hey guys I need a path to the nodejs for sublime prettier and I can find the path
I install nodejs with pacman
when I run which nodejs it return node js not found however which I use node -v I return the node js current version which mean node is install correctly also I can use npm and node fine but I cant find the path to node
thanx man I was using nodejs in the command and its node silly me
