I will just be using nano or vs code to edit txt files now, because I have made edits to config files before, but I have no idea how they affect kate and only kate.
or at least I think I have made edits to config files, I have made edits to files that would definitely affect the second account too so those must not be the files that I am thinking of.
what do you mean by config file?
a piece of information that might be important is that I only noticed kateâs overindulgence in my cpu after I made edits to files that need root permissions to write to
It could be any config file, either manually created/edited, or when you change settings in KDE or different applications.
In fact, it could be a configuration you previously changed on Kate (with your main user account) but forgot about it.
You can rename/remove the relevant kate
configs on your main user account.
Consider this folder:
~/.local/share/kate
And these files:
~/.config/kateschemarc
~/.config/katerc
~/.config/katevirc
~/.config/katemetainfos
I removed all those files, and there is no change. I double checked the temp account and I canât get it to act in the same way
That certainly is crazy.
I just opened a large file in code, also in kate, and used btop to check them out - they both come in at 0.0% CPU on a Ryzen 5600G.
Why does kate use so much cpu? - #25 by winnie looks like a good plan.
I have no such folder on my KDE system.
Perhaps it was from an older installation in which you used Kate?
Do you have a katerc
file located at ~/.config/katerc
yes I do
Did you notice the folder ~/.config/kate
get recreated after running Kate again?
(No matter what I try, I cannot get that folder to appear. So it might be an older method in which Kate saved its settings.)
EDIT: Thatâs interesting. Hopefully this âhigh CPUâ issue doesnât recur.
Yes, it was recreated after I ran kate again.
I donât understand, now after rebooting, the issue is back.
Try a shotgun approach.
Close all instances of Kate.
Then rename all relevant folders/files.
mv ~/.local/share/kate ~/.local/share/kate.old
mv ~/.config/kate ~/.config/kate.old
mv ~/.config/kateschemarc ~/.config/kateschemarc.old
mv ~/.config/katerc /.config/katerc.old
mv ~/.config/katevirc ~/.config/katevirc.old
mv ~/.config/katemetainfos ~/.config/katemetainfos.old
Then reboot. (Or just logout and log back in.)
the issue persists
Iâm out of ideas.
Weâve exhausted nearly every possibility.
Unless youâve installed a package from the AUR that is causing this.
Log out, rename your .config
folder (to keep it) and/or the .local
folder, from TTY, and log back in. See if issue persists.
If it doesnât, then youâll need to take time to log out and restore folders and files from the renamed .config
folder to the fresh .config
folder (same for .local
), maybe do it step by step to see if issue arises at some point, instead of reimporting everything in bulk, so you can know at which point it breaks.
It will be long and boring.
Have fun.
There is one more test:
- Create a new user/account in KDE
- logout, then login this new user
- Check
kate
if it has no issue?
Thread is long but you can search within the thread if you donât want to read it. He already confirmed that new user doesnât have issue.
I would have fun, however, kate continues to be uncooperative after I rename the folder and reboot.
I guess that helps somewhat, it means that the problem is not in the config folder somehow?
you mean folderS, right?
I wrote and/or
but in the end you need to do both .config
and .local
at minimum to start cleaner on applications settings, to see what happens when you do one or the other or both.
yup i did both
tried uninstalling and making sure that those files were gone and then reinstalling kate too
