I am quite happy with the yay but I came across paru and I have seen that most people use both of them I just can’t decide which one to go with? should I stay with yay or switch to paru?
btw I found that paru is little bit faster in performing the task
There is no best AUR Helper, but if you ask here, pamac would probably be the one recommended as it is Manjaro’s main package manager that also installs packages from AUR.
“best” is subjective. We’re not here to make decisions for you. Try them both and see which you like the best. This is a support forum, not Reddit.
