Hello,
I am running Manjaro xfce version 4.16. The Linux installer i used included the option to encrypt the partition so I opted for it. Is there a terminal command to see the stats on the encryption that my os is using? I suspect AES-128 at least, but I cannot find a way to verify this. All I can see is that LUKS version 1 is being used. I am new to Linux, switched from windows last week but I can already tell that I’m a lifer for Linux now!
Thanks!
