I have the driver, where is it? I can’t find it in Mate.
If you cannot locate it - install it
sudo pacman -Syu nvidia-settings
And careful - do not save the settings where nvidia-settings suggest - as /etc/X11/xorg.conf is not the correct place - if you installed using mhwd - the correct place would be /etc/mhwd.d or in /etc/X11/xorg.conf.d
If you installed using mhwd - you will have a file /etc/X11/mhwd.d/99-mhwd.conf you should overwrite that one.
