Hi Scotty, thanks for the rapid reply, I don’t remember exactly. I think I just checked the amdgpu package and tried to reinstall ‘linux-firmware-amdgpu’ using pacman. Either way I dont think I changed the system doing it.
Commands and output:
❯ inxi -zv8
Kernel: 6.18.33-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=70033e1a-c228-45d0-966e-42f31e1f7b22 rw rootflags=subvol=@
quiet splash iommu=pt amdgpu.sg_display=0 pcie_aspm=off
mem_sleep_default=deep amdgpu.runpm=0 amdgpu.abmlevel=0 amdgpu.bapm=0
pcie_port_pm=off amdgpu.mclk_dpm_en=0
Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
Type: Desktop Mobo: ASRock model: X670E Taichi serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC.
v: 4.20 date: 04/16/2026
System RAM: total: 32 GiB available: 30.92 GiB used: 7.79 GiB (25.2%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 6200 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: N/A part-no: RG33D516GX2-8000C38B serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 7950X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB
desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 5400 min/max: 425/5883 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5400 2: 5400 3: 5400
4: 5400 5: 5400 6: 5400 7: 5400 8: 5400 9: 5400 10: 5400 11: 5400 12: 5400
13: 5400 14: 5400 15: 5400 16: 5400 17: 5400 18: 5400 19: 5400 20: 5400
21: 5400 22: 5400 23: 5400 24: 5400 25: 5400 26: 5400 27: 5400 28: 5400
29: 5400 30: 5400 31: 5400 32: 5400 bogomips: 297107
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3
code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: Idek Iiyama PL3467WQ serial: <filter> built: 2022
res: mode: 3440x1440 hz: 165 scale: 100% (1) dpi: 110 gamma: 1.2 chroma:
red: x: 0.675 y: 0.310 green: x: 0.278 y: 0.651 blue: x: 0.153 y: 0.071
white: x: 0.314 y: 0.329 size: 797x334mm (31.38x13.15") diag: 864mm (34")
modes: 3440x1440, 3840x2160, 1920x1080, 1680x1050, 1280x1024, 1440x900,
1280x960, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 96 3: parse_edid: unknown tag 112
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi navi31 ACO
DRM 3.64 6.18.33-1-MANJARO) device-ID: 1002:744c memory: 23.44 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.4.350 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 26.1.1-arch1.2
device-ID: 1002:744c surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: miniDSP UMIK-2 driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
chip-ID: 2752:002b class-ID: 0300 serial: <filter>
Device-3: Thesycon System & Consulting GmbH SMSL M8A 1.1.2
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-12:4 chip-ID: 152a:85dd class-ID: fe01
API: ALSA v: k6.18.33-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
Device-1: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: b000 bus-ID: 49:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp73s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:2 chip-ID: 0bda:8771
Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
Local Storage: total: 2.73 TiB used: 275.8 GiB (9.9%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620311WD temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
ID-1: / raw-size: 400 GiB size: 400 GiB (100.00%) used: 275.77 GiB (68.9%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 70033e1a-c228-45d0-966e-42f31e1f7b22
used: 31.8 MiB (33.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 125B-D5C0
ID-3: /home raw-size: 400 GiB size: 400 GiB (100.00%)
used: 275.77 GiB (68.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 70033e1a-c228-45d0-966e-42f31e1f7b22
ID-4: /var/cache raw-size: 400 GiB size: 400 GiB (100.00%)
ID-5: /var/log raw-size: 400 GiB size: 400 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 1.43 TiB fs: ntfs label: N/A
uuid: 01DCCB5D3164D100
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 770 MiB fs: ntfs label: N/A
uuid: F220078120074BD3
ID-4: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: Game Drive
uuid: 80CE4692CE468100
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: miniDSP UMIK-2 type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Hub-4: 3-3:3 info: VIA Labs Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2811
Hub-5: 4-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 5-3:2 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Hub-7: 5-5:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-5.2:5 info: WL WLMOUSE SWORD X 8K RECEIVER
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 36a7:a878 class-ID: 0300 serial: <filter>
Device-2: 5-5.3:6 info: Endor AG ClubSportPedal type: HID
driver: fanatec,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0eb7:183b class-ID: 0300
Device-3: 5-12:4 info: Thesycon System & Consulting GmbH SMSL M8A 1.1.2
type: audio driver: snd-usb-audio interfaces: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 152a:85dd
class-ID: fe01
Hub-8: 6-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-9: 6-5:2 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-11: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-12: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 9-1:2 info: ATK Hex80 type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 373b:1177 class-ID: 0300 serial: <filter>
Hub-13: 10-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-14: 11-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 11-1:2 info: ASRock LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
serial: <filter>
System Temperatures: cpu: 54.5 C mobo: 45.0 C gpu: amdgpu temp: 49.0 C
mem: 61.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 835
Packages: 1703 pm: pacman pkgs: 1695 libs: 415 tools: pamac,yay pm: flatpak
pkgs: 0 pm: snap pkgs: 8
1: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
7: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
8: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 609
1: cpu: 39.2% command: steamwebhelper pid: 4645 mem: 228.1 MiB (0.7%)
2: cpu: 21.9% command: obs pid: 7701 mem: 382.5 MiB (1.2%)
3: cpu: 8.8% command: easyeffects pid: 1699 mem: 278.4 MiB (0.8%)
4: cpu: 7.7% command: firefox pid: 2684 mem: 832.7 MiB (2.6%)
5: cpu: 7.3% command: kwin_wayland pid: 1122 mem: 365.4 MiB (1.1%)
Memory top: 5 of 609
1: mem: 832.7 MiB (2.6%) command: firefox pid: 2684 cpu: 7.7%
2: mem: 594.7 MiB (1.8%) command: thunderbird pid: 12775 cpu: 0.6%
3: mem: 474.6 MiB (1.4%) command: spotify pid: 8763 cpu: 1.1%
4: mem: 472.2 MiB (1.4%) command: exe pid: 2344 cpu: 1.8%
5: mem: 462.3 MiB (1.4%) command: steamwebhelper pid: 3352 cpu: 0.0%
Processes: 609 Power: uptime: 1h 47m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.28 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
tool: systemctl
Compilers: clang: 22.1.5 gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.40
❯ pamac search -i amd
libteam 1.32-3 extra
Library for controlling team network device
xf86-video-amdgpu 25.0.0-1 extra
X.org amdgpu video driver
mhwd-amdgpu 19.1.0-1 extra
MHWD module-ids for amdgpu
linux-firmware-amdgpu 20260519-1 core
Firmware files for Linux - Firmware for AMD Radeon GPUs
hip-runtime-amd 7.2.3-1 extra
Heterogeneous Interface for Portability (AMD runtime)
amd-ucode 20260519-1 core
Microcode update image for AMD CPUs
