But I set those permissions when I set up my system from the start. So still an enigma of sorts.
Then, perhaps, I did something with a sudo Nemo window when I had steam running.
But yeah, if the issue can’t be reproduced, there may be little point in reporting it indeed. But they may want to be informed about it nevertheless.
Meanwhile, I’ll contact Steam Support and ask them if I can somehow reset that pull-down menu. It’s probably some .json file somewhere in my Steam directory.
In case I don’t get replied anymore or send none, I already thank you guys for looking into it with me.
But the problem so far if I understand is that you can see the path of folders you shouldn’t have access to, folders you can’t list their content anyway in the Steam client (or can you list the content of these folders you shouldn’t have access to?)?
I just shut down Steam, I’m gonna try the reset command now and see if those directories still show up. It’ll take some minutes, but I’ll report back here.
But you do not mention how you reached that conclusion.
If it is a custom package from AUR - it is unsupported and any use is at your own risk. The disclaimer on the AUR web page is equally valid for Manjaro.
DISCLAIMER: AUR packages are user produced content. Any use of the provided files is at your own risk.
Please educate yourself on AUR by reading the document linked
You have to understand how permissions works and it is frowned upon to change initial system permissions on system folders as this may have unintended side effects.
The folder x is accessible only by root - but default umask creates folders as 755 - so you have deliberately assigned new permissions - unless of course the listing is all a part of trying to prove malware intent.
/mnt is a designated system temporary mount point - it is not recommended for permanent mounts.
