So I have gotten a new amd gpu an rx 6600 (previously an rtx 2070) and I have removed the old nvidia drivers and installed amd open source drivers and I can play games just fine but after a while ( around an hour) the games I play (all of them) suddenly lose all the fps and goes from 120+ to 30 - 40, I pulled up CPU-X and I see my gpu is being used but my games just doesnt seem to be anymore, I have also switched to wayland as well since I am on amd now, The strange thing is restarting the computer gets my fps back but of course this is not want I want to do every time.
inxi output:
Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=00f3477c-e9b6-4bb9-91a5-2906c026d43e rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
UEFI: American Megatrends v: 4622 date: 09/29/2024
System RAM: total: 16 GiB available: 15.53 GiB used: 3.78 GiB (24.3%)
Device-1: DIMM_A1 type: no module installed
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: KHX3200C16D4/8GX serial: <filter>
Device-3: DIMM_B1 type: no module installed
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 1+
level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
model-id: 8 stepping: 2 microcode: 0x800820D
smt: enabled cache: L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB
desc: 6x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 1550 min/max: 1550/3800 boost: disabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550 3: 1550
4: 1550 5: 1550 6: 1550 7: 1550 8: 1550 9: 1550 10: 1550 11: 1550 12: 1550
bogomips: 91247
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Navi 23 [Radeon RX 6600/6600
XT/6600M] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
Writeback-1 bus-ID: 0b:00.0 chip-ID: 1002:73ff class-ID: 0300
Display: wayland server: X.org v: 1.21.1.14 with: Xwayland v: 24.1.4
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: HP OMEN 24 serial: <filter> built: 2024 res:
mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.8-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
LLVM 18.1.8 DRM 3.59 6.12.4-1-MANJARO) device-ID: 1002:73ff
memory: 7.81 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 7 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: N/A device-ID: 1002:73ff
surfaces: xcb,xlib,wayland
de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 0b:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASUSTeK
bus-ID: 0d:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 0c76:161e class-ID: 0300
API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-2: TP-Link Archer T2U PLUS [RTL8821AU] driver: rtl8821au type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 2357:0120
class-ID: 0000 serial: <filter>
IF: wlp12s0f3u4 state: up mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 2.27 TiB used: 1.04 TiB (45.5%)
model: WDS500G2B0C size: 465.76 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000BX500SSD1
tech: SSD serial: <filter> fw-rev: 030 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 QVO 1TB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-1: / raw-size: 465.26 GiB size: 456.89 GiB (98.20%)
used: 209.93 GiB (45.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 00f3477c-e9b6-4bb9-91a5-2906c026d43e
used: 251.6 MiB (49.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: D62E-3FAE
ID-3: /mnt/1TB SSD raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 531.8 GiB (58.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: 1TB SSD
uuid: a7d93cc7-675a-4eb2-af8f-676021235387
ID-4: /mnt/Samsung SSD 1TB raw-size: 931.51 GiB size: 915.81 GiB (98.31%)
used: 317.96 GiB (34.7%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17
label: Samsung SSD 1TB uuid: b6fc83ac-25a1-4db9-8bc0-9826a12a405c
Device-1: 1-1:2 info: JMTek LLC. USB PnP Audio Device type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
Device-2: 1-2:3 info: Logitech G Pro Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c085 class-ID: 0300
serial: <filter>
Device-1: 3-1:2 info: Razer USA RZ03-0274 Gaming Keyboard [Cynosa Lite]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:023f class-ID: 0300
Device-2: 3-2:3 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-3: 3-4:4 info: TP-Link Archer T2U PLUS [RTL8821AU] type: Network
driver: rtl8821au interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 2357:0120 class-ID: 0000
serial: <filter>
Hub-4: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 46.9 C mobo: N/A gpu: amdgpu temp: 43.0 C
mem: 40.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
Processes: 357 Power: uptime: 38m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: 1594 pm: pacman pkgs: 1508 libs: 380 tools: pamac pm: flatpak
pkgs: 86 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
