Hi,
i got a new device a few weeks ago (refurbished HP ZBook with a seperate secondary Nvidia Quadro T2000 graphics adapter built in).
Currently i am running KDE Plasma 6 on Wayland with the Intel UHD Graphics 630 adapter, but i would like to use the Nvidia at least for some rendering work (e.g. image editing).
How can this be achieved and which drivers should i install?
Thanks
you can check before ( high priority ) and version nvidia drivers
sudo mhwd -d -l
So it means that V 470 is the correct driver?
This is the output of mhwd:
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:1fb8)
Display controller nVidia Corporation TU117GLM [Quadro T2000 Mobile / Max-Q]
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: video-modesetting
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 7
FREEDRIVER: false
No.
Out of what is available there the preferable profile is the latest - video-hybrid-intel-nvidia-prime.
But you didnt show the ‘installed’ section.
If you cannot for some reason then show us the output of
mhwd -li
sudo mhwd -li does give this result:
Warning: No installed PCI configs!
but the previous commands (sudo mhwd -d -l ) full output is this, so i think there is “nothing” installed so far. During setup of Manjaro, i selected the open-source drivers.
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2024.05.03
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2024.05.06
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:3e9b)
Display controller Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2024.05.06
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
volkskamera:
Nvidia Quadro T2000
According to Nvidia - the latest drivers support your card
Quadro Series (Notebooks):
Quadro T2000, Quadro T1000, Quadro P5200, Quadro P5000, Quadro P4200, Quadro P3200, Quadro P4000, Quadro P3000, Quadro P2000, Quadro P1000, Quadro P620, Quadro P600, Quadro P520, Quadro P500, Quadro M2200, Quadro M1200, Quadro M620, Quadro M520, Quadro M5500, Quadro M5000M, Quadro M4000M, Quadro M3000M, Quadro M2000M, Quadro M1000M, Quadro M600M, Quadro M500M, Quadro K2200M, Quadro K620M
Thanks, but your Link goes to the Windows version.
Will search for the Linux version now.
EDIT: Got it here
You arent supposed to get it manually.
sudo mhwd -i pci video-hybrid-intel-nvidia-prime
