Hi!
Why was the Bangladeshi mirror removed from the Manjaro repo site? By mistakes or something else?
Hello,
Make sure you first understand how Manjaro Mirrors - Manjaro work.
If a mirror goes under the radar for whatever reason or was turned of by whoever set it up in the first place, is removed from the repo.manjaro.org list too.
You can instead use the other two mirrors from India, once they sync …
