Hey,
I am not able to share my whole screen during my meetings. I read a few of the similar questions in discussions forums, but that doesn’t work.
The output of inxi --full --verbosity=7 --filter --no-host
is:
System: Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.4
tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1 Distro: Manjaro Linux base: Arch Linux
Machine: Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk1xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8742 v: 02.34 serial: <filter> UEFI: Insyde v: F.21 date: 01/08/2021
Battery: ID-1: BAT1 charge: 30.5 Wh (59.2%) condition: 51.5/52.5 Wh (98.1%) volts: 12.7 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Charging
Memory: RAM: total: 15.43 GiB used: 2.66 GiB (17.2%)
CPU: Info: 8-Core model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake rev: 2
cache: L2: 16 MiB bogomips: 70421
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800 15: 800
16: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr
mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln
pni popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Hewlett-Packard
driver: nvidia v: 470.63.01 bus-ID: 01:00.0 chip-ID: 10de:1f95 class-ID: 0300
Device-3: Quanta HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:2
chip-ID: 0408:5300 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver: loaded: nvidia
note: n/a (using device driver) - try sudo/root resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 8087:0026 class-ID: e001
Logical: Message: No logical block device data found.
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060
bus-ID: 00:17.0 chip-ID: 8086.282a rev: class-ID: 0104
Device-1: md127 type: mdraid level: N/A status: inactive size: N/A
Info: report: N/A blocks: 2944 chunk-size: N/A
Components: Online: N/A Spare: 0: nvme1n1
Drives: Local Storage: total: 504.19 GiB used: 50.86 GiB (10.1%)
ID-1: /dev/nvme0n1 vendor: Intel model: HBRPEKNX0202AH size: 476.94 GiB speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: HPS2 temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Intel model: HBRPEKNX0202AHO size: 27.25 GiB speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: HPS3 temp: 45.9 C
Partition: ID-1: / size: 244.77 GiB used: 50.86 GiB (20.8%) fs: ext4 dev: /dev/nvme0n1p6 label: N/A
uuid: 71927843-4c9f-4e08-b2d3-fccbc78c34d9
ID-2: /boot/efi size: 252 MiB used: 275 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5
label: NO_LABEL uuid: F89E-5B45
Swap: Alert: No swap data was found.
Unmounted: ID-1: /dev/nvme0n1p1 size: 260 MiB fs: vfat label: SYSTEM uuid: 6246-07DB
ID-2: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 size: 226.15 GiB fs: ntfs label: Windows uuid: C0D87D48D87D3DAA
ID-4: /dev/nvme0n1p4 size: 522 MiB fs: ntfs label: Windows RE tools
uuid: 3236B7C936B78BFB
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
Device-1: 1-5:2 info: Quanta HP Wide Vision HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:5300 class-ID: 0e02
serial: <filter>
Device-2: 1-14:3 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
Sensors: System Temperatures: cpu: 44.0 C mobo: 10.0 C
Info: Processes: 379 Uptime: 1h 12m wakeups: 1 Init: systemd v: 248 Compilers: gcc: 11.1.0
alt: 10 Packages: 1212 pacman: 1208 snap: 4 Shell: Zsh v: 5.8 running-in: gnome-terminal
inxi: 3.3.06
The output of dmesg
is:
[ 0.000000] microcode: microcode updated early to revision 0xea, date = 2021-02-07
[ 0.000000] Linux version 5.10.60-1-MANJARO (builduser@fv-az82-699) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Aug 18 08:02:07 UTC 2021
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=71927843-4c9f-4e08-b2d3-fccbc78c34d9 rw nouveau.modeset=0 quiet splash apparmor=1 security=apparmor udev.log_priority=3 isolcpus=6,7,14,15
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ 0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ 0.000000] x86/fpu: xstate_offset[9]: 960, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x21f, context size is 968 bytes, using 'compacted' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000006908dfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006908e000-0x000000006958dfff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000006958e000-0x000000006bb7dfff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006bb7e000-0x000000006da7dfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006da7e000-0x000000006db4dfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000006db4e000-0x000000006db4efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006db4f000-0x00000000737fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff380000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000048a7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.70 by INSYDE Corp.
[ 0.000000] efi: ACPI=0x6db4d000 ACPI 2.0=0x6db4d014 TPMFinalLog=0x6da75000 ESRT=0x6ad72918 SMBIOS=0x6a55e000 SMBIOS 3.0=0x6a55c000 MEMATTR=0x57a8e018
[ 0.000000] SMBIOS 3.2.0 present.
[ 0.000000] DMI: HP HP Pavilion Gaming Laptop 15-dk1xxx/8742, BIOS F.21 01/08/2021
[ 0.000000] tsc: Detected 2200.000 MHz processor
[ 0.000000] tsc: Detected 2199.996 MHz TSC
[ 0.000005] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000007] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000010] last_pfn = 0x48a800 max_arch_pfn = 0x400000000
[ 0.000012] MTRR default type: write-back
[ 0.000013] MTRR fixed ranges enabled:
[ 0.000014] 00000-9FFFF write-back
[ 0.000014] A0000-BFFFF uncachable
[ 0.000015] C0000-FFFFF write-protect
[ 0.000015] MTRR variable ranges enabled:
[ 0.000016] 0 base 0080000000 mask 7F80000000 uncachable
[ 0.000016] 1 base 0070000000 mask 7FF0000000 uncachable
[ 0.000017] 2 base 006F000000 mask 7FFF000000 uncachable
[ 0.000017] 3 base 2000000000 mask 6000000000 uncachable
[ 0.000018] 4 base 1000000000 mask 7000000000 uncachable
[ 0.000018] 5 base 0800000000 mask 7800000000 uncachable
[ 0.000019] 6 base 4000000000 mask 4000000000 uncachable
[ 0.000019] 7 disabled
[ 0.000020] 8 disabled
[ 0.000020] 9 disabled
[ 0.000352] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000598] last_pfn = 0x6db4f max_arch_pfn = 0x400000000
[ 0.005145] esrt: Reserving ESRT space from 0x000000006ad72918 to 0x000000006ad72950.
[ 0.005151] check: Scanning 1 areas for low memory corruption
[ 0.005154] Using GB pages for direct mapping
[ 0.005360] Secure boot disabled
[ 0.005360] RAMDISK: [mem 0x364ad000-0x3724dfff]
[ 0.005363] ACPI: Early table checksum verification disabled
[ 0.005365] ACPI: RSDP 0x000000006DB4D014 000024 (v02 HPQOEM)
[ 0.005367] ACPI: XSDT 0x000000006DB24188 00014C (v01 HPQOEM SLIC-MPC 00000002 HP 01000013)
[ 0.005370] ACPI: FACP 0x000000006DB22000 00010C (v05 HPQOEM SLIC-MPC 00000002 HP 00040000)
[ 0.005373] ACPI: DSDT 0x000000006DADA000 043084 (v02 HPQOEM 8742 00000002 HP 00040000)
[ 0.005375] ACPI: FACS 0x000000006D9D3000 000040
[ 0.005376] ACPI: UEFI 0x000000006DA7D000 000236 (v01 HPQOEM 8742 00000001 HP 00040000)
[ 0.005378] ACPI: SSDT 0x000000006DB4B000 000100 (v02 HPQOEM 8742 00003000 HP 00040000)
[ 0.005380] ACPI: SSDT 0x000000006DB46000 004C19 (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005382] ACPI: SSDT 0x000000006DB45000 000F34 (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005383] ACPI: SSDT 0x000000006DB42000 002087 (v02 HPQOEM 8742 00003000 HP 00040000)
[ 0.005385] ACPI: SSDT 0x000000006DB3E000 0031DA (v02 HPQOEM 8742 00003000 HP 00040000)
[ 0.005387] ACPI: SSDT 0x000000006DB3B000 002B23 (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005388] ACPI: SSDT 0x000000006DB3A000 00045A (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005390] ACPI: SSDT 0x000000006DB39000 000046 (v02 HPQOEM 8742 00003000 HP 00040000)
[ 0.005392] ACPI: TPM2 0x000000006DB38000 000034 (v03 HPQOEM 8742 00000002 HP 00040000)
[ 0.005394] ACPI: SSDT 0x000000006DB37000 000179 (v01 HPQOEM 8742 00001000 HP 00040000)
[ 0.005395] ACPI: SSDT 0x000000006DB2E000 008089 (v01 HPQOEM 8742 00001000 HP 00040000)
[ 0.005397] ACPI: MSDM 0x000000006DB2D000 000055 (v03 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ 0.005399] ACPI: LPIT 0x000000006DB2C000 000094 (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005400] ACPI: WSMT 0x000000006DB2B000 000028 (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005402] ACPI: SSDT 0x000000006DB2A000 000B70 (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005404] ACPI: SSDT 0x000000006DB27000 00256F (v02 HPQOEM 8742 00000000 HP 00040000)
[ 0.005406] ACPI: DBGP 0x000000006DB26000 000034 (v01 HPQOEM SLIC-MPC 00000002 HP 00040000)
[ 0.005407] ACPI: DBG2 0x000000006DB25000 00005C (v00 HPQOEM 8742 00000002 HP 00040000)
[ 0.005409] ACPI: NHLT 0x000000006DB4C000 00002D (v00 HPQOEM 8742 00000002 HP 00040000)
[ 0.005411] ACPI: ECDT 0x000000006DB23000 000069 (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005412] ACPI: HPET 0x000000006DB21000 000038 (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005414] ACPI: APIC 0x000000006DB20000 000164 (v03 HPQOEM 8742 00000002 HP 00040000)
[ 0.005416] ACPI: MCFG 0x000000006DB1F000 00003C (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005417] ACPI: SSDT 0x000000006DAD9000 00018A (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005419] ACPI: SSDT 0x000000006DAD7000 0012B7 (v02 HPQOEM 8742 00000002 HP 00040000)
[ 0.005421] ACPI: DMAR 0x000000006DAD6000 0000A8 (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005422] ACPI: SSDT 0x000000006DAD3000 002160 (v01 HPQOEM 8742 00001000 HP 00040000)
[ 0.005424] ACPI: SSDT 0x000000006DAD2000 00005C (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005426] ACPI: SSDT 0x000000006DAD1000 000161 (v02 HPQOEM 8742 00001000 HP 00040000)
[ 0.005427] ACPI: SSDT 0x000000006DAD0000 000164 (v01 HPQOEM 8742 00001000 HP 00040000)
[ 0.005429] ACPI: SSDT 0x000000006DACF000 00082B (v02 HPQOEM 8742 00003000 HP 00040000)
[ 0.005431] ACPI: UEFI 0x000000006D18A000 00063A (v01 HPQOEM 8742 00000000 HP 00040000)
[ 0.005433] ACPI: UEFI 0x000000006D189000 00005C (v01 HPQOEM 8742 00000000 HP 00040000)
[ 0.005434] ACPI: FPDT 0x000000006DACE000 000044 (v01 HPQOEM 8742 00000002 HP 00040000)
[ 0.005436] ACPI: BGRT 0x000000006DACD000 000038 (v01 HPQOEM 8742 00000001 HP 00040000)
[ 0.005438] ACPI: Reserving FACP table memory at [mem 0x6db22000-0x6db2210b]
[ 0.005438] ACPI: Reserving DSDT table memory at [mem 0x6dada000-0x6db1d083]
[ 0.005439] ACPI: Reserving FACS table memory at [mem 0x6d9d3000-0x6d9d303f]
[ 0.005439] ACPI: Reserving UEFI table memory at [mem 0x6da7d000-0x6da7d235]
[ 0.005440] ACPI: Reserving SSDT table memory at [mem 0x6db4b000-0x6db4b0ff]
[ 0.005440] ACPI: Reserving SSDT table memory at [mem 0x6db46000-0x6db4ac18]
[ 0.005441] ACPI: Reserving SSDT table memory at [mem 0x6db45000-0x6db45f33]
[ 0.005441] ACPI: Reserving SSDT table memory at [mem 0x6db42000-0x6db44086]
[ 0.005442] ACPI: Reserving SSDT table memory at [mem 0x6db3e000-0x6db411d9]
[ 0.005442] ACPI: Reserving SSDT table memory at [mem 0x6db3b000-0x6db3db22]
[ 0.005443] ACPI: Reserving SSDT table memory at [mem 0x6db3a000-0x6db3a459]
[ 0.005443] ACPI: Reserving SSDT table memory at [mem 0x6db39000-0x6db39045]
[ 0.005444] ACPI: Reserving TPM2 table memory at [mem 0x6db38000-0x6db38033]
[ 0.005444] ACPI: Reserving SSDT table memory at [mem 0x6db37000-0x6db37178]
[ 0.005445] ACPI: Reserving SSDT table memory at [mem 0x6db2e000-0x6db36088]
[ 0.005445] ACPI: Reserving MSDM table memory at [mem 0x6db2d000-0x6db2d054]
[ 0.005446] ACPI: Reserving LPIT table memory at [mem 0x6db2c000-0x6db2c093]
[ 0.005446] ACPI: Reserving WSMT table memory at [mem 0x6db2b000-0x6db2b027]
[ 0.005447] ACPI: Reserving SSDT table memory at [mem 0x6db2a000-0x6db2ab6f]
[ 0.005447] ACPI: Reserving SSDT table memory at [mem 0x6db27000-0x6db2956e]
[ 0.005448] ACPI: Reserving DBGP table memory at [mem 0x6db26000-0x6db26033]
[ 0.005448] ACPI: Reserving DBG2 table memory at [mem 0x6db25000-0x6db2505b]
[ 0.005449] ACPI: Reserving NHLT table memory at [mem 0x6db4c000-0x6db4c02c]
[ 0.005449] ACPI: Reserving ECDT table memory at [mem 0x6db23000-0x6db23068]
[ 0.005450] ACPI: Reserving HPET table memory at [mem 0x6db21000-0x6db21037]
[ 0.005450] ACPI: Reserving APIC table memory at [mem 0x6db20000-0x6db20163]
[ 0.005451] ACPI: Reserving MCFG table memory at [mem 0x6db1f000-0x6db1f03b]
[ 0.005451] ACPI: Reserving SSDT table memory at [mem 0x6dad9000-0x6dad9189]
[ 0.005452] ACPI: Reserving SSDT table memory at [mem 0x6dad7000-0x6dad82b6]
[ 0.005452] ACPI: Reserving DMAR table memory at [mem 0x6dad6000-0x6dad60a7]
[ 0.005453] ACPI: Reserving SSDT table memory at [mem 0x6dad3000-0x6dad515f]
[ 0.005454] ACPI: Reserving SSDT table memory at [mem 0x6dad2000-0x6dad205b]
[ 0.005454] ACPI: Reserving SSDT table memory at [mem 0x6dad1000-0x6dad1160]
[ 0.005455] ACPI: Reserving SSDT table memory at [mem 0x6dad0000-0x6dad0163]
[ 0.005455] ACPI: Reserving SSDT table memory at [mem 0x6dacf000-0x6dacf82a]
[ 0.005456] ACPI: Reserving UEFI table memory at [mem 0x6d18a000-0x6d18a639]
[ 0.005456] ACPI: Reserving UEFI table memory at [mem 0x6d189000-0x6d18905b]
[ 0.005457] ACPI: Reserving FPDT table memory at [mem 0x6dace000-0x6dace043]
[ 0.005457] ACPI: Reserving BGRT table memory at [mem 0x6dacd000-0x6dacd037]
[ 0.005467] ACPI: Local APIC address 0xfee00000
[ 0.005696] No NUMA configuration found
[ 0.005697] Faking a node at [mem 0x0000000000000000-0x000000048a7fffff]
[ 0.005699] NODE_DATA(0) allocated [mem 0x48a7fc000-0x48a7fffff]
[ 0.033788] Zone ranges:
[ 0.033789] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.033790] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.033791] Normal [mem 0x0000000100000000-0x000000048a7fffff]
[ 0.033791] Device empty
[ 0.033792] Movable zone start for each node
[ 0.033792] Early memory node ranges
[ 0.033793] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.033793] node 0: [mem 0x0000000000100000-0x000000006908dfff]
[ 0.033794] node 0: [mem 0x000000006db4e000-0x000000006db4efff]
[ 0.033794] node 0: [mem 0x0000000100000000-0x000000048a7fffff]
[ 0.033796] Initmem setup node 0 [mem 0x0000000000001000-0x000000048a7fffff]
[ 0.033797] On node 0 totalpages: 4143149
[ 0.033797] DMA zone: 64 pages used for memmap
[ 0.033798] DMA zone: 23 pages reserved
[ 0.033798] DMA zone: 3998 pages, LIFO batch:0
[ 0.033799] DMA32 zone: 6659 pages used for memmap
[ 0.033799] DMA32 zone: 426127 pages, LIFO batch:63
[ 0.033799] Normal zone: 58016 pages used for memmap
[ 0.033800] Normal zone: 3713024 pages, LIFO batch:63
[ 0.033802] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.033834] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.036038] On node 0, zone DMA32: 19136 pages in unavailable ranges
[ 0.061795] On node 0, zone Normal: 9393 pages in unavailable ranges
[ 0.061964] On node 0, zone Normal: 22528 pages in unavailable ranges
[ 0.061990] Reserving Intel graphics memory at [mem 0x6f800000-0x737fffff]
[ 0.066064] ACPI: PM-Timer IO Port: 0x1808
[ 0.066065] ACPI: Local APIC address 0xfee00000
[ 0.066069] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.066070] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.066070] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.066071] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ 0.066071] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ 0.066071] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ 0.066072] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ 0.066072] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ 0.066072] ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
[ 0.066073] ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
[ 0.066073] ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
[ 0.066073] ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
[ 0.066074] ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
[ 0.066074] ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
[ 0.066074] ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
[ 0.066075] ACPI: LAPIC_NMI (acpi_id[0x10] high edge lint[0x1])
[ 0.066075] ACPI: LAPIC_NMI (acpi_id[0x11] high edge lint[0x1])
[ 0.066076] ACPI: LAPIC_NMI (acpi_id[0x12] high edge lint[0x1])
[ 0.066076] ACPI: LAPIC_NMI (acpi_id[0x13] high edge lint[0x1])
[ 0.066076] ACPI: LAPIC_NMI (acpi_id[0x14] high edge lint[0x1])
[ 0.066129] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.066130] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.066131] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.066132] ACPI: IRQ0 used by override.
[ 0.066132] ACPI: IRQ9 used by override.
[ 0.066133] Using ACPI (MADT) for SMP configuration information
[ 0.066134] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.066139] e820: update [mem 0x56fcf000-0x56fe2fff] usable ==> reserved
[ 0.066143] TSC deadline timer available
[ 0.066144] smpboot: Allowing 16 CPUs, 0 hotplug CPUs
[ 0.066155] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.066157] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.066158] PM: hibernation: Registered nosave memory: [mem 0x56fcf000-0x56fe2fff]
[ 0.066159] PM: hibernation: Registered nosave memory: [mem 0x6908e000-0x6958dfff]
[ 0.066159] PM: hibernation: Registered nosave memory: [mem 0x6958e000-0x6bb7dfff]
[ 0.066159] PM: hibernation: Registered nosave memory: [mem 0x6bb7e000-0x6da7dfff]
[ 0.066160] PM: hibernation: Registered nosave memory: [mem 0x6da7e000-0x6db4dfff]
[ 0.066161] PM: hibernation: Registered nosave memory: [mem 0x6db4f000-0x737fffff]
[ 0.066161] PM: hibernation: Registered nosave memory: [mem 0x73800000-0xdfffffff]
[ 0.066161] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ 0.066162] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[ 0.066162] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[ 0.066162] PM: hibernation: Registered nosave memory: [mem 0xfe011000-0xfed0ffff]
[ 0.066163] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[ 0.066163] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[ 0.066163] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[ 0.066164] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[ 0.066164] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.066165] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff37ffff]
[ 0.066165] PM: hibernation: Registered nosave memory: [mem 0xff380000-0xffffffff]
[ 0.066166] [mem 0x73800000-0xdfffffff] available for PCI devices
[ 0.066166] Booting paravirtualized kernel on bare hardware
[ 0.066169] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.069115] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[ 0.069385] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ 0.069389] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ 0.069390] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.069407] Built 1 zonelists, mobility grouping on. Total pages: 4078387
[ 0.069407] Policy zone: Normal
[ 0.069408] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=71927843-4c9f-4e08-b2d3-fccbc78c34d9 rw nouveau.modeset=0 quiet splash apparmor=1 security=apparmor udev.log_priority=3 isolcpus=6,7,14,15
[ 0.070273] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.070679] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.070766] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.108346] Memory: 16132640K/16572596K available (14344K kernel code, 2061K rwdata, 8888K rodata, 1708K init, 4244K bss, 439696K reserved, 0K cma-reserved)
[ 0.108351] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[ 0.108429] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[ 0.108437] ftrace: allocating 41906 entries in 164 pages
[ 0.117619] ftrace: allocated 164 pages with 3 groups
[ 0.117709] rcu: Preemptible hierarchical RCU implementation.
[ 0.117709] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.117710] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[ 0.117710] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.117711] Trampoline variant of Tasks RCU enabled.
[ 0.117711] Rude variant of Tasks RCU enabled.
[ 0.117711] Tracing variant of Tasks RCU enabled.
[ 0.117712] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.117713] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[ 0.119861] NR_IRQS: 20736, nr_irqs: 2184, preallocated irqs: 16
[ 0.120836] Console: colour dummy device 80x25
[ 0.120897] printk: console [tty0] enabled
[ 0.120955] ACPI: Core revision 20200925
[ 0.122566] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ 0.122733] APIC: Switch to symmetric I/O mode setup
[ 0.122738] DMAR: Host address width 39
[ 0.122742] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ 0.122757] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ 0.122760] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ 0.122772] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ 0.122775] DMAR: RMRR base: 0x0000006b9ac000 end: 0x0000006b9cbfff
[ 0.122779] DMAR: RMRR base: 0x0000006f000000 end: 0x000000737fffff
[ 0.122784] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ 0.122787] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ 0.122789] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.126486] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.126490] x2apic enabled
[ 0.126532] Switched APIC routing to cluster x2apic.
[ 0.136351] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.152776] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fb62f12e8c, max_idle_ns: 440795238402 ns
[ 0.152778] Calibrating delay loop (skipped), value calculated using timer frequency.. 4401.32 BogoMIPS (lpj=7333320)
[ 0.152779] pid_max: default: 32768 minimum: 301
[ 0.156211] LSM: Security Framework initializing
[ 0.156231] Yama: becoming mindful.
[ 0.156295] AppArmor: AppArmor initialized
[ 0.156398] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.156458] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.157203] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.157298] process: using mwait in idle threads
[ 0.157305] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ 0.157308] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ 0.157318] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.157323] Spectre V2 : Mitigation: Enhanced IBRS
[ 0.157325] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.157329] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.157333] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.159593] Freeing SMP alternatives memory: 36K
[ 0.163017] smpboot: CPU0: Intel(R) Core(TM) i7-10870H CPU @ 2.20GHz (family: 0x6, model: 0xa5, stepping: 0x2)
[ 0.163378] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.163413] ... version: 4
[ 0.163415] ... bit width: 48
[ 0.163417] ... generic registers: 4
[ 0.163420] ... value mask: 0000ffffffffffff
[ 0.163421] ... max period: 00007fffffffffff
[ 0.163423] ... fixed-purpose events: 3
[ 0.163425] ... event mask: 000000070000000f
[ 0.163717] rcu: Hierarchical SRCU implementation.
[ 0.166110] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.166110] smp: Bringing up secondary CPUs ...
[ 0.166110] x86: Booting SMP configuration:
[ 0.166110] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
[ 0.200156] smp: Brought up 1 node, 16 CPUs
[ 0.200156] smpboot: Max logical packages: 1
[ 0.200156] smpboot: Total of 16 processors activated (70428.20 BogoMIPS)
[ 0.203228] devtmpfs: initialized
[ 0.203228] x86/mm: Memory block size: 128MB
[ 0.203635] PM: Registering ACPI NVS region [mem 0x6bb7e000-0x6da7dfff] (32505856 bytes)
[ 0.203635] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.203635] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.203635] pinctrl core: initialized pinctrl subsystem
[ 0.203635] PM: RTC time: 03:55:05, date: 2021-09-04
[ 0.203736] NET: Registered protocol family 16
[ 0.203986] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[ 0.204111] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.204245] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.204251] audit: initializing netlink subsys (disabled)
[ 0.204256] audit: type=2000 audit(1630727705.073:1): state=initialized audit_enabled=0 res=1
[ 0.204256] thermal_sys: Registered thermal governor 'fair_share'
[ 0.204256] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.204256] thermal_sys: Registered thermal governor 'step_wise'
[ 0.204256] thermal_sys: Registered thermal governor 'user_space'
[ 0.204256] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.204256] cpuidle: using governor ladder
[ 0.204256] cpuidle: using governor menu
[ 0.204256] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.204256] ACPI: bus type PCI registered
[ 0.204256] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.204256] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.204256] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.204256] PCI: Using configuration type 1 for base access
[ 0.206500] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.207019] Kprobes globally optimized
[ 0.207022] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.207022] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.207022] ACPI: Added _OSI(Module Device)
[ 0.207022] ACPI: Added _OSI(Processor Device)
[ 0.207022] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.207022] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.207022] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.207022] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.207022] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.274112] ACPI: 20 ACPI AML tables successfully acquired and loaded
[ 0.276033] ACPI: EC: EC started
[ 0.276033] ACPI: EC: interrupt blocked
[ 0.278225] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.278225] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.287069] ACPI: Dynamic OEM Table Load:
[ 0.287081] ACPI: SSDT 0xFFFF90A481996900 0000FC (v02 PmRef Cpu0Psd 00003000 INTL 20160422)
[ 0.288530] ACPI: \_SB_.PR00: _OSC native thermal LVT Acked
[ 0.292107] ACPI: Dynamic OEM Table Load:
[ 0.292116] ACPI: SSDT 0xFFFF90A48199D800 000400 (v02 PmRef Cpu0Cst 00003001 INTL 20160422)
[ 0.293677] ACPI: Dynamic OEM Table Load:
[ 0.293685] ACPI: SSDT 0xFFFF90A480D5A000 0004FD (v02 PmRef Cpu0Ist 00003000 INTL 20160422)
[ 0.295311] ACPI: Dynamic OEM Table Load:
[ 0.295318] ACPI: SSDT 0xFFFF90A481992000 000137 (v02 PmRef Cpu0Hwp 00003000 INTL 20160422)
[ 0.296818] ACPI: Dynamic OEM Table Load:
[ 0.296828] ACPI: SSDT 0xFFFF90A4819A2000 000BEA (v02 PmRef HwpLvt 00003000 INTL 20160422)
[ 0.298929] ACPI: Dynamic OEM Table Load:
[ 0.298937] ACPI: SSDT 0xFFFF90A480D5C800 000778 (v02 PmRef ApIst 00003000 INTL 20160422)
[ 0.300651] ACPI: Dynamic OEM Table Load:
[ 0.300659] ACPI: SSDT 0xFFFF90A48199A400 0003D7 (v02 PmRef ApHwp 00003000 INTL 20160422)
[ 0.302356] ACPI: Dynamic OEM Table Load:
[ 0.302365] ACPI: SSDT 0xFFFF90A4819A7000 000D22 (v02 PmRef ApPsd 00003000 INTL 20160422)
[ 0.304814] ACPI: Dynamic OEM Table Load:
[ 0.304822] ACPI: SSDT 0xFFFF90A48199BC00 0003CA (v02 PmRef ApCst 00003000 INTL 20160422)
[ 0.315193] ACPI: Interpreter enabled
[ 0.315237] ACPI: (supports S0 S3 S4 S5)
[ 0.315238] ACPI: Using IOAPIC for interrupt routing
[ 0.315275] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.318455] ACPI: Enabled 7 GPEs in block 00 to 7F
[ 0.319204] ACPI: Power Resource [PG00] (on)
[ 0.326448] ACPI: Power Resource [BTPR] (on)
[ 0.327509] ACPI: Power Resource [DBTP] (on)
[ 0.327874] ACPI: Power Resource [USBC] (on)
[ 0.343236] ACPI: Power Resource [V0PR] (on)
[ 0.343431] ACPI: Power Resource [V1PR] (on)
[ 0.343621] ACPI: Power Resource [V2PR] (on)
[ 0.349320] ACPI: Power Resource [WRST] (on)
[ 0.349631] acpi ABCD0000:00: ACPI dock station (docks/bays count: 1)
[ 0.356220] ACPI: Power Resource [FN00] (off)
[ 0.356316] ACPI: Power Resource [FN01] (off)
[ 0.356406] ACPI: Power Resource [FN02] (off)
[ 0.356496] ACPI: Power Resource [FN03] (off)
[ 0.356588] ACPI: Power Resource [FN04] (off)
[ 0.357250] ACPI: Power Resource [PIN] (off)
[ 0.357685] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ 0.357691] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.361029] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 0.361030] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.364367] PCI host bridge to bus 0000:00
[ 0.364369] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.364370] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.364371] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.364372] pci_bus 0000:00: root bus resource [mem 0x73800000-0xdfffffff window]
[ 0.364372] pci_bus 0000:00: root bus resource [mem 0xfc800000-0xfe7fffff window]
[ 0.364373] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.364394] pci 0000:00:00.0: [8086:9b44] type 00 class 0x060000
[ 0.365909] pci 0000:00:01.0: [8086:1901] type 01 class 0x060400
[ 0.365948] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.367424] pci 0000:00:02.0: [8086:9bc4] type 00 class 0x030000
[ 0.367431] pci 0000:00:02.0: reg 0x10: [mem 0xa2000000-0xa2ffffff 64bit]
[ 0.367436] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.367439] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.367454] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.368697] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ 0.368705] pci 0000:00:04.0: reg 0x10: [mem 0xa5690000-0xa5697fff 64bit]
[ 0.370015] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ 0.370023] pci 0000:00:08.0: reg 0x10: [mem 0xa56a4000-0xa56a4fff 64bit]
[ 0.371329] pci 0000:00:12.0: [8086:06f9] type 00 class 0x118000
[ 0.371365] pci 0000:00:12.0: reg 0x10: [mem 0xa56a5000-0xa56a5fff 64bit]
[ 0.372773] pci 0000:00:14.0: [8086:06ed] type 00 class 0x0c0330
[ 0.372809] pci 0000:00:14.0: reg 0x10: [mem 0xa5680000-0xa568ffff 64bit]
[ 0.372950] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.374292] pci 0000:00:14.2: [8086:06ef] type 00 class 0x050000
[ 0.374326] pci 0000:00:14.2: reg 0x10: [mem 0xa56a0000-0xa56a1fff 64bit]
[ 0.374348] pci 0000:00:14.2: reg 0x18: [mem 0xa56a6000-0xa56a6fff 64bit]
[ 0.375661] pci 0000:00:14.3: [8086:06f0] type 00 class 0x028000
[ 0.375711] pci 0000:00:14.3: reg 0x10: [mem 0xa5698000-0xa569bfff 64bit]
[ 0.375939] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.377268] pci 0000:00:15.0: [8086:06e8] type 00 class 0x0c8000
[ 0.377299] pci 0000:00:15.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.378683] pci 0000:00:15.1: [8086:06e9] type 00 class 0x0c8000
[ 0.378714] pci 0000:00:15.1: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 0.380170] pci 0000:00:16.0: [8086:06e0] type 00 class 0x078000
[ 0.380202] pci 0000:00:16.0: reg 0x10: [mem 0xa56a9000-0xa56a9fff 64bit]
[ 0.380322] pci 0000:00:16.0: PME# supported from D3hot
[ 0.381791] pci 0000:00:17.0: [8086:282a] type 00 class 0x010400
[ 0.381835] pci 0000:00:17.0: reg 0x10: [mem 0xa56a2000-0xa56a3fff]
[ 0.381858] pci 0000:00:17.0: reg 0x14: [mem 0xa56ad000-0xa56ad0ff]
[ 0.381882] pci 0000:00:17.0: reg 0x18: [io 0x5080-0x5087]
[ 0.381905] pci 0000:00:17.0: reg 0x1c: [io 0x5088-0x508b]
[ 0.381928] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ 0.381951] pci 0000:00:17.0: reg 0x24: [mem 0xa56ac000-0xa56ac7ff]
[ 0.382094] pci 0000:00:17.0: PME# supported from D3hot
[ 0.383505] pci 0000:00:1d.0: [8086:06b0] type 01 class 0x060400
[ 0.383706] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.383756] pci 0000:00:1d.0: PTM enabled (root), 4ns granularity
[ 0.385274] pci 0000:00:1d.2: [8086:06b2] type 01 class 0x060400
[ 0.385468] pci 0000:00:1d.2: PME# supported from D0 D3hot D3cold
[ 0.385510] pci 0000:00:1d.2: PTM enabled (root), 4ns granularity
[ 0.387035] pci 0000:00:1d.5: [8086:06b5] type 01 class 0x060400
[ 0.387232] pci 0000:00:1d.5: PME# supported from D0 D3hot D3cold
[ 0.387279] pci 0000:00:1d.5: PTM enabled (root), 4ns granularity
[ 0.388778] pci 0000:00:1d.6: [8086:06b6] type 01 class 0x060400
[ 0.388966] pci 0000:00:1d.6: PME# supported from D0 D3hot D3cold
[ 0.389003] pci 0000:00:1d.6: PTM enabled (root), 4ns granularity
[ 0.390513] pci 0000:00:1f.0: [8086:068d] type 00 class 0x060100
[ 0.392076] pci 0000:00:1f.3: [8086:06c8] type 00 class 0x040300
[ 0.392135] pci 0000:00:1f.3: reg 0x10: [mem 0xa569c000-0xa569ffff 64bit]
[ 0.392209] pci 0000:00:1f.3: reg 0x20: [mem 0xa5100000-0xa51fffff 64bit]
[ 0.392362] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.393922] pci 0000:00:1f.4: [8086:06a3] type 00 class 0x0c0500
[ 0.394104] pci 0000:00:1f.4: reg 0x10: [mem 0xa56aa000-0xa56aa0ff 64bit]
[ 0.394309] pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
[ 0.395809] pci 0000:00:1f.5: [8086:06a4] type 00 class 0x0c8000
[ 0.395834] pci 0000:00:1f.5: reg 0x10: [mem 0xfe010000-0xfe010fff]
[ 0.397171] pci 0000:01:00.0: [10de:1f95] type 00 class 0x030000
[ 0.397181] pci 0000:01:00.0: reg 0x10: [mem 0xa4000000-0xa4ffffff]
[ 0.397190] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ 0.397198] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ 0.397203] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ 0.397209] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ 0.397258] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 0.397303] pci 0000:01:00.0: 63.008 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x8 link at 0000:00:01.0 (capable of 126.016 Gb/s with 8.0 GT/s PCIe x16 link)
[ 0.397398] pci 0000:01:00.1: [10de:10fa] type 00 class 0x040300
[ 0.397407] pci 0000:01:00.1: reg 0x10: [mem 0xa5000000-0xa5003fff]
[ 0.397515] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[ 0.397517] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.397518] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa50fffff]
[ 0.397521] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.397735] pci 0000:06:00.0: [8086:0975] type 00 class 0x010802
[ 0.397770] pci 0000:06:00.0: reg 0x10: [mem 0xa5500000-0xa5503fff 64bit]
[ 0.398265] pci 0000:00:1d.0: PCI bridge to [bus 06]
[ 0.398274] pci 0000:00:1d.0: bridge window [mem 0xa5500000-0xa55fffff]
[ 0.398495] pci 0000:07:00.0: [8086:0975] type 00 class 0x010802
[ 0.398530] pci 0000:07:00.0: reg 0x10: [mem 0xa5400000-0xa5403fff 64bit]
[ 0.398612] pci 0000:07:00.0: enabling Extended Tags
[ 0.398979] pci 0000:00:1d.2: PCI bridge to [bus 07]
[ 0.398987] pci 0000:00:1d.2: bridge window [mem 0xa5400000-0xa54fffff]
[ 0.399106] pci 0000:08:00.0: [10ec:8168] type 00 class 0x020000
[ 0.399133] pci 0000:08:00.0: reg 0x10: [io 0x3000-0x30ff]
[ 0.399170] pci 0000:08:00.0: reg 0x18: [mem 0xa5304000-0xa5304fff 64bit]
[ 0.399194] pci 0000:08:00.0: reg 0x20: [mem 0xa5300000-0xa5303fff 64bit]
[ 0.399354] pci 0000:08:00.0: supports D1 D2
[ 0.399355] pci 0000:08:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.399581] pci 0000:00:1d.5: PCI bridge to [bus 08]
[ 0.399586] pci 0000:00:1d.5: bridge window [io 0x3000-0x3fff]
[ 0.399591] pci 0000:00:1d.5: bridge window [mem 0xa5300000-0xa53fffff]
[ 0.401013] pci 0000:09:00.0: [1aea:6625] type 00 class 0xff0000
[ 0.401049] pci 0000:09:00.0: reg 0x10: [mem 0xa5200000-0xa5200fff 64bit]
[ 0.401235] pci 0000:09:00.0: supports D1 D2
[ 0.401236] pci 0000:09:00.0: PME# supported from D1 D2 D3hot D3cold
[ 0.402721] pci 0000:00:1d.6: PCI bridge to [bus 09]
[ 0.402730] pci 0000:00:1d.6: bridge window [mem 0xa5200000-0xa52fffff]
[ 0.407266] ACPI: EC: interrupt unblocked
[ 0.407267] ACPI: EC: event unblocked
[ 0.407290] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.407290] ACPI: EC: GPE=0x17
[ 0.407291] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot ECDT EC initialization complete
[ 0.407292] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.407343] iommu: Default domain type: Translated
[ 0.409457] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.409457] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.409457] pci 0000:01:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 0.409457] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.409457] pci 0000:01:00.0: vgaarb: bridge control possible
[ 0.409458] vgaarb: loaded
[ 0.409587] SCSI subsystem initialized
[ 0.409594] libata version 3.00 loaded.
[ 0.409594] ACPI: bus type USB registered
[ 0.409594] usbcore: registered new interface driver usbfs
[ 0.409594] usbcore: registered new interface driver hub
[ 0.409594] usbcore: registered new device driver usb
[ 0.409594] pps_core: LinuxPPS API ver. 1 registered
[ 0.409594] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.409594] PTP clock support registered
[ 0.409594] EDAC MC: Ver: 3.0.0
[ 0.411050] Registered efivars operations
[ 0.411050] NetLabel: Initializing
[ 0.411050] NetLabel: domain hash size = 128
[ 0.411050] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.411050] NetLabel: unlabeled traffic allowed by default
[ 0.411050] PCI: Using ACPI for IRQ routing
[ 0.494062] PCI: pci_cache_line_size set to 64 bytes
[ 0.502368] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.502369] e820: reserve RAM buffer [mem 0x56fcf000-0x57ffffff]
[ 0.502369] e820: reserve RAM buffer [mem 0x6908e000-0x6bffffff]
[ 0.502370] e820: reserve RAM buffer [mem 0x6db4f000-0x6fffffff]
[ 0.502371] e820: reserve RAM buffer [mem 0x48a800000-0x48bffffff]
[ 0.502778] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.502778] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.502779] clocksource: Switched to clocksource tsc-early
[ 0.511341] VFS: Disk quotas dquot_6.6.0
[ 0.511353] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.511425] AppArmor: AppArmor Filesystem Enabled
[ 0.511441] pnp: PnP ACPI init
[ 0.511523] system 00:00: [mem 0x40000000-0x403fffff] could not be reserved
[ 0.511527] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.511784] system 00:01: [io 0x1800-0x18fe] has been reserved
[ 0.511785] system 00:01: [mem 0xfd000000-0xfd69ffff] has been reserved
[ 0.511786] system 00:01: [mem 0xfd6c0000-0xfd6cffff] has been reserved
[ 0.511787] system 00:01: [mem 0xfd6f0000-0xfdffffff] has been reserved
[ 0.511788] system 00:01: [mem 0xfe000000-0xfe01ffff] could not be reserved
[ 0.511789] system 00:01: [mem 0xfe200000-0xfe7fffff] has been reserved
[ 0.511790] system 00:01: [mem 0xfc7e0000-0xfc7e0fff] has been reserved
[ 0.511791] system 00:01: [mem 0xff000000-0xffffffff] could not be reserved
[ 0.511794] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.512142] system 00:02: [io 0x2000-0x20fe] has been reserved
[ 0.512144] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.512255] system 00:03: [io 0x0680-0x069f] has been reserved
[ 0.512256] system 00:03: [io 0x164e-0x164f] has been reserved
[ 0.512257] system 00:03: [io 0xfd60-0xfd63] has been reserved
[ 0.512260] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.512385] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.512388] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.512422] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.513363] system 00:06: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.513364] system 00:06: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.513365] system 00:06: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.513366] system 00:06: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.513367] system 00:06: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.513369] system 00:06: [mem 0xfed90000-0xfed93fff] could not be reserved
[ 0.513370] system 00:06: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.513371] system 00:06: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.513373] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.513869] system 00:07: [mem 0xfe038000-0xfe038fff] has been reserved
[ 0.513871] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.514123] pnp: PnP ACPI: found 8 devices
[ 0.519521] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.519563] NET: Registered protocol family 2
[ 0.519705] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.521320] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.521391] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.521554] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.521614] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.521677] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[ 0.521732] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.521770] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[ 0.521929] NET: Registered protocol family 1
[ 0.521934] NET: Registered protocol family 44
[ 0.521937] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ 0.521947] pci 0000:00:15.0: BAR 0: assigned [mem 0x73800000-0x73800fff 64bit]
[ 0.521966] pci 0000:00:15.1: BAR 0: assigned [mem 0x73801000-0x73801fff 64bit]
[ 0.521982] pci 0000:01:00.0: BAR 6: assigned [mem 0xa3000000-0xa307ffff pref]
[ 0.521984] pci 0000:00:01.0: PCI bridge to [bus 01-05]
[ 0.521985] pci 0000:00:01.0: bridge window [io 0x4000-0x4fff]
[ 0.521987] pci 0000:00:01.0: bridge window [mem 0xa3000000-0xa50fffff]
[ 0.521989] pci 0000:00:01.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.521992] pci 0000:00:1d.0: PCI bridge to [bus 06]
[ 0.522000] pci 0000:00:1d.0: bridge window [mem 0xa5500000-0xa55fffff]
[ 0.522013] pci 0000:00:1d.2: PCI bridge to [bus 07]
[ 0.522020] pci 0000:00:1d.2: bridge window [mem 0xa5400000-0xa54fffff]
[ 0.522033] pci 0000:00:1d.5: PCI bridge to [bus 08]
[ 0.522035] pci 0000:00:1d.5: bridge window [io 0x3000-0x3fff]
[ 0.522042] pci 0000:00:1d.5: bridge window [mem 0xa5300000-0xa53fffff]
[ 0.522055] pci 0000:00:1d.6: PCI bridge to [bus 09]
[ 0.522061] pci 0000:00:1d.6: bridge window [mem 0xa5200000-0xa52fffff]
[ 0.522074] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.522075] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.522076] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.522077] pci_bus 0000:00: resource 7 [mem 0x73800000-0xdfffffff window]
[ 0.522078] pci_bus 0000:00: resource 8 [mem 0xfc800000-0xfe7fffff window]
[ 0.522079] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ 0.522080] pci_bus 0000:01: resource 1 [mem 0xa3000000-0xa50fffff]
[ 0.522080] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa1ffffff 64bit pref]
[ 0.522081] pci_bus 0000:06: resource 1 [mem 0xa5500000-0xa55fffff]
[ 0.522082] pci_bus 0000:07: resource 1 [mem 0xa5400000-0xa54fffff]
[ 0.522083] pci_bus 0000:08: resource 0 [io 0x3000-0x3fff]
[ 0.522084] pci_bus 0000:08: resource 1 [mem 0xa5300000-0xa53fffff]
[ 0.522085] pci_bus 0000:09: resource 1 [mem 0xa5200000-0xa52fffff]
[ 0.522249] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.524391] pci 0000:01:00.1: D0 power state depends on 0000:01:00.0
[ 0.525960] PCI: CLS 64 bytes, default 64
[ 0.525987] Trying to unpack rootfs image as initramfs...
[ 0.644630] Freeing initrd memory: 13956K
[ 0.644665] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.644667] software IO TLB: mapped [mem 0x00000000646c6000-0x00000000686c6000] (64MB)
[ 0.644765] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.645706] check: Scanning for low memory corruption every 60 seconds
[ 0.645986] Initialise system trusted keyrings
[ 0.645992] Key type blacklist registered
[ 0.646026] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[ 0.646849] zbud: loaded
[ 0.654799] Key type asymmetric registered
[ 0.654800] Asymmetric key parser 'x509' registered
[ 0.654805] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.654831] io scheduler mq-deadline registered
[ 0.654832] io scheduler kyber registered
[ 0.654849] io scheduler bfq registered
[ 0.654948] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 0.659144] pcieport 0000:00:01.0: PME: Signaling with IRQ 122
[ 0.659394] pcieport 0000:00:1d.0: PME: Signaling with IRQ 123
[ 0.659457] pcieport 0000:00:1d.0: AER: enabled with IRQ 123
[ 0.659494] pcieport 0000:00:1d.0: DPC: enabled with IRQ 123
[ 0.659496] pcieport 0000:00:1d.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.659798] pcieport 0000:00:1d.2: PME: Signaling with IRQ 124
[ 0.659852] pcieport 0000:00:1d.2: AER: enabled with IRQ 124
[ 0.659881] pcieport 0000:00:1d.2: DPC: enabled with IRQ 124
[ 0.659882] pcieport 0000:00:1d.2: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.660175] pcieport 0000:00:1d.5: PME: Signaling with IRQ 125
[ 0.660231] pcieport 0000:00:1d.5: AER: enabled with IRQ 125
[ 0.660260] pcieport 0000:00:1d.5: DPC: enabled with IRQ 125
[ 0.660261] pcieport 0000:00:1d.5: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.660562] pcieport 0000:00:1d.6: PME: Signaling with IRQ 126
[ 0.660614] pcieport 0000:00:1d.6: AER: enabled with IRQ 126
[ 0.660641] pcieport 0000:00:1d.6: DPC: enabled with IRQ 126
[ 0.660642] pcieport 0000:00:1d.6: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 0.660758] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.660785] efifb: probing for efifb
[ 0.660797] efifb: showing boot graphics
[ 0.661373] efifb: framebuffer at 0x80000000, using 8128k, total 8128k
[ 0.661374] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ 0.661374] efifb: scrolling: redraw
[ 0.661375] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.661403] fbcon: Deferring console take-over
[ 0.661404] fb0: EFI VGA frame buffer device
[ 0.661409] intel_idle: MWAIT substates: 0x11142120
[ 0.661678] Monitor-Mwait will be used to enter C-1 state
[ 0.661684] Monitor-Mwait will be used to enter C-2 state
[ 0.661689] Monitor-Mwait will be used to enter C-3 state
[ 0.661692] ACPI: \_SB_.PR00: Found 3 idle states
[ 0.661693] intel_idle: v0.5.1 model 0xA5
[ 0.662066] intel_idle: Local APIC timer is reliable in all C-states
[ 0.662201] ACPI: AC Adapter [ACAD] (off-line)
[ 0.662245] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:20/PNP0C0D:00/input/input0
[ 0.662256] ACPI: Lid Switch [LID0]
[ 0.662285] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.669502] ACPI: Power Button [PWRB]
[ 0.669534] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.669782] ACPI: Power Button [PWRF]
[ 0.672955] [Firmware Bug]: Invalid critical threshold (0)
[ 0.673224] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.673225] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.673284] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.673284] ACPI: Thermal Zone [TZ02] (10 C)
[ 0.673410] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.674011] battery: ACPI: Battery Slot [BAT1] (battery present)
[ 0.674351] Non-volatile memory driver v1.3
[ 0.674351] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ 0.674352] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ 0.675638] nvme 0000:06:00.0: platform quirk: setting simple suspend
[ 0.675659] nvme nvme0: pci function 0000:06:00.0
[ 0.675694] nvme 0000:07:00.0: platform quirk: setting simple suspend
[ 0.679254] nvme nvme1: pci function 0000:07:00.0
[ 0.679276] ahci 0000:00:17.0: version 3.0
[ 0.680052] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl RAID mode
[ 0.680054] ahci 0000:00:17.0: flags: 64bit ncq sntf pm clo only pio slum part ems deso sadm sds apst
[ 0.681033] scsi host0: ahci
[ 0.681171] ata1: SATA max UDMA/133 abar m2048@0xa56ac000 port 0xa56ac100 irq 129
[ 0.681188] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.681190] ehci-pci: EHCI PCI platform driver
[ 0.681198] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.681199] ohci-pci: OHCI PCI platform driver
[ 0.681203] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.681233] usbcore: registered new interface driver usbserial_generic
[ 0.681235] usbserial: USB Serial support registered for generic
[ 0.681267] i8042: PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.681267] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.681960] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.682095] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.683209] rtc_cmos rtc_cmos: registered as rtc0
[ 0.683541] rtc_cmos rtc_cmos: setting system clock to 2021-09-04T03:55:05 UTC (1630727705)
[ 0.683552] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 0.683579] intel_pstate: Intel P-state driver initializing
[ 0.685250] intel_pstate: HWP enabled
[ 0.685678] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.685878] hid: raw HID events driver (C) Jiri Kosina
[ 0.685920] ashmem: initialized
[ 0.685957] intel_pmc_core INT33A1:00: initialized
[ 0.686019] drop_monitor: Initializing network drop monitor service
[ 0.686068] Initializing XFRM netlink socket
[ 0.686169] NET: Registered protocol family 10
[ 0.689991] Segment Routing with IPv6
[ 0.689992] RPL Segment Routing with IPv6
[ 0.690009] NET: Registered protocol family 17
[ 0.690041] nvme nvme0: 8/0/0 default/read/poll queues
[ 0.691496] microcode: sig=0xa0652, pf=0x20, revision=0xea
[ 0.691734] microcode: Microcode Update Driver: v2.2.
[ 0.691754] IPI shorthand broadcast: enabled
[ 0.691760] sched_clock: Marking stable (682632744, 8774325)->(710443482, -19036413)
[ 0.691965] registered taskstats version 1
[ 0.691991] Loading compiled-in X.509 certificates
[ 0.692222] nvme0n1: p1 p2 p3 p4 p5 p6
[ 0.692512] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.694349] Loaded X.509 cert 'Build time autogenerated kernel key: 181d49fec11759afda4ded534d4574c66843ba83'
[ 0.696459] zswap: loaded using pool zstd/z3fold
[ 0.696770] Key type ._fscrypt registered
[ 0.696771] Key type .fscrypt registered
[ 0.696772] Key type fscrypt-provisioning registered
[ 0.696800] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.698261] PM: Magic number: 5:524:916
[ 0.698274] tty ptmx: hash matches
[ 0.698288] msr msr11: hash matches
[ 0.698414] RAS: Correctable Errors collector initialized.
[ 0.704442] nvme nvme1: 8/0/0 default/read/poll queues
[ 0.996321] ata1: SATA link down (SStatus 4 SControl 300)
[ 1.002192] Freeing unused decrypted memory: 2036K
[ 1.002889] Freeing unused kernel image (initmem) memory: 1708K
[ 1.002893] Write protecting the kernel read-only data: 26624k
[ 1.004256] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.004933] Freeing unused kernel image (rodata/data gap) memory: 1352K
[ 1.015251] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.015253] rodata_test: all tests were successful
[ 1.015257] Run /init as init process
[ 1.015258] with arguments:
[ 1.015258] /init
[ 1.015259] splash
[ 1.015259] with environment:
[ 1.015260] HOME=/
[ 1.015260] TERM=linux
[ 1.015260] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ 1.256906] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.256913] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 1.258024] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000000009810
[ 1.258032] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.258408] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.258409] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.258410] usb usb1: Product: xHCI Host Controller
[ 1.258413] usb usb1: Manufacturer: Linux 5.10.60-1-MANJARO xhci-hcd
[ 1.258414] usb usb1: SerialNumber: 0000:00:14.0
[ 1.258497] hub 1-0:1.0: USB hub found
[ 1.259741] alcor_pci 0000:09:00.0: enabling device (0000 -> 0002)
[ 1.259779] hub 1-0:1.0: 16 ports detected
[ 1.265376] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.265378] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.265381] xhci_hcd 0000:00:14.0: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.265423] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.265425] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.265426] usb usb2: Product: xHCI Host Controller
[ 1.265428] usb usb2: Manufacturer: Linux 5.10.60-1-MANJARO xhci-hcd
[ 1.265429] usb usb2: SerialNumber: 0000:00:14.0
[ 1.265542] hub 2-0:1.0: USB hub found
[ 1.265562] hub 2-0:1.0: 8 ports detected
[ 1.266363] usb: port power management may be unreliable
[ 1.509239] random: fast init done
[ 1.512807] usb 1-5: new high-speed USB device number 2 using xhci_hcd
[ 1.513979] EXT4-fs (nvme0n1p6): mounted filesystem with ordered data mode. Opts: (null)
[ 1.649486] tsc: Refined TSC clocksource calibration: 2207.999 MHz
[ 1.649497] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fd3b75da7f, max_idle_ns: 440795296082 ns
[ 1.649581] clocksource: Switched to clocksource tsc
[ 1.658508] systemd[1]: systemd 248.7-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 1.673117] systemd[1]: Detected architecture x86-64.
[ 1.673836] systemd[1]: Hostname set to <khushi>.
[ 1.678526] usb 1-5: New USB device found, idVendor=0408, idProduct=5300, bcdDevice= 0.06
[ 1.678531] usb 1-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.678534] usb 1-5: Product: HP Wide Vision HD Camera
[ 1.678536] usb 1-5: Manufacturer: Quanta
[ 1.678538] usb 1-5: SerialNumber: 200901010001
[ 1.802872] usb 1-14: new full-speed USB device number 3 using xhci_hcd
[ 1.926052] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 1.944425] usb 1-14: New USB device found, idVendor=8087, idProduct=0026, bcdDevice= 0.02
[ 1.944426] usb 1-14: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.993227] systemd[1]: Queued start job for default target Graphical Interface.
[ 1.994436] systemd[1]: Created slice Slice /system/getty.
[ 1.994600] systemd[1]: Created slice Slice /system/modprobe.
[ 1.994792] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 1.994905] systemd[1]: Created slice User and Session Slice.
[ 1.994944] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.995044] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 1.995070] systemd[1]: Reached target Login Prompts.
[ 1.995087] systemd[1]: Reached target Remote File Systems.
[ 1.995095] systemd[1]: Reached target Slice Units.
[ 1.995107] systemd[1]: Reached target Swaps.
[ 1.995119] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[ 1.995158] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 1.995333] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.996001] systemd[1]: Listening on Process Core Dump Socket.
[ 1.996089] systemd[1]: Listening on Journal Audit Socket.
[ 1.996159] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.996219] systemd[1]: Listening on Journal Socket.
[ 1.996297] systemd[1]: Listening on udev Control Socket.
[ 1.996355] systemd[1]: Listening on udev Kernel Socket.
[ 1.996830] systemd[1]: Mounting Huge Pages File System...
[ 1.997302] systemd[1]: Mounting POSIX Message Queue File System...
[ 1.997813] systemd[1]: Mounting Kernel Debug File System...
[ 1.998325] systemd[1]: Mounting Kernel Trace File System...
[ 1.999278] systemd[1]: Mounting Temporary Directory /tmp...
[ 1.999797] systemd[1]: Starting Load AppArmor profiles...
[ 2.000278] systemd[1]: Starting Create List of Static Device Nodes...
[ 2.000757] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 2.001263] systemd[1]: Starting Load Kernel Module configfs...
[ 2.001754] systemd[1]: Starting Load Kernel Module drm...
[ 2.002259] systemd[1]: Starting Load Kernel Module fuse...
[ 2.002799] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 2.002824] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 2.002854] random: lvm: uninitialized urandom read (4 bytes read)
[ 2.004107] systemd[1]: Starting Load Kernel Modules...
[ 2.004596] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 2.004635] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ 2.005087] systemd[1]: Starting Coldplug All udev Devices...
[ 2.005626] systemd[1]: Starting Setup Virtual Console...
[ 2.006605] systemd[1]: Mounted Huge Pages File System.
[ 2.006690] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.006752] systemd[1]: Mounted Kernel Debug File System.
[ 2.006822] systemd[1]: Mounted Kernel Trace File System.
[ 2.006881] systemd[1]: Mounted Temporary Directory /tmp.
[ 2.007053] systemd[1]: Finished Create List of Static Device Nodes.
[ 2.007266] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.007379] systemd[1]: Finished Load Kernel Module configfs.
[ 2.007514] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.007627] systemd[1]: Finished Load Kernel Module drm.
[ 2.008152] systemd[1]: Mounting Kernel Configuration File System...
[ 2.009719] systemd[1]: Mounted Kernel Configuration File System.
[ 2.009841] EXT4-fs (nvme0n1p6): re-mounted. Opts: (null)
[ 2.010532] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 2.010653] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ 2.012521] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 2.013110] systemd[1]: Starting Load/Save Random Seed...
[ 2.013606] systemd[1]: Starting Create System Users...
[ 2.017754] Linux agpgart interface v0.103
[ 2.021573] fuse: init (API version 7.32)
[ 2.022334] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.022501] systemd[1]: Finished Load Kernel Module fuse.
[ 2.023154] systemd[1]: Mounting FUSE Control File System...
[ 2.025558] systemd[1]: Mounted FUSE Control File System.
[ 2.041122] systemd[1]: Finished Create System Users.
[ 2.041886] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 2.051785] systemd[1]: Finished Setup Virtual Console.
[ 2.058797] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 2.060492] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ 2.062015] systemd[1]: Starting Journal Service...
[ 2.063725] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 2.070391] systemd[1]: Finished Coldplug All udev Devices.
[ 2.089037] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 2.089090] audit: type=1130 audit(1630727706.899:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.089203] systemd[1]: Reached target Preparation for Local File Systems.
[ 2.089241] systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
[ 2.091342] systemd[1]: Mounting Mount unit for cmake, revision 918...
[ 2.092957] systemd[1]: Mounting Mount unit for cmake, revision 924...
[ 2.094958] systemd[1]: Mounting Mount unit for core18, revision 2128...
[ 2.096491] audit: type=1400 audit(1630727706.909:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=338 comm="apparmor_parser"
[ 2.097617] systemd[1]: Mounting Mount unit for snapd, revision 12704...
[ 2.098524] systemd[1]: Mounting Mount unit for snapd, revision 12883...
[ 2.100642] loop: module loaded
[ 2.107570] systemd[1]: Started Journal Service.
[ 2.107655] audit: type=1130 audit(1630727706.919:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.113257] systemd-journald[347]: Received client request to flush runtime journal.
[ 2.123174] audit: type=1130 audit(1630727706.936:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.131008] audit: type=1400 audit(1630727706.942:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=341 comm="apparmor_parser"
[ 2.144405] audit: type=1400 audit(1630727706.956:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=339 comm="apparmor_parser"
[ 2.145563] audit: type=1400 audit(1630727706.956:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=339 comm="apparmor_parser"
[ 2.148384] audit: type=1130 audit(1630727706.959:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=plymouth-start comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 2.173337] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.181451] ACPI BIOS Error (bug): Could not resolve symbol [\DPPP], AE_NOT_FOUND (20200925/psargs-330)
[ 2.181462] ACPI Error: Aborting method \_SB.IETM.IDSP due to previous error (AE_NOT_FOUND) (20200925/psparse-529)
[ 2.191214] input: HP Wireless hotkeys as /devices/virtual/input/input4
[ 2.199229] audit: type=1400 audit(1630727707.009:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=340 comm="apparmor_parser"
[ 2.199529] hp_accel: laptop model unknown, using default axes configuration
[ 2.209565] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.209569] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.209570] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.209572] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
[ 2.209817] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 2.209994] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:03)
[ 2.210025] wmi_bus wmi_bus-PNP0C14:05: WQBJ data block query control method not found
[ 2.246477] lis3lv02d: 8 bits 3DC sensor found
[ 2.270069] random: mktemp: uninitialized urandom read (6 bytes read)
[ 2.294719] intel_rapl_common: Found RAPL domain package
[ 2.294721] intel_rapl_common: Found RAPL domain dram
[ 2.294926] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ 2.299509] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input5
[ 2.305750] intel-lpss 0000:00:15.0: enabling device (0004 -> 0006)
[ 2.306076] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 2.313278] i2c_hid i2c-ELAN0710:01: supply vdd not found, using dummy regulator
[ 2.313321] i2c_hid i2c-ELAN0710:01: supply vddl not found, using dummy regulator
[ 2.329472] intel-lpss 0000:00:15.1: enabling device (0004 -> 0006)
[ 2.330013] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 2.345986] random: crng init done
[ 2.345988] random: 3 urandom warning(s) missed due to ratelimiting
[ 2.393160] input: ELAN0710:01 04F3:30ED Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN0710:01/0018:04F3:30ED.0001/input/input6
[ 2.393270] input: ELAN0710:01 04F3:30ED Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN0710:01/0018:04F3:30ED.0001/input/input8
[ 2.393433] hid-generic 0018:04F3:30ED.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0710:01 04F3:30ED] on i2c-ELAN0710:01
[ 2.397241] nvidia: loading out-of-tree module taints kernel.
[ 2.397252] nvidia: module license 'NVIDIA' taints kernel.
[ 2.397253] Disabling lock debugging due to kernel taint
[ 2.409964] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 2.417271] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 2.417361] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 2.419194] i2c i2c-2: 1/2 memory slots populated (from DMI)
[ 2.419354] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 2.427385] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.428674] nvidia-nvlink: Nvlink Core is being initialized, major device number 234
[ 2.429104] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[ 2.429294] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 2.431570] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.432721] intel-spi 0000:00:1f.5: w25q128 (16384 Kbytes)
[ 2.435115] Creating 1 MTD partitions on "0000:00:1f.5":
[ 2.435118] 0x000000000000-0x000001000000 : "BIOS"
[ 2.440708] r8169 0000:08:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.443839] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 2.455021] libphy: r8169: probed
[ 2.455267] r8169 0000:08:00.0 eth0: RTL8168h/8111h, 48:9e:bd:76:26:40, XID 541, IRQ 148
[ 2.455270] r8169 0000:08:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[ 2.479496] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.63.01 Tue Aug 3 20:44:16 UTC 2021
[ 2.558151] Intel(R) Wireless WiFi driver for Linux
[ 2.566611] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 2.566626] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 65.3.35.22
[ 2.566951] iwlwifi 0000:00:14.3: loaded firmware version 59.601f3a66.0 QuZ-a0-hr-b0-59.ucode op_mode iwlmvm
[ 2.626788] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 470.63.01 Tue Aug 3 20:30:55 UTC 2021
[ 2.626866] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ 2.626867] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 2.626868] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 2.626869] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 2.626870] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 2.626870] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 2.688470] checking generic (80000000 7f0000) vs hw (a2000000 1000000)
[ 2.688473] checking generic (80000000 7f0000) vs hw (80000000 10000000)
[ 2.688474] fb0: switching to inteldrmfb from EFI VGA
[ 2.692029] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 2.695746] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 2.696631] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 2.697750] cryptd: max_cpu_qlen set to 1000
[ 2.717715] AVX2 version of gcm_enc/dec engaged.
[ 2.717718] AES CTR mode by8 optimization enabled
[ 2.718039] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 2.718042] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 2.723493] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[ 2.724343] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 2.724366] ACPI: Video Device [PEGP] (multi-head: yes rom: no post: no)
[ 2.724725] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/LNXVIDEO:00/input/input10
[ 2.726948] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 2.727197] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input11
[ 2.728494] fbcon: i915drmfb (fb0) is primary device
[ 2.728495] fbcon: Deferring console take-over
[ 2.728497] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 2.816486] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX201 160MHz, REV=0x354
[ 2.818321] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[ 2.819701] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[ 2.819873] snd_hda_intel 0000:01:00.1: Disabling MSI
[ 2.819883] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[ 3.001540] iwlwifi 0000:00:14.3: base HW address: f4:4e:e3:aa:05:fa
[ 3.013238] thermal thermal_zone8: failed to read out thermal zone (-61)
[ 3.208127] intel_rapl_common: Found RAPL domain package
[ 3.208130] intel_rapl_common: Found RAPL domain core
[ 3.208131] intel_rapl_common: Found RAPL domain uncore
[ 3.208133] intel_rapl_common: Found RAPL domain dram
[ 3.208134] intel_rapl_common: Found RAPL domain psys
[ 3.226018] iTCO_vendor_support: vendor-support=0
[ 3.229443] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 3.229537] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[ 3.229766] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 3.243420] r8169 0000:08:00.0 eno1: renamed from eth0
[ 3.283025] input: ELAN0710:01 04F3:30ED Mouse as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN0710:01/0018:04F3:30ED.0001/input/input13
[ 3.283110] input: ELAN0710:01 04F3:30ED Touchpad as /devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-0/i2c-ELAN0710:01/0018:04F3:30ED.0001/input/input15
[ 3.283601] hid-multitouch 0018:04F3:30ED.0001: input,hidraw0: I2C HID v1.00 Mouse [ELAN0710:01 04F3:30ED] on i2c-ELAN0710:01
[ 3.289173] mousedev: PS/2 mouse device common for all mice
[ 3.302803] Generic FE-GE Realtek PHY r8169-0-800:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-800:00, irq=IGNORE)
[ 3.493065] r8169 0000:08:00.0 eno1: Link is Down
[ 3.493644] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[ 3.513183] mc: Linux media interface: v0.10
[ 3.532758] videodev: Linux video capture interface: v2.00
[ 3.566228] Bluetooth: Core ver 2.22
[ 3.566287] NET: Registered protocol family 31
[ 3.566288] Bluetooth: HCI device and connection manager initialized
[ 3.566291] Bluetooth: HCI socket layer initialized
[ 3.566292] Bluetooth: L2CAP socket layer initialized
[ 3.566296] Bluetooth: SCO socket layer initialized
[ 3.578515] usbcore: registered new interface driver btusb
[ 3.579151] Bluetooth: hci0: Bootloader revision 0.4 build 0 week 30 2018
[ 3.580186] Bluetooth: hci0: Device revision is 2
[ 3.580187] Bluetooth: hci0: Secure boot is enabled
[ 3.580188] Bluetooth: hci0: OTP lock is enabled
[ 3.580188] Bluetooth: hci0: API lock is enabled
[ 3.580189] Bluetooth: hci0: Debug lock is disabled
[ 3.580190] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 3.581998] uvcvideo: Found UVC 1.00 device HP Wide Vision HD Camera (0408:5300)
[ 3.582261] Bluetooth: hci0: Found device firmware: intel/ibt-19-0-4.sfi
[ 3.586771] input: HP Wide Vision HD Camera: HP Wi as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input16
[ 3.586910] usbcore: registered new interface driver uvcvideo
[ 3.586911] USB Video Class driver (1.1.1)
[ 3.643365] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.643366] Bluetooth: BNEP filters: protocol multicast
[ 3.643369] Bluetooth: BNEP socket layer initialized
[ 3.665723] input: HP WMI hotkeys as /devices/virtual/input/input12
[ 4.106426] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.106575] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ 4.130402] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[ 4.130442] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[ 4.130489] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input19
[ 4.130542] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input20
[ 4.130589] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input21
[ 4.143220] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC285: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.143222] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.143223] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.143224] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.143224] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.143225] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ 4.143226] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ 4.181544] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 4.202336] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input22
[ 4.202371] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input23
[ 4.202444] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input24
[ 4.202475] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input25
[ 4.202508] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input26
[ 4.202539] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input27
[ 4.202567] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input28
[ 4.576750] hp_wmi: query 0x4c returned error 0x6
[ 5.176194] Bluetooth: hci0: Waiting for firmware download to complete
[ 5.177271] Bluetooth: hci0: Firmware loaded in 1561283 usecs
[ 5.177286] Bluetooth: hci0: Waiting for device to boot
[ 5.192487] Bluetooth: hci0: Device booted in 14855 usecs
[ 5.196084] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-19-0-4.ddc
[ 5.198280] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 5.201363] Bluetooth: hci0: Firmware revision 0.0 build 191 week 21 2021
[ 5.266797] NET: Registered protocol family 38
[ 6.988406] kauditd_printk_skb: 67 callbacks suppressed
[ 6.988407] audit: type=1334 audit(1630727711.799:76): prog-id=18 op=LOAD
[ 6.988590] audit: type=1334 audit(1630727711.799:77): prog-id=19 op=LOAD
[ 6.988813] audit: type=1334 audit(1630727711.799:78): prog-id=20 op=LOAD
[ 7.014371] audit: type=1130 audit(1630727711.826:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.132351] audit: type=1334 audit(1630727711.942:80): prog-id=21 op=LOAD
[ 7.132427] audit: type=1334 audit(1630727711.942:81): prog-id=22 op=LOAD
[ 7.178124] audit: type=1130 audit(1630727711.989:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.191691] audit: type=1130 audit(1630727712.002:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.212178] audit: type=1130 audit(1630727712.022:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7.321576] rfkill: input handler disabled
[ 7.496855] audit: type=1334 audit(1630727712.309:85): prog-id=23 op=LOAD
[ 9.038597] wlo1: authenticate with bc:62:d2:69:a7:01
[ 9.043692] wlo1: send auth to bc:62:d2:69:a7:01 (try 1/3)
[ 9.169005] wlo1: authenticated
[ 9.172878] wlo1: associate with bc:62:d2:69:a7:01 (try 1/3)
[ 9.176901] wlo1: RX AssocResp from bc:62:d2:69:a7:01 (capab=0x111 status=0 aid=1)
[ 9.181507] wlo1: associated
[ 9.220869] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by bc:62:d2:69:a7:01
[ 9.319539] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 12.814918] kauditd_printk_skb: 5 callbacks suppressed
[ 12.814920] audit: type=1100 audit(1630727717.626:91): pid=1281 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[ 12.816795] audit: type=1101 audit(1630727717.629:92): pid=1281 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[ 12.818064] audit: type=1103 audit(1630727717.629:93): pid=1281 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[ 12.818851] audit: type=1006 audit(1630727717.629:94): pid=1281 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[ 12.837478] audit: type=1130 audit(1630727717.649:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.843858] audit: type=1101 audit(1630727717.656:96): pid=1311 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.843862] audit: type=1103 audit(1630727717.656:97): pid=1311 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="khushi" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 12.843947] audit: type=1006 audit(1630727717.656:98): pid=1311 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=4 res=1
[ 12.845550] audit: type=1105 audit(1630727717.656:99): pid=1311 uid=0 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="khushi" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 12.851847] audit: type=1334 audit(1630727717.662:100): prog-id=24 op=LOAD
[ 13.382904] rfkill: input handler enabled
[ 16.852137] rfkill: input handler disabled
[ 16.949874] Bluetooth: RFCOMM TTY layer initialized
[ 16.949880] Bluetooth: RFCOMM socket layer initialized
[ 16.949885] Bluetooth: RFCOMM ver 1.11
[ 27.819092] kauditd_printk_skb: 12 callbacks suppressed
[ 27.819095] audit: type=1131 audit(1630727732.629:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 27.839160] audit: type=1131 audit(1630727732.649:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@120 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.118742] audit: type=1131 audit(1630727742.855:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 38.265815] audit: type=1334 audit(1630727742.999:116): prog-id=23 op=UNLOAD
[ 47.725792] audit: type=1131 audit(1630727752.400:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.730177] audit: type=1131 audit(1630727752.403:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 47.842191] audit: type=1334 audit(1630727752.516:119): prog-id=20 op=UNLOAD
[ 47.842214] audit: type=1334 audit(1630727752.516:120): prog-id=19 op=UNLOAD
[ 47.842218] audit: type=1334 audit(1630727752.516:121): prog-id=18 op=UNLOAD
[ 47.971221] audit: type=1334 audit(1630727752.643:122): prog-id=16 op=UNLOAD
[ 47.971227] audit: type=1334 audit(1630727752.643:123): prog-id=15 op=UNLOAD
[ 47.971230] audit: type=1334 audit(1630727752.643:124): prog-id=14 op=UNLOAD
[ 67.191658] audit: type=1131 audit(1630727771.845:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 578.697798] audit: type=1334 audit(1630728283.346:126): prog-id=25 op=LOAD
[ 578.817410] audit: type=1130 audit(1630728283.466:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 583.341603] audit: type=1100 audit(1630728287.990:128): pid=5117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="khushi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 583.344390] audit: type=1101 audit(1630728287.993:129): pid=5117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 583.344878] audit: type=1110 audit(1630728287.993:130): pid=5117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 583.352068] audit: type=1105 audit(1630728288.000:131): pid=5117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 586.354762] audit: type=1106 audit(1630728291.003:132): pid=5117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 586.354819] audit: type=1104 audit(1630728291.003:133): pid=5117 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 609.202208] audit: type=1131 audit(1630728313.853:134): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 609.342208] audit: type=1334 audit(1630728313.993:135): prog-id=25 op=UNLOAD
[ 630.244138] audit: type=1101 audit(1630728334.893:136): pid=5210 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 630.244585] audit: type=1110 audit(1630728334.893:137): pid=5210 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 630.252031] audit: type=1105 audit(1630728334.899:138): pid=5210 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 635.691212] audit: type=1106 audit(1630728340.339:139): pid=5210 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 635.691261] audit: type=1104 audit(1630728340.339:140): pid=5210 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 903.235915] audit: type=1130 audit(1630728607.885:141): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 903.235919] audit: type=1131 audit(1630728607.885:142): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 916.280257] audit: type=1101 audit(1630728620.932:143): pid=5856 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 916.280723] audit: type=1110 audit(1630728620.932:144): pid=5856 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 916.282412] audit: type=1105 audit(1630728620.932:145): pid=5856 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 916.306738] audit: type=1106 audit(1630728620.958:146): pid=5856 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 916.306908] audit: type=1104 audit(1630728620.958:147): pid=5856 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1052.313204] audit: type=1101 audit(1630728756.960:148): pid=6136 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1052.313847] audit: type=1110 audit(1630728756.960:149): pid=6136 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1052.321450] audit: type=1105 audit(1630728756.970:150): pid=6136 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1052.325703] audit: type=1106 audit(1630728756.974:151): pid=6136 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1052.325881] audit: type=1104 audit(1630728756.974:152): pid=6136 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_fprintd acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 2219.649133] atkbd serio0: Unknown key pressed (translated set 2, code 0xd8 on isa0060/serio0).
[ 2219.649141] atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
[ 2219.655339] atkbd serio0: Unknown key released (translated set 2, code 0xd8 on isa0060/serio0).
[ 2219.655346] atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
[ 3347.255811] audit: type=1334 audit(1630731051.877:153): prog-id=26 op=LOAD
[ 3347.324303] audit: type=1130 audit(1630731051.947:154): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3352.375555] audit: type=1100 audit(1630731056.997:155): pid=8198 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[ 3352.380172] audit: type=1101 audit(1630731057.000:156): pid=8198 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[ 3352.382824] audit: type=1110 audit(1630731057.004:157): pid=8198 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[ 3377.229745] audit: type=1131 audit(1630731081.850:158): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3377.371251] audit: type=1334 audit(1630731081.993:159): prog-id=26 op=UNLOAD
[ 3516.032966] audit: type=1334 audit(1630731220.652:160): prog-id=27 op=LOAD
[ 3516.032971] audit: type=1334 audit(1630731220.652:161): prog-id=28 op=LOAD
[ 3516.033022] audit: type=1334 audit(1630731220.652:162): prog-id=29 op=LOAD
[ 3516.085309] audit: type=1130 audit(1630731220.702:163): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3519.935981] audit: type=1334 audit(1630731224.556:164): prog-id=30 op=LOAD
[ 3519.936111] audit: type=1334 audit(1630731224.556:165): prog-id=31 op=LOAD
[ 3519.936200] audit: type=1334 audit(1630731224.556:166): prog-id=32 op=LOAD
[ 3519.978866] audit: type=1130 audit(1630731224.599:167): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3546.122209] audit: type=1131 audit(1630731250.739:168): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3546.159166] audit: type=1334 audit(1630731250.779:169): prog-id=29 op=UNLOAD
[ 3546.159168] audit: type=1334 audit(1630731250.779:170): prog-id=28 op=UNLOAD
[ 3546.159170] audit: type=1334 audit(1630731250.779:171): prog-id=27 op=UNLOAD
[ 3550.027450] audit: type=1131 audit(1630731254.645:172): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3550.165827] audit: type=1334 audit(1630731254.785:173): prog-id=32 op=UNLOAD
[ 3550.165830] audit: type=1334 audit(1630731254.785:174): prog-id=31 op=UNLOAD
[ 3550.165831] audit: type=1334 audit(1630731254.785:175): prog-id=30 op=UNLOAD
[ 3654.069927] audit: type=1334 audit(1630731358.688:176): prog-id=33 op=LOAD
[ 3654.070261] audit: type=1334 audit(1630731358.691:177): prog-id=34 op=LOAD
[ 3654.070421] audit: type=1334 audit(1630731358.691:178): prog-id=35 op=LOAD
[ 3654.154314] audit: type=1130 audit(1630731358.774:179): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3667.518946] audit: type=1334 audit(1630731372.138:180): prog-id=36 op=LOAD
[ 3667.519279] audit: type=1334 audit(1630731372.138:181): prog-id=37 op=LOAD
[ 3667.519418] audit: type=1334 audit(1630731372.138:182): prog-id=38 op=LOAD
[ 3667.594245] audit: type=1130 audit(1630731372.214:183): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3670.220121] audit: type=1334 audit(1630731374.841:184): prog-id=39 op=LOAD
[ 3670.277071] audit: type=1130 audit(1630731374.898:185): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3681.946377] audit: type=1334 audit(1630731386.564:186): prog-id=40 op=LOAD
[ 3681.946629] audit: type=1334 audit(1630731386.564:187): prog-id=41 op=LOAD
[ 3681.946786] audit: type=1334 audit(1630731386.568:188): prog-id=42 op=LOAD
[ 3682.012880] audit: type=1130 audit(1630731386.631:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3684.201753] audit: type=1131 audit(1630731388.821:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3684.326885] audit: type=1334 audit(1630731388.948:191): prog-id=35 op=UNLOAD
[ 3684.326889] audit: type=1334 audit(1630731388.948:192): prog-id=34 op=UNLOAD
[ 3684.326891] audit: type=1334 audit(1630731388.948:193): prog-id=33 op=UNLOAD
[ 3697.909737] audit: type=1131 audit(1630731402.527:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3698.040422] audit: type=1334 audit(1630731402.661:195): prog-id=38 op=UNLOAD
[ 3698.040426] audit: type=1334 audit(1630731402.661:196): prog-id=37 op=UNLOAD
[ 3698.040428] audit: type=1334 audit(1630731402.661:197): prog-id=36 op=UNLOAD
[ 3700.234865] audit: type=1131 audit(1630731404.854:198): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3700.437021] audit: type=1334 audit(1630731405.057:199): prog-id=39 op=UNLOAD
[ 3712.048883] audit: type=1131 audit(1630731416.667:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3712.077145] audit: type=1334 audit(1630731416.697:201): prog-id=42 op=UNLOAD
[ 3712.077148] audit: type=1334 audit(1630731416.697:202): prog-id=41 op=UNLOAD
[ 3712.077150] audit: type=1334 audit(1630731416.697:203): prog-id=40 op=UNLOAD
[ 3731.547637] audit: type=1334 audit(1630731436.167:204): prog-id=43 op=LOAD
[ 3731.547789] audit: type=1334 audit(1630731436.167:205): prog-id=44 op=LOAD
[ 3731.547881] audit: type=1334 audit(1630731436.167:206): prog-id=45 op=LOAD
[ 3731.579913] audit: type=1130 audit(1630731436.197:207): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3761.589598] audit: type=1131 audit(1630731466.207:208): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3761.604763] audit: type=1334 audit(1630731466.224:209): prog-id=45 op=UNLOAD
[ 3761.604772] audit: type=1334 audit(1630731466.224:210): prog-id=44 op=UNLOAD
[ 3761.604776] audit: type=1334 audit(1630731466.224:211): prog-id=43 op=UNLOAD
[ 3791.624055] audit: type=1334 audit(1630731496.240:212): prog-id=46 op=LOAD
[ 3791.739242] audit: type=1130 audit(1630731496.357:213): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3797.386571] audit: type=1100 audit(1630731502.003:214): pid=9478 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:authentication grantors=pam_unix acct="khushi" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 3797.389614] audit: type=1101 audit(1630731502.007:215): pid=9478 uid=1000 auid=1000 ses=4 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 3798.855763] clocksource: timekeeping watchdog on CPU12: hpet retried 2 times before success
[ 3799.479619] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 3822.238481] audit: type=1131 audit(1630731526.856:216): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 3822.411648] audit: type=1334 audit(1630731527.030:217): prog-id=46 op=UNLOAD
[ 4672.280434] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[ 4676.346669] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[ 4676.346785] usb usb2-port2: attempt power cycle
[ 7698.126582] audit: type=1111 audit(1630735402.757:218): pid=543 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-activate uuid=c948a4c2-fda8-41c2-a8fe-e7dd8574804f name="Khushi" pid=1373 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[ 7698.153802] audit: type=1130 audit(1630735402.787:219): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7701.106259] wlo1: authenticate with 92:0d:b6:02:4d:4f
[ 7701.109741] wlo1: send auth to 92:0d:b6:02:4d:4f (try 1/3)
[ 7701.138081] wlo1: authenticated
[ 7701.143580] wlo1: associate with 92:0d:b6:02:4d:4f (try 1/3)
[ 7701.183928] wlo1: RX AssocResp from 92:0d:b6:02:4d:4f (capab=0x1431 status=0 aid=1)
[ 7701.187391] wlo1: associated
[ 7701.228030] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 7708.201012] audit: type=1131 audit(1630735412.833:220): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8094.377519] wlo1: disassociated from 92:0d:b6:02:4d:4f (Reason: 1=UNSPECIFIED)
[ 8125.234708] audit: type=1130 audit(1630735829.866:221): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8133.789067] wlo1: authenticate with bc:62:d2:69:a7:01
[ 8133.793150] wlo1: send auth to bc:62:d2:69:a7:01 (try 1/3)
[ 8133.824420] wlo1: authenticated
[ 8133.827755] wlo1: associate with bc:62:d2:69:a7:01 (try 1/3)
[ 8133.831957] wlo1: RX AssocResp from bc:62:d2:69:a7:01 (capab=0x111 status=0 aid=1)
[ 8133.835333] wlo1: associated
[ 8133.899464] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by bc:62:d2:69:a7:01
[ 8133.938132] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[ 8135.196553] audit: type=1131 audit(1630735839.826:222): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9127.819150] atkbd serio0: Unknown key pressed (translated set 2, code 0xd8 on isa0060/serio0).
[ 9127.819158] atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
[ 9127.823185] atkbd serio0: Unknown key released (translated set 2, code 0xd8 on isa0060/serio0).
[ 9127.823193] atkbd serio0: Use 'setkeycodes e058 <keycode>' to make it known.
[10325.154162] audit: type=1130 audit(1630738029.778:223): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10325.155360] wlo1: deauthenticating from bc:62:d2:69:a7:01 by local choice (Reason: 3=DEAUTH_LEAVING)
[10327.554371] PM: suspend entry (deep)
[10327.559920] Filesystems sync: 0.005 seconds
[10327.564432] rfkill: input handler enabled
[10327.671539] Freezing user space processes ... (elapsed 0.002 seconds) done.
[10327.673818] OOM killer disabled.
[10327.673818] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[10327.675165] printk: Suspending console(s) (use no_console_suspend to debug)
[10327.916517] ACPI: EC: interrupt blocked
[10328.040032] ACPI: Preparing to enter system sleep state S3
[10328.042547] ACPI: EC: event blocked
[10328.042549] ACPI: EC: EC stopped
[10328.042551] PM: Saving platform NVS memory
[10328.043072] Disabling non-boot CPUs ...
[10328.044271] IRQ 151: no longer affine to CPU1
[10328.045328] smpboot: CPU 1 is now offline
[10328.047832] IRQ 152: no longer affine to CPU2
[10328.048907] smpboot: CPU 2 is now offline
[10328.051472] IRQ 153: no longer affine to CPU3
[10328.052521] smpboot: CPU 3 is now offline
[10328.054901] IRQ 154: no longer affine to CPU4
[10328.055950] smpboot: CPU 4 is now offline
[10328.058296] IRQ 155: no longer affine to CPU5
[10328.059351] smpboot: CPU 5 is now offline
[10328.062923] IRQ 156: no longer affine to CPU6
[10328.063987] smpboot: CPU 6 is now offline
[10328.065576] IRQ 157: no longer affine to CPU7
[10328.066651] smpboot: CPU 7 is now offline
[10328.069049] IRQ 158: no longer affine to CPU8
[10328.071508] smpboot: CPU 8 is now offline
[10328.073480] IRQ 159: no longer affine to CPU9
[10328.074514] smpboot: CPU 9 is now offline
[10328.076421] IRQ 160: no longer affine to CPU10
[10328.077454] smpboot: CPU 10 is now offline
[10328.080458] smpboot: CPU 11 is now offline
[10328.083472] smpboot: CPU 12 is now offline
[10328.086486] smpboot: CPU 13 is now offline
[10328.089435] smpboot: CPU 14 is now offline
[10328.092036] smpboot: CPU 15 is now offline
[10328.098220] ACPI: Low-level resume complete
[10328.098397] ACPI: EC: EC started
[10328.098399] PM: Restoring platform NVS memory
[10328.104316] smpboot: Scheduler frequency invariance went wobbly, disabling!
[10328.104503] Enabling non-boot CPUs ...
[10328.104623] x86: Booting SMP configuration:
[10328.104624] smpboot: Booting Node 0 Processor 1 APIC 0x2
[10328.106135] CPU1 is up
[10328.106279] smpboot: Booting Node 0 Processor 2 APIC 0x4
[10328.107763] CPU2 is up
[10328.107905] smpboot: Booting Node 0 Processor 3 APIC 0x6
[10328.109405] CPU3 is up
[10328.109530] smpboot: Booting Node 0 Processor 4 APIC 0x8
[10328.111035] CPU4 is up
[10328.111154] smpboot: Booting Node 0 Processor 5 APIC 0xa
[10328.112680] CPU5 is up
[10328.112800] smpboot: Booting Node 0 Processor 6 APIC 0xc
[10328.114271] CPU6 is up
[10328.114392] smpboot: Booting Node 0 Processor 7 APIC 0xe
[10328.115878] CPU7 is up
[10328.115999] smpboot: Booting Node 0 Processor 8 APIC 0x1
[10328.116825] CPU8 is up
[10328.116952] smpboot: Booting Node 0 Processor 9 APIC 0x3
[10328.117609] CPU9 is up
[10328.117731] smpboot: Booting Node 0 Processor 10 APIC 0x5
[10328.118408] CPU10 is up
[10328.118525] smpboot: Booting Node 0 Processor 11 APIC 0x7
[10328.119201] CPU11 is up
[10328.119313] smpboot: Booting Node 0 Processor 12 APIC 0x9
[10328.119999] CPU12 is up
[10328.120111] smpboot: Booting Node 0 Processor 13 APIC 0xb
[10328.120808] CPU13 is up
[10328.120918] smpboot: Booting Node 0 Processor 14 APIC 0xd
[10328.121531] CPU14 is up
[10328.121643] smpboot: Booting Node 0 Processor 15 APIC 0xf
[10328.122278] CPU15 is up
[10328.135718] ACPI: Waking up from system sleep state S3
[10328.143264] ACPI: button: The lid device is not compliant to SW_LID.
[10328.145463] ACPI: EC: interrupt unblocked
[10328.749611] hp_wmi: bad event status 0x5
[10329.280447] ACPI: EC: event unblocked
[10329.302143] nvme nvme1: 8/0/0 default/read/poll queues
[10329.362714] nvme nvme0: 8/0/0 default/read/poll queues
[10329.585359] usb 1-5: reset high-speed USB device number 2 using xhci_hcd
[10329.598646] ata1: SATA link down (SStatus 4 SControl 300)
[10329.747954] restoring control 00000000-0000-0000-0000-000000000101/10/5
[10329.747958] restoring control 00000000-0000-0000-0000-000000000101/12/11
[10329.750114] acpi LNXPOWER:07: Turning OFF
[10329.750163] acpi LNXPOWER:03: Turning OFF
[10329.751198] acpi LNXPOWER:02: Turning OFF
[10329.752309] OOM killer enabled.
[10329.752311] Restarting tasks ... done.
[10329.757286] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[10329.765717] PM: suspend exit
[10329.771992] rfkill: input handler disabled
[10330.108516] audit: type=1130 audit(1630740154.006:224): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10330.108525] audit: type=1131 audit(1630740154.006:225): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10330.145114] Generic FE-GE Realtek PHY r8169-0-800:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-0-800:00, irq=IGNORE)
[10330.308875] r8169 0000:08:00.0 eno1: Link is Down
[10330.377171] hp_wmi: bad event status 0x5
[10335.212594] audit: type=1131 audit(1630740159.109:226): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10335.660703] wlo1: authenticate with bc:62:d2:69:a7:01
[10335.663964] wlo1: send auth to bc:62:d2:69:a7:01 (try 1/3)
[10335.791421] wlo1: authenticated
[10335.791854] wlo1: associate with bc:62:d2:69:a7:01 (try 1/3)
[10335.796473] wlo1: RX AssocResp from bc:62:d2:69:a7:01 (capab=0x111 status=0 aid=2)
[10335.802773] wlo1: associated
[10335.842504] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by bc:62:d2:69:a7:01
[10335.911049] IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
[10336.040404] audit: type=1130 audit(1630740159.936:227): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10336.452140] audit: type=1334 audit(1630740160.349:228): prog-id=47 op=LOAD
[10336.570486] audit: type=1130 audit(1630740160.466:229): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10346.215750] audit: type=1131 audit(1630740170.113:230): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10361.364133] audit: type=1100 audit(1630740185.259:231): pid=15494 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=? acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=failed'
[10367.237215] audit: type=1131 audit(1630740191.132:232): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10367.310172] audit: type=1100 audit(1630740191.206:233): pid=15535 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[10367.314576] audit: type=1101 audit(1630740191.209:234): pid=15535 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[10367.317133] audit: type=1110 audit(1630740191.212:235): pid=15535 uid=0 auid=1000 ses=3 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="khushi" exe="/usr/lib/gdm-session-worker" hostname=khushi addr=? terminal=/dev/tty1 res=success'
[10367.415843] audit: type=1334 audit(1630740191.312:236): prog-id=47 op=UNLOAD
[10367.439148] audit: type=1334 audit(1630740191.336:237): prog-id=48 op=LOAD
[10367.556178] audit: type=1130 audit(1630740191.452:238): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10398.238021] audit: type=1131 audit(1630740222.132:239): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fprintd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10398.426581] audit: type=1334 audit(1630740222.322:240): prog-id=48 op=UNLOAD
[11146.405638] audit: type=1130 audit(1630740970.292:241): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
The output of journalctl
is:
-- Journal begins at Thu 2021-08-12 20:00:08 IST, ends at Sat 2021-09-04 13:16:56 IST. --
Aug 12 20:00:08 khushi kernel: Linux version 5.10.42-1-MANJARO (builduser@LEGION) (gcc (GCC) 11.1.0, GNU ld (GNU B>
Aug 12 20:00:08 khushi kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=71927843-4c9f-4e08-b2d>
Aug 12 20:00:08 khushi kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
Aug 12 20:00:08 khushi kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
Aug 12 20:00:08 khushi kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
Aug 12 20:00:08 khushi kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
Aug 12 20:00:08 khushi kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
Aug 12 20:00:08 khushi kernel: x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
Aug 12 20:00:08 khushi kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
Aug 12 20:00:08 khushi kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
Aug 12 20:00:08 khushi kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
Aug 12 20:00:08 khushi kernel: x86/fpu: xstate_offset[9]: 960, xstate_sizes[9]: 8
Aug 12 20:00:08 khushi kernel: x86/fpu: Enabled xstate features 0x21f, context size is 968 bytes, using 'compacted>
Aug 12 20:00:08 khushi kernel: BIOS-provided physical RAM map:
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x0000000000100000-0x000000006908dfff] usable
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000006908e000-0x000000006958dfff] type 20
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000006958e000-0x000000006bb7dfff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000006bb7e000-0x000000006da7dfff] ACPI NVS
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000006da7e000-0x000000006db4dfff] ACPI data
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000006db4e000-0x000000006db4efff] usable
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x000000006db4f000-0x00000000737fffff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x00000000ff380000-0x00000000ffffffff] reserved
Aug 12 20:00:08 khushi kernel: BIOS-e820: [mem 0x0000000100000000-0x000000048a7fffff] usable
Aug 12 20:00:08 khushi kernel: NX (Execute Disable) protection: active
Aug 12 20:00:08 khushi kernel: efi: EFI v2.70 by INSYDE Corp.
Aug 12 20:00:08 khushi kernel: efi: ACPI=0x6db4d000 ACPI 2.0=0x6db4d014 TPMFinalLog=0x6da75000 ESRT=0x6ad72918 SMB>
Aug 12 20:00:08 khushi kernel: SMBIOS 3.2.0 present.
Aug 12 20:00:08 khushi kernel: DMI: HP HP Pavilion Gaming Laptop 15-dk1xxx/8742, BIOS F.21 01/08/2021
Aug 12 20:00:08 khushi kernel: tsc: Detected 2200.000 MHz processor
Aug 12 20:00:08 khushi kernel: tsc: Detected 2199.996 MHz TSC
Aug 12 20:00:08 khushi kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Aug 12 20:00:08 khushi kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Aug 12 20:00:08 khushi kernel: last_pfn = 0x48a800 max_arch_pfn = 0x400000000
Aug 12 20:00:08 khushi kernel: MTRR default type: write-back
Aug 12 20:00:08 khushi kernel: MTRR fixed ranges enabled:
Aug 12 20:00:08 khushi kernel: 00000-9FFFF write-back
Aug 12 20:00:08 khushi kernel: A0000-BFFFF uncachable
Aug 12 20:00:08 khushi kernel: C0000-FFFFF write-protect
Aug 12 20:00:08 khushi kernel: MTRR variable ranges enabled:
Will be very helpful if anyone of you can help me out to resolve this. Thanks!
