Which hip package for Blender for AMD GPU?
Hi all,
I’m trying to enable HIP in Blender 4.1.1 with amdgpu drivers.
I’m confused because there are many packages that should provide HIP and I would avoid to mess up a newly setup machine.
Any hint on which package I should use?
So far I’ve found these promising packages:
 pamac search hip-runtime-amd         ✔
opencl-amd  1:6.1.2-1        AUR
    ROCm components repackaged from AMD's Ubuntu releases (ROCr runtime, ROCm runtime, HIP runtime) - This package is intended to work along with the free
    amdgpu stack.
hip-runtime-amd  6.0.2-4        extra
    Heterogeneous Interface for Portability ROCm
and
pamac search rocm-hip-runtime         ✔
opencl-amd-dev  1:6.1.2-1        AUR
    OpenCL SDK / HIP SDK / ROCM Compiler. This package needs at least 20GB of disk space.
    amdgpu stack.
rocm-hip-runtime  6.0.2-1        extra
    Packages to run HIP applications on the AMD platform
and
pamac search opencl-amd         ✔
amdapp-sdk  3.0-23        AUR
    AMD Accelerated Parallel Processing (APP) SDK, 3.0 with OpenCL 2.0 support.
xmr-stak-opencl-amd  2.10.8-1        AUR
    Unified All-in-one Monero miner (AMD)
    amdgpu stack.
BTW rocminfo says:
sudo rocminfo         ✔
[sudo] password di mirto:
ROCk module is loaded
HSA System Attributes
Runtime Version:         1.1
System Timestamp Freq.:  1000.000000MHz
Sig. Max Wait Duration:  18446744073709551615 (0xFFFFFFFFFFFFFFFF) (timestamp count)
Machine Model:           LARGE
System Endianness:       LITTLE
Mwaitx:                  DISABLED
DMAbuf Support:          YES
HSA Agents
Agent 1
  Name:                    AMD Ryzen 7 5800X 8-Core Processor
  Uuid:                    CPU-XX
  Marketing Name:          AMD Ryzen 7 5800X 8-Core Processor
  Vendor Name:             CPU
  Feature:                 None specified
  Profile:                 FULL_PROFILE
  Float Round Mode:        NEAR
  Max Queue Number:        0(0x0)
  Queue Min Size:          0(0x0)
  Queue Max Size:          0(0x0)
  Queue Type:              MULTI
  Node:                    0
  Device Type:             CPU
  Cache Info:
    L1:                      32768(0x8000) KB
  Chip ID:                 0(0x0)
  ASIC Revision:           0(0x0)
  Cacheline Size:          64(0x40)
  Max Clock Freq. (MHz):   3800
  BDFID:                   0
  Internal Node ID:        0
  Compute Unit:            16
  SIMDs per CU:            0
  Shader Engines:          0
  Shader Arrs. per Eng.:   0
  WatchPts on Addr. Ranges:1
  Features:                None
  Pool Info:
    Pool 1
      Segment:                 GLOBAL; FLAGS: FINE GRAINED
      Allocatable:             TRUE
      Alloc Granule:           4KB
      Alloc Alignment:         4KB
      Accessible by all:       TRUE
    Pool 2
      Segment:                 GLOBAL; FLAGS: KERNARG, FINE GRAINED
      Allocatable:             TRUE
      Alloc Granule:           4KB
    Pool 3
      Segment:                 GLOBAL; FLAGS: COARSE GRAINED
      Allocatable:             TRUE
      Alloc Granule:           4KB
  ISA Info:
Agent 2
  Uuid:                    GPU-XX
  Marketing Name:          AMD Radeon RX 6700 XT
  Vendor Name:             AMD
  Feature:                 KERNEL_DISPATCH
  Profile:                 BASE_PROFILE
  Max Queue Number:        128(0x80)
  Queue Min Size:          64(0x40)
  Queue Max Size:          131072(0x20000)
  Queue Type:              MULTI
  Node:                    1
  Device Type:             GPU
  Cache Info:
    L1:                      16(0x10) KB
    L2:                      3072(0xc00) KB
    L3:                      98304(0x18000) KB
  Chip ID:                 29663(0x73df)
  Cacheline Size:          128(0x80)
  Max Clock Freq. (MHz):   2855
  BDFID:                   12032
  Internal Node ID:        1
  Compute Unit:            40
  SIMDs per CU:            2
  Shader Engines:          2
  Shader Arrs. per Eng.:   2
  WatchPts on Addr. Ranges:4
  Coherent Host Access:    FALSE
  Features:                KERNEL_DISPATCH
  Fast F16 Operation:      TRUE
  Wavefront Size:          32(0x20)
  Workgroup Max Size:      1024(0x400)
  Workgroup Max Size per Dimension:
    x                        1024(0x400)
    y                        1024(0x400)
    z                        1024(0x400)
  Max Waves Per CU:        32(0x20)
  Max Work-item Per CU:    1024(0x400)
  Grid Max Size:           4294967295(0xffffffff)
  Grid Max Size per Dimension:
    x                        4294967295(0xffffffff)
    y                        4294967295(0xffffffff)
    z                        4294967295(0xffffffff)
  Max fbarriers/Workgrp:   32
  Packet Processor uCode:: 118
  SDMA engine uCode::      80
  IOMMU Support::          None
  Pool Info:
    Pool 1
      Allocatable:             TRUE
      Alloc Granule:           4KB
      Accessible by all:       FALSE
    Pool 2
      Segment:                 GLOBAL; FLAGS: EXTENDED FINE GRAINED
      Allocatable:             TRUE
      Alloc Granule:           4KB
    Pool 3
      Segment:                 GROUP
      Allocatable:             FALSE
      Alloc Granule:           0KB
      Alloc Alignment:         0KB
  ISA Info:
    ISA 1
      Machine Models:          HSA_MACHINE_MODEL_LARGE
      Profiles:                HSA_PROFILE_BASE
      Default Rounding Mode:   NEAR
      Fast f16:                TRUE
        x                        1024(0x400)
        y                        1024(0x400)
        z                        1024(0x400)
      FBarrier Max Size:       32
*** Done ***
https://wiki.archlinux.org/title/Blender#HIP_on_AMD_open_source_drivers
Thanks a lot: it works.
BTW if I use Blender installed from Pamac it crashed during the rendering
if I use the Blender downloaded from the Blender site it works correctly
