AlanP
22 March 2023 14:02
1
Hello,
many gtk themes are available with lightdm-gtk-greeter package. But, the login box don’t have round corners. I want to see the login box look like this (for example) : https://149366088.v2.pressablecdn.com/wp-content/uploads/2013/12/lightdm-gtk-greeter_1.7.0_positioning.png
So, how to do that ?
Thanks.
Hi @AlanP ,
According to this page , the theme is in:
/etc/lightdm/slick-greeter.conf
So check there.
Hope this helps!
Edit:
This should also help:
A configuration tool for the LightDM display manager
Which is in the commnity repository:
$ pamac search lightdm
lightdm-settings 1.6.1-1 community
So can be installed with:
pamac install lightdm-settings
It is dependent on the theme you choose in LightDM GTK+ Greeter Settings under Appearance-Theme.
Install a GTK theme and test to your liking, if you don’t have one you like already. I tested with Adwaita Dark and it had rounded corners.
Section 2-Themes here : GTK - ArchWiki
AlanP
23 March 2023 11:09
4
Hello,
Lightdm-settings is very useful, happy to see this kind of tool. I will try Yaru-colors theme (it is available in AUR).
