So, I’ve previously used xrandr -o in several linux distributions to dynamically alter screen orientation. I heard Manjaro was basically Kubuntu w/ a better package manager, so I decided I’d give it a spin…
I load the live instance and test drive; “xrandr -o left” and xrandr -o normal" both work just fine. Then I install.
Now when I type an xrandr command it tries to switch it to “_xrandr”, then it says it has no idea what I’m talking about, whether I allow the substitution or not, though there’s still a man page. I have made sure to select X11 instead of Wayland in the login screen, but still the same behavior. What’s going on?
Then I’m afraid you heard (or were told) wrong. Kubuntu is Debian-based, while Manjaro is Arch-based.
We don’t follow any of the Debian or {K,X,M,Edu,}buntu decisions. We follow Arch as our upstream.
Furthermore Kubuntu is a fixed-point-release distribution, whereas Manjaro is a rolling-release distribution. You install it only once and just keep it updated. No periodic reinstallation required.
If it’s on the live image but not on the installed system, then perhaps you used one of the minimal images instead of the full-fat ones?
