Which donation channel should I use: Collective or Foundation?
what is the difference between “our collective” and " Linux foundation "
Open Collective has EU, UK and US based departments, while Linux Foundation only has US, as far as I know.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
